Old 08-22-2012, 09:02 PM   #3556
Magnet Top's Avatar
Originally Posted by artwork View Post
Nope sorry...they are in correct. They just do not pivot quite as much as I would like.
Maybe I need to polish my balls, thanks jake!
yeah, and if that does't work I've never run across anything that a little self flagellation couldn't fix !
Magnet Top is offline   Reply With Quote
Old 08-23-2012, 12:55 AM   #3557
RCknight's Avatar
I would like to see some titanium or hard coated aluminum balls. I should have been a machinist. lol
RCknight is offline   Reply With Quote
Old 08-23-2012, 02:28 AM   #3558
Skiddins's Avatar
Originally Posted by Magnet Top View Post
Art,
Are you talking about the lack of *range* of movement of the shock ends or just that they feel bound up ?
If it is that they feel bound up , I polish the balls (did I just say that in public ? ) with 400 grit sandpaper. Specifically I chuck up and spin the ball on a long 3mm screw in my dremel ( or other "rotary" tool ) and use the sandpaper to make the ball nice and shiny. It seems to do the trick.
Jake D.
I do exactly the same, except I use 1200-1500 paper
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-23-2012, 08:48 AM   #3559
artwork's Avatar
Trader Rating: 54 (100%+)
Art,
Jake D.
I am mostly talking about the range of motion...To smooth out the friction issues I have found that Mother's Polish works best, but it is less about the friction and more about the range of motion. I could put some Tamiya shocks on, but I am kind of a stickler about using the parts that were designed for the car in those critical area's such as dampening and the effects on geometry.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 08-23-2012, 11:12 AM   #3560
Trader Rating: 15 (100%+)
Default Movement
Well polishing them wont get you anymore range of motion . You would have to machine the rear shoulder off and then space them away for the tower or shave the outside off the shock top off because it will hit the tower .
AARON YOUNG is offline   Reply With Quote
Old 08-23-2012, 12:00 PM   #3561
Skiddins's Avatar
Surely there isn't that much motion to deal with; a small amount of rotation as the shock extends and is returned, and a small amount of lateral due to caster/anti-dive etc. as the wishbone moves through it's arc.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 08-23-2012, 12:33 PM   #3562
Default Sticky balls
He must be really good to notice the effects of the shock being a little tight . I can hardly tell the difference in shock oils .
Old 08-23-2012, 12:37 PM   #3563
artwork's Avatar
I don't think you need to be so condescending...I did not say I could feel it, I said I don't like it...There is a difference.
Old 08-23-2012, 12:40 PM   #3564
M-Technic's Avatar
If the pivot balls allowed more rotation, I think there would be potential problems with the piston alignment on the clicker/adjustable pistons.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-23-2012, 12:42 PM   #3565
Default Reply
It would be condescending if I put smiley faces or lol after it . I believe with just a period it was a statement .
Old 08-23-2012, 12:45 PM   #3566
artwork's Avatar
People actually use those...? Maybe your right, that seems to make sense!
Old 08-23-2012, 01:51 PM   #3567
Hi guys!
Could some of you explain me how and where to make hole in the shock? Pictures are welcome.
Thank you in advance!
Likeslowww is offline   Reply With Quote
Old 08-23-2012, 02:39 PM   #3568
Trader Rating: 57 (100%+)
Anyone have a pic of a Novak GTB2 installed on one of these? Trying to figure out how to put the electronics on with this mega capacitor.
PROMODVETTE is offline   Reply With Quote
Old 08-23-2012, 02:50 PM   #3569
samnelso's Avatar
Originally Posted by Likeslowww View Post
Hi guys!
There's already a hole in the shock cap if that's what you're referring to. See the shock cap on items 4, 5, and 6 of the below figure.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 08-23-2012, 03:13 PM   #3570
MikeXray's Avatar
Trader Rating: 72 (100%+)
My tip for the small spur and 2nd screw, use needle nose to get the screw into the mount behind the spur, OR use the RW spurs which have bigger holes and can fit a button head 3mm through. (or ream 2 bigger holes in your spur opposite each other).
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
