Old 08-05-2012, 04:22 PM   #3391
Anyone got a new or lightly used xray t3'12 bottom chassis I can buy?
ChampRC is offline   Reply With Quote
Old 08-05-2012, 04:43 PM   #3392
RCknight's Avatar
Problem solved, yes I can see those shims will make it much easier. Thanks for the tip, I'll give them a try. I never had an issue with the single post design, but I always ran carpet and used a center post.
The car seems to be continued development for asphalt racing, I hope we carpet guys are not left in the dust and we will see some option parts to make it stiffer. Since the center post seems to have gone MIA, I hope to see something like the carbon fiber steering brace much like the 417.
I guess my only request would still be pivot ball toe blocks and a solid motor mount. I'm looking forward to building this car come fall.
How did the new car perform at the worlds? I read a lot about the luck factor, but it appears many of the drivers didn't do well. Anyone out there get to see what happened first hand? Just wondering if the short shock system didn't work out so well or if there were other problems.
Originally Posted by Skiddins View Post
Like this;
I'm afraid RCKnight, your request will fall on deaf ears. Although quicker to adjust it was not a great design and as mentioned, used to pop out in heavy crashes.
Skiddins
RCknight is offline   Reply With Quote
Old 08-06-2012, 03:29 AM   #3393
Stusdal's Avatar
Watched it on liverc.com.
The not making the a-main was mainly tire strategy gone wrong, with the weather messing it up. With that saind they seemd to be lacking some pace, and i think at best they would have ended in the lower a-main at qualy.
Hagberg and Pauls cars seemd very good in their finals, putting on some entertaining runs. Paul from far back on the grid.
Serpent || Futaba || Protoform || Orca || GensACE || Sorex ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 08-06-2012, 04:39 AM   #3394
nerdling's Avatar
Like this;
Skiddins
That is awsome.... I've wasted so much time changing the ackerman setting.... till now.
Simple solution, thanks Skiddins
ACT EP10 & EP12 ONR Titles, February 26th to 29thth 2016.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
http://www.rcracedatesaustralia.com/
nerdling is offline   Reply With Quote
Old 08-06-2012, 04:42 AM   #3395
Hagbergs final time was one second off jilles and hara's time.. so their pace was very good. The only reason they didnt make A-main is cause they had the wrong tyre strategy for qualifying.
JanE is offline   Reply With Quote
Old 08-06-2012, 06:40 AM   #3396
kinga's Avatar
Trader Rating: 15 (100%+)
Originally Posted by andrewdoherty View Post
I'm using RSD bladdders, no foam, 1.1 mm 3 hole, hole in cap, 450/600 2.6/3.0
What track conditions u using that on? Seems like high traction configuration
kinga is offline   Reply With Quote
Old 08-06-2012, 12:10 PM   #3397
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Low to medium grip carpet.
Old 08-06-2012, 04:36 PM   #3398
nashrcracer's Avatar
R/C Tech Charter Subscriber
paul actually started 10th in the "B" and won 2 of the triple mains. I don't think his car was lacking anything with short shocks or not. he did have 2 different cars there that he was trying in open practice before the control practice and yes the rain screwed several including myself. I rode back and forth to the hotel with him and he was happy with the car that he used as it was slightly fast to drive then the other. not sure what the differences were other then shock oil for sure.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 08-06-2012, 05:40 PM   #3399
I know this issue has been beaten to a pulp, but I'm getting frustrated and out of solutions...
I've switched right components with left components including rear hubs, arms, suspension holders, 1.50mm washers, switched entire suspension, switched what hudy device used, wheel hexes, I even bought the one piece front rear suspension holder....everything I tried end up with 2 degrees toe on the left and the right will vary from 3.1 to 4 degrees. I've taken everything apart and rebuilt/rescrewed....
Whenever I use a washer on the left to compensate, the right just increases. I put in a washer almost double the size apprx 3mm on the left and finally got 3 degrees, but then the right was at 4 degrees.
I spent half a grand on this car and this issue is making me really question my decision.
In my past experience I notice a great difference in driving with even rear toe than uneven...so I'm not just OCD, this thing drives like garbage with the toe being 1 degree different and I'm not that good of a driver to drive it like this....
Old 08-06-2012, 05:52 PM   #3400
artwork's Avatar
Trader Rating: 54 (100%+)
Have you taken off the bulkeds and checked to make sure they are still straight? Have you stripped everything off of the car and tried to rebuild it from scratch starting with the rear of the car? Have you replaced all suspension components on the rear of the car? Do you have a bent hing pin or suspension mount? I could go on for days...
Seriously, in these situations you have to just tear the car down and put it back together piece by piece checking between each step to find the part with the problem. You will find it...but you have to be thorough.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is online now   Reply With Quote
Old 08-06-2012, 05:56 PM   #3401
silvalis's Avatar
Trader Rating: 29 (100%+)
how does putting a spacer on the left affect the right arm?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 08-06-2012, 06:09 PM   #3402
Unhappy Perplexed
Anyone know the answer to this....I mean is this even supposed to happen at all?
Old 08-06-2012, 07:15 PM   #3403
Trader Rating: 38 (100%+)
It can't. You must be doing something wrong.
or8ital is offline   Reply With Quote
Old 08-06-2012, 07:18 PM   #3404
Is the issue perhaps the method/tool you are using to measure toe and not the car?
Old 08-06-2012, 08:03 PM   #3405
NolanP's Avatar
Yeah I would go over the car tooth and nail. Go through it via the owners manual step by step. Something has to be off cause I can adjust one side and have the other stay the same. Ie zero toe on the left 3 degrees on the right.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
