Old 11-08-2011, 09:41 AM   #331
millbank's Avatar
I was hoping for some set up advice on here but it looks like someone copied and pasted the first 20 pages from the t3'11 thread.. Lmao
I want alu shocks.....
I run Alu shocks and plastic shocks and don't have a problem with either.
Xray make a quality product that lasts. Still winning with my t2 009 and my t3'11's not bad either. Got my 12 last week and am looking forward to building it.
I will return for some set up advise when the threads a bit older
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 11-08-2011, 10:29 AM   #332
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Default 2 cents
Originally Posted by Mera'din View Post
So, what is the benefit of the new bulkhead clamps? What effect on driving do they have?
from discussions and past cars i've owned compared to Xray.
the bulkhead clamps provide a bit more fine tuning for roll center adjustments.
-shim up down
-extend or lengthen the link itself.
etc..etc.
should make finding the right setup for your driving style a bit more easier.
Xray Setup book: page 25 is my reference point
http://www.teamxray.com/teamxray/pro...=3989&catName=
I am converting my '2011 to a 2012 ...my parts are on their way....can't wait to get it all.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 11-08-2011, 12:11 PM   #333
Default Bulkhead Clamps
I race on really high bite asphalt and was never really able to get enough steering with the Factory Xray Clamps because like others I could not go low enough on the inside camber link. I used the Max Carbon Clamps and was able to increase aggression and steering.
With the new updates to the 2012 has anyone experienced the car working better because of the changes and/or did they change the clamps at all lowering the mounting position. I will probably hold on to my max carbon clamps and not sell them with my 2011 if the car does not work better with the Factory Clamps.
West Coast RC Raceway / TQ Raceway
TRESFR is offline   Reply With Quote
Old 11-08-2011, 12:36 PM   #334
orci77's Avatar
Default Multi-Diff LiPo
Has anybody experience with the Multi-Diff LiPo which came out with the T3'011?
On the Xray site there is no information if you can run it with the 52mm drive shaft. The old Multi-Diff could only be run with 50mm drive shafts.
Xray T3'012 + Nosram Pearl SpecRacing V2 + LRP X12 17,5T / X11 9,5T / X11 6,5T
Team Associated SC10 + Nosram Matrix Reverse + LRP X11 13,5T
3Racing F1-09 + LRP Sphere + LRP X11 17,5T
orci77 is offline   Reply With Quote
Old 11-08-2011, 02:20 PM   #335
M-Technic's Avatar
Trader Rating: 15 (100%+)
There was some discussion earlier in this thread that the clamps are the same as the original option parts for the 2011.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-08-2011, 02:34 PM   #336
theatriks's Avatar
hey guys kinda a newbie to xray and just wondering if im ordering uprites and c clamps and what not for my t3 2012 are they the same uprites that sites have listed under the t3 2011
theatriks is offline   Reply With Quote
Old 11-08-2011, 02:45 PM   #337
olhipster1's Avatar
yes I believe it's a carry over.
anyone else please confirm.
I believe the Xray site/shop parts listing will show compatible parts.
CAUSE and EFFECT
Old 11-08-2011, 02:51 PM   #338
syndr0me's Avatar
Trader Rating: 32 (100%+)
Is there a definitive list somewhere of the parts needed to convert an 11 to a 12?
syndr0me is offline   Reply With Quote
Old 11-08-2011, 02:53 PM   #339
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I would say look at the manuals and illustrated parts breakdowns.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 11-08-2011, 07:31 PM   #340
miccal's Avatar
Trader Rating: 23 (100%+)
Here you go:
Originally Posted by miccal View Post
Main new parts compared to T3-11:
301132 T3-12 chassis
303087 T3-12 shock tower rear
302086 T3-12 shock tower front
301193 T3-12 upper deck
302526 Composite dual servo saver arm
372503 Composite servo saver X-stiff
302253 Composite steering block hard
along with gear diff, upper clamps, open ball joints and pivot balls, and of course different turnbuckles for the servo link.
miccal is offline   Reply With Quote
Old 11-08-2011, 08:31 PM   #341
Got mine today, over here on the EASTCOAST.
Serpent Lover is offline   Reply With Quote
Old 11-09-2011, 05:26 AM   #342
theatriks's Avatar
Mine came in today ....ottawa canada.....cant wait to get this baby pieced together..
Old 11-09-2011, 06:00 AM   #343
NR
NR's Avatar
Trader Rating: 52 (100%+)
Default Servo Saver
Ok perhaps I'm doing something wrong, But I cant seem to work the servo saver out, am I supposed to put all 4 springs in their? As it feels incredibly tight and hard to get in.
Besides that I'm loving the build thus far.
Nathan
NR is offline   Reply With Quote
Old 11-09-2011, 06:49 AM   #344
Skiddins's Avatar
Nathan
Yes, you should be putting all the U shaped springs in.
Just make sure you do them in order.
They need to be tight to do their job without slack etc during heavy cornering.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-09-2011, 06:54 AM   #345
Nathan
I found the manual wrong for this bit, the way i did it was to clip all the plastic parts together first, then insert as appropiate the 4 u shaped clips (as skiddins says this needs to be in the correct order smallest to largest
Not sure if the above makes sense, let us know via return if this works better for you
Run the car for the first time at the weekend and the servo saver done its job so i cant have been too wrong with the build of this part
Bony85 is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
