Old 08-03-2012, 02:51 AM   #3361
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by rack View Post
I know the asker is have some where but here is go again. I want to run mod I have a 5.5 motor and I need to know were to start with pinion and spur gear.
On our 90x40' indoor carpet I am at 116/27 with a 5.5 and no esc timing. My motor and esc have been coming off cool, although I am pretty sure I could get a bit more oomph if I geared up a little.
Old 08-03-2012, 03:43 AM   #3362
Skiddins's Avatar
Originally Posted by moggy12 View Post
i put additive on at least for 1/2 hr before first race full on front and rear tyres i did try to put only half on front but found first heat was getting less grip from front tyres due to getting marbles on the one side of tyres after the first heat i use full on rear and half on fronts
Perhaps, try full rears for the 1/2hr, but full fronts for only 10mins.
The fact that you say the car is great after a few runs suggests you want to make the bare minimum of changes. Perhaps try standing the rear shocks up a bit more early on.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-03-2012, 04:34 AM   #3363
Trader Rating: 38 (100%+)
hi i race on indoor carpet set up is xray carpet setup apart from 40 weight shock oil f+r ,rear shock on inner most setting 5.5mm ride height the problem is first 2 rounds i just don't have any rear grip i know you get more grip from more rubber being put down but would like more rear grip from round 1 by round 3/4 car is well set up with plenty rear grip is there anything i can change on car to get intant rear grip from round 1 ? i use sorex 28 jb tyres thanks
I've been struggling with rear grip lately as well. Some things I've tried with some success:
- only dope 2/3 of front tires
- add 1mm rear wheel spacers
or8ital is offline   Reply With Quote
Old 08-03-2012, 05:32 AM   #3364
MikeXray's Avatar
Trader Rating: 73 (100%+)
Experiment with taking or moving screws from the top deck, also shock position is an easy change to work with throughout the day. (which end to change and how much can vary depending on at what point in the corner the car is breaking loose).
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-03-2012, 08:10 AM   #3365
Meradin's Avatar
Trader Rating: 19 (100%+)
My car is breaking loose mid corner under power. What changes can I make?
I am running...
2 rear camber
3 toe in rear
1 toe out in front
1.5 camber in front
Middle upper link holes front and rear with 1mm spacer
Mid roll centers
Middle shock position up front
Down one shock hole in rear
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 08-03-2012, 08:23 AM   #3366
Trader Rating: 55 (100%+)
Move front shock out 1 hole and go to 1 degree camber in front.
Jamison R is offline   Reply With Quote
Old 08-03-2012, 08:24 AM   #3367
Also what is your droop setting?
Old 08-03-2012, 09:24 AM   #3368
Meradin's Avatar
I am running 3mm over ride height in the front and 2 in the rear.
Old 08-03-2012, 09:27 AM   #3369
What tires are you running on what surface? Also how do you prep your rites?
Old 08-03-2012, 10:31 AM   #3370
rack's Avatar
Trader Rating: 64 (100%+)
thank you
rack is offline   Reply With Quote
Old 08-03-2012, 10:32 AM   #3371
rack's Avatar
Originally Posted by R3VoLuTiOn View Post
116 spur and 32 pinion blinky, mess with the timing after that
thank you yal gave me a start
Old 08-03-2012, 03:34 PM   #3372
In case anybody is interested in a spare car..
Xray T3'12
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 08-03-2012, 08:47 PM   #3373
Skiddins
thanks for info do you think going to 30 weight shock oil in the rear would help ?
rc12r5.1
moggy12 is offline   Reply With Quote
Old 08-03-2012, 11:40 PM   #3374
Danny-b23's Avatar
I think in your situation it would actually make it more tail-happy. It would allow the weight to transfer side to side too quickly and overload your tires even more; which sounds like what is happening. I would look at your downstop settings. Maybe try giving the car less rear uptravel to limit the weight transfer a bit.
Cheers
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 08-04-2012, 12:20 AM   #3375
Or you could try a little anti-squat, allows you to put the power down a little sooner.
Bb
bucketboy is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
