Old 08-23-2012, 08:36 PM   #3571
haywood's Avatar
Trader Rating: 48 (100%+)
Default 2012
Couple things.
What steering link are guys using to get the servo saver at 90 degrees? Stock one is too long.
Are guys happy with the build of the shocks with the Reflex Racing bladders?
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 08-23-2012, 09:37 PM   #3572
B00t13g's Avatar
Originally Posted by haywood View Post
Couple things.
The stock one for me. The reflex bladders are too big and take too much finagling to get to fit. I prefer the stock ones.
B00t13g is offline   Reply With Quote
Old 08-23-2012, 10:27 PM   #3573
Fred Hubbard's Avatar
Couple things.
Standard camber link. Stick with the stock bladders. I've been using the same bladders for over a year without any issues. The key that I've mentioned several times before is only tighten the cap down until you feel resistance. If you crank the cap down as tight as it will go you will ruin the bladders.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 08-23-2012, 10:56 PM   #3574
Trader Rating: 27 (100%+)
Too big? These ones?
http://www.reflexracing.net/RSD-10mm...ers_p_528.html
I found them 10x easier to use than the stock Xray bladders, and if anything, they're a heck of a lot smaller.
I love them, personally.
hyujmn is offline   Reply With Quote
Old 08-24-2012, 12:21 AM   #3575
malcnz's Avatar
Couple things.
I just built mine with a savox low profile servo and cut down the ends of the link and it ended up the perfect 90 degrees.
and i had some reflex bladders and used them and they fitted perfectly and shocks feel good.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 08-24-2012, 12:23 AM   #3576
B00t13g's Avatar
Yes. They were not good for me.
Old 08-24-2012, 02:23 AM   #3577
Skiddins's Avatar
I found the same. I think it depends a bit on what servo as the output shaft varies slightly from manufacturer to manufacturer.
I cut 1 or 2mm off each end of the link before fitting the rod ends
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-24-2012, 07:26 AM   #3578
M-Technic's Avatar
Trader Rating: 15 (100%+)
I used a shorter link in my box left over from an old Serpent. I am not sure how long it is, but it was a lot shorter than the stock link.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-24-2012, 08:49 AM   #3579
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I like the Reflex bladders much better than the Xray bladders. Come by my room and I'll show you how to build the shock easily with them.
Old 08-25-2012, 08:17 AM   #3580
mbykerman's Avatar
Trader Rating: 45 (100%+)
I have a question. I just got a 12 from a guy but has no servo saver. Can I just use one I had before or should I get the Xray servo saver? Just to be clear it has no servo saver arm.
mbykerman is offline   Reply With Quote
Old 08-25-2012, 08:55 AM   #3581
M-Technic's Avatar
You can use any servo saver, the Xray one is nice though.
Old 08-25-2012, 09:21 AM   #3582
Send a message via AIM to Matt W
Default Chassis nub
Hi,
I know a lot of drivers now stick down the servo or use the centre servo mount but Is there much benifit in cutting off the nub on the side of the chassis or will you not really notice much difference in the handling?
Matt W is offline   Reply With Quote
Old 08-25-2012, 01:01 PM   #3583
Originally Posted by Matt W View Post
Hi,
I dont think you will notice any difference in handling but the chassis nub will rub alot. I cut mine off as I use the centre servo mount and Im fuzzy lol
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 08-25-2012, 01:21 PM   #3584
B00t13g's Avatar
I cut mine off and the lack of rubbing seemed to help with the high speed sweepers.
Old 08-25-2012, 02:34 PM   #3585
mbykerman's Avatar
Thanks for the info on servo saver.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
