Old 07-31-2012, 01:25 PM   #3331
Trader Rating: 15 (100%+)
Default Exotek
The X-ray chassis wouldn't have the option of split blocks and holes to mount them like the exotek . The stock X-ray ones tweak with the one hole and post setup and can rip out of the chassis .
AARON YOUNG is offline   Reply With Quote
Old 07-31-2012, 01:46 PM   #3332
syndr0me's Avatar
Trader Rating: 32 (100%+)
I guess i'm just looking for some that use the existing hole pattern but are machined to accept pillow ball. Is there something keeping that from working? Maybe you lose the option of split blocks? Is that what CSO is offering there?
The Exotek solution seems like it was designed to just re-use their Tamiya blocks. Which I guess is okay, but I didn't want to change the chassis of my car. I just wanted the option of running toe blocks because I find them to be easier to work on. I'm not interested in any geometry changes.
syndr0me is offline   Reply With Quote
Old 07-31-2012, 03:07 PM   #3333
Default Cso
The cso ones mount in the stock holes . But the tolerances are fairly poor there is side play within the ball and mount and no way to shim out the play . Best way is to use heavy grease or the tamiya anti wear stuff to limit the play
Old 07-31-2012, 06:13 PM   #3334
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
I am running a t3 11 chassis using serpent ff and fr blocks and a serpent rr block then I ordered the exotek split blocks for the rf. It has been 3 weeks and the car is really good. I think I had to do minimal shaving of the fr holes to fit the serpent block. I did move the rf exotek blocks forward for clearance.
It was really just a fun project at first but the results have been good. here are a couple pics
Xray T3 2012-imag0184.jpg   Xray T3 2012-imag0222.jpg   Xray T3 2012-imag0223.jpg
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 07-31-2012, 09:28 PM   #3335
RCknight's Avatar
I want a pillow ball conversion that works with XRay's existing chassis.
AMEN! +1
RCknight is offline   Reply With Quote
Old 07-31-2012, 09:38 PM   #3336
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by artwork View Post
Anyone find a better shock bladders for these shocks yet...The Tamiya ones don't fit very well and the stock bladders are way too soft. I heard a while back that the reflex bladders fit, but not sure.
The Tamiya ones fit OK but you have to put them in the cap instead of on top of the body like the xray ones. A little tricker to bleed. Reflex makes them that fit the Xray now and are very very good Ive heard! I know all the AE cars around here and AE Drivers run their bladders.
The bladders are something that has been changed on the proto car too. So they are not so soft, tear and they actually work.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-31-2012, 09:49 PM   #3337
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
EA
+1
The reflex bladders are awesome in the Xray shocks. I haven't torn one since I started using them in my mod sedans 2-3 months ago. When they are brand new you can put them into the shock, and then put the cap assembly on top, but I prefer to put the bladder in the cap after I have used them once. ~$1 each is a nice reprieve from the Xrays as well.
Old 07-31-2012, 09:58 PM   #3338
hotrod1933's Avatar
Default servo saver or not
what are the pro's and con's of running a servo saver.
have a t3-11 and 12 and was swapping parts to get one ready for racing and swapped from one car (not run yet secondhand) to the other.
got to the track and no steering near centre. swapped to solid arm and all good. my bad did not have other saver with me.
only run 21.5 blinky and still learning.
not sure if running without a saver is too hard on servo i would assume it is if you hit stuff. if the saver is good what is the harm or running them.
car felt fine with original saver fitted second one must be bad.
XRAY T4-15 -- nbhc.com -- powerhouse performance -- sma.org
hotrod1933 is offline   Reply With Quote
Old 07-31-2012, 09:59 PM   #3339
nerdling's Avatar
Why?
The original T1 and T1 Evo had pillow ball suspension. The FOC then came out with both C hub and pillow ball, then pillow ball was dropped in favor of the lighter, simpler and easer to live with C-Hub suspension.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 07-31-2012, 10:10 PM   #3340
He's talking about the pivot balls on the inner hinge pins.
Old 07-31-2012, 10:11 PM   #3341
nerdling's Avatar
The servo saver is designed to absorb impacts rather than trasnfering them directly to the servo. If you take a hit to the front end the servo saver should protect your servo and steering componets from damage.
The down side to a servo saver is that it can introduce an in accruate feeling in the steering and they are weigh more and are bulky when compared to a straight arm.
Comes down to a risk assesment, if you don't hit things often, and when you do your steering will not break then run an arm.
Old 07-31-2012, 10:14 PM   #3342
syndr0me's Avatar
Yep. Is pillow ball not the right verbiage?
Old 07-31-2012, 11:20 PM   #3343
I may not be right, but here's my understanding.
Pillow ball
Pivot ball
Old 07-31-2012, 11:33 PM   #3344
Any news about new car from xray?
Zooberg is offline   Reply With Quote
Old 07-31-2012, 11:50 PM   #3345
Like what he said, I would never run without one, never had a centre point steering issue. I always mod the sero saver so that the link is closer to the centre, slows the steering a little but gives more torque and better feel.
Bb
bucketboy is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
