Old 08-16-2012, 08:18 AM   #3511
artwork's Avatar
Trader Rating: 56 (100%+)
Originally Posted by bvoltz View Post
So let me ask, what would be the results of the following:
Droop 1mm over ride height (ORH)
Droop 2mm ORH?
Just speaking of the effect that these settings would have on the car...2mm ORH would allow the car to roll much deeper then 1mm ORH. Even on carpet I never run less then 1.5mm ORH and outside never under 2mm ORH. I would think 2mm to start both front and rear and then add as needed to either end of the car. If the car pushes off power then go to 2.5mm ORH in the rear and so on...
on a side note...VHT will change considerably as the tempature changes and as such may require some slight changes in the car to accommodation.
Also it is outdoor so tires are 95%...if you do not have a good tire saucing technique then all of the rest really does not matter. You could make changes all day long and never get the car faster if your tires are not being properly prepared. The difference between properly prepared tires and non can be as high as .5-1 sec per lap or more. There is more time in tire prep then in setup once you get close...this I am positive of!
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 08-16-2012, 05:42 PM   #3512
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Originally Posted by ChrisP View Post
There were some restrictions placed on some spammer users withing the past couple days...I will check with the admins to make sure that they didn't accidentally put too broad of a restriction...
i cant get in either its says banned
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 08-17-2012, 02:03 AM   #3513
kinga's Avatar
Trader Rating: 15 (100%+)
The xray instruction manual says to run 6mm and 5mm droop front and rear doesnt it? I have tried 1.5mm and 2mm droop on outdoor asphalt and the car is undrivable. When the grip is up I can drop to 3mm or 4mm droop but needs alot of grip and smooth track.
kinga is offline   Reply With Quote
Old 08-17-2012, 03:42 AM   #3514
elee32's Avatar
Trader Rating: 18 (100%+)
The manual is telling you the settings on droop blocks. I think of droop as a weight transfer thing, more droop = more weight being transfered from front to rear under acceleration, or rear to front when braking or off power. I would think with your situation, med grip and bumpy track, you would want more ride height, not more droop. Check out the ask Paul L thread as the topic of measuring droop has been talked about quite a bit lately.
Hope I'm not totally wrong on this one, but that's how it makes sense in my head
eric
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 08-17-2012, 06:35 AM   #3515
M-Technic's Avatar
Those values from the manual are for droop setup blocks, not values over ride height.
How much droop you can run really depends on your track and traction level. I race on very high traction asphalt and thus I run 1.5-2.5mm over ride height in the rear, and maybe 1mm over ride height in the front most of the time.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-17-2012, 07:02 AM   #3516
bvoltz's Avatar
Trader Rating: 44 (100%+)
Can someone describe how to set Droop over Ride Height?
I have been told you can NOT use tires just off the setup board because of the air gap in the tires. You could use this if you used setup wheels...
Sorry but I'm confused how to do this....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 08-17-2012, 07:08 AM   #3517
M-Technic's Avatar
Use your fingers to put pressure on top of the tires, while also using your thumb and pointer finger to lift up on the shock tower. Then slide a ride height gauge under the chassis again. It's hard to describe but you can do it with one hand.
Old 08-17-2012, 07:11 AM   #3518
bvoltz's Avatar
Could you provide a picture or two? Just asking....
Old 08-17-2012, 07:14 AM   #3519
bvoltz's Avatar
This is what Paul said on his thread...
"That is the way that would be perfect if the tire did not have air gap, when doing it that way you are measuring the tires flex as droop which is why you would end up with very little droop. when saying 2mm's above ride height i refer to the shock travel will allow the chassis to come up 2mm before topping out. you could use your method perfect if you were using set up wheels instead of race tires."
Old 08-17-2012, 07:17 AM   #3520
M-Technic's Avatar
Well I personally measure using droop blocks because it's easier. Doing it the way I described is just quick and easy to see where you are at, so I'm not worried about the air gap. You'd still want to use blocks to make sure your droop is the same on the left and right side of the car.
Old 08-17-2012, 07:21 AM   #3521
bvoltz's Avatar
But how do you translate 2mm over ride height to the Droop blocks?
Old 08-17-2012, 08:03 AM   #3522
M-Technic's Avatar
There is no easy way, because 2mm over ride height on a car with 5mm of ride height is going to measure different on the droop blocks than a car with 2mm over ride height on a car with 6mm ride height.
Old 08-17-2012, 08:19 AM   #3523
MikeXray's Avatar
Trader Rating: 72 (100%+)
Shouldn't blocks - RH + droop work? Say 10mm blocks - 5.5 + 2mm = 6.5 on the blocks
If you raise the car .5mm with no change in droop, it would be 6 on the blocks.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-17-2012, 08:59 AM   #3524
bvoltz's Avatar
When I tried that... it do not work out that way... I think the key is what Paul said... Shock movement is the key... But I need to figure this out.... Most talk in ORH and I prefer the blocks.
Old 08-17-2012, 01:31 PM   #3525
barnacle's Avatar
Just use the droop blocks to make sure that both the left and right sides are even then switch to the other end of the car and do the same thing.
Notate what the droop block settings were so you can duplicate it again and put on a setup sheet if u need to.
Don't over think the process.
Set your ride height, set your "over ride height" setting, check it with droop blocks, and then your done.
Mike Dobbs
Race Opt MTS T'2
WWW.DISCHARGERC.COM
U.S. DISTRIBUTOR FOR RACE OPT BRAND
barnacle is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
