Old 08-04-2012, 02:55 AM   #3376
Skiddins's Avatar
Originally Posted by moggy12 View Post
thanks for info do you think going to 30 weight shock oil in the rear would help ?
I do tend to run soft shocks, 400 oil in alloy shocks with 3x1.1 pistons. But I do it at both ends.
Mine's the car from 2nd, dark bluey purple colour with what looks like a yellow front in the video (10th after the second corner as I rolled it)
+ YouTube Video
The setup for that night, additive was full front and rear, both for around 20 mins, which is what I do from practice onwards all night; http://piez0r.com/Skiddins/Xray%20Setup%20Sheets/Carpet%20Setups/t3'12-Newbury(F)-27-7-12.pdf
My car is a bit aggressive but it doesn't tend to over rotate, I also run some drag brake.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-04-2012, 03:49 AM   #3377
+ YouTube Video
thanks for the set up sheet nice driving car seemed planted
rc12r5.1
moggy12 is offline   Reply With Quote
Old 08-04-2012, 07:45 AM   #3378
narcotiks's Avatar
With the pinion Off, my car is making a squeezing noise in the drivetrain ne'er the layshaft mount, any ideas what it could be ?
narcotiks is offline   Reply With Quote
Old 08-04-2012, 07:51 AM   #3379
NolanP's Avatar
check tension on the two screws that hold down the layshaft....then check then bearings and the actual shaft.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 08-04-2012, 08:44 PM   #3380
RCknight's Avatar
Xray please consider redesigning the center piece of your steering rack? Something with a stair step two pieces design much like your older single post design. That way we can make ackerman changes on the fly and the steering link will be more inline to the servo horn. That's one thing I loved about your past design. Then this will not be a carbon copy of your competitors.
Originally Posted by andrewdoherty View Post
RCknight is offline   Reply With Quote
Old 08-04-2012, 11:35 PM   #3381
Trader Rating: 15 (100%+)
Default Ackerman
If you are having a problem adjusting Ackerman buy the a plus shims you drop them in and go just as easy as the old style and won't break. Every car that I know of that had the adjustable center steering it was a weak point.
AARON YOUNG is offline   Reply With Quote
Old 08-05-2012, 01:58 AM   #3382
kinga's Avatar
The steering design was the worst thing about the t3, that center single peice steering design was horrible, and would cause the steering rack to pop out of the cups in a heavy crash unless you had the center stiffening post in.
If it rears its head again it will need to be substantially re-designed.
kinga is offline   Reply With Quote
Old 08-05-2012, 05:41 AM   #3383
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Originally Posted by RCknight View Post
That way we can make ackerman changes on the fly...
Remove the bumper. (Three screws)
From the front of the car you can get your tools into the steering area to remove the ackerman washers.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 08-05-2012, 06:06 AM   #3384
Default Front
You don't even take the bumper off . Use a 2.0 mm ball end driver loose the ball studs one or two turns drop In the shim or pull one out and tighten .
Old 08-05-2012, 06:33 AM   #3385
Trader Rating: 55 (100%+)
where do you get these ackerman shims?
Jamison R is offline   Reply With Quote
Old 08-05-2012, 08:32 AM   #3386
syndr0me's Avatar
Trader Rating: 32 (100%+)
Behold...
syndr0me is offline   Reply With Quote
Old 08-05-2012, 09:52 AM   #3387
Trader Rating: 38 (100%+)
I have a dilemma. I'm not going to be able to race for the next couple months. Do I sell the car now and hope that the new one comes out around the time or hold on to it. New cars usually come out in Oct? Is that correct?
or8ital is offline   Reply With Quote
Old 08-05-2012, 11:46 AM   #3388
Skiddins's Avatar
Snowy.
Like this;
I'm afraid RCKnight, your request will fall on deaf ears. Although quicker to adjust it was not a great design and as mentioned, used to pop out in heavy crashes.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 08-05-2012, 01:41 PM   #3389
Dusttt's Avatar
Trader Rating: 123 (100%+)
What set up is everyone using with the aluminum X-ray shocks? Foam,bladder,oil,spring?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 08-05-2012, 02:35 PM   #3390
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'm using RSD bladdders, no foam, 1.1 mm 3 hole, hole in cap, 450/600 2.6/3.0
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
