Xray T3 2012
#3182
I was wondering about the rear front suspension holder that some have mentioned to deal with the unequal rear toe issue on the T3'12.
I hear it reduces rear grip...
Has anyone tried it and had sucess in getting that rear grip back?
Does removing the screws closer to the spur gear on the rear end of the top deck negate the loss of rear grip?
#3186
#3189
plz help!
I removed the washers and see that I have exactly 1 deg on the right and 0 deg on the left.
I loosened the screws on the bottom then rescrewed, same problem.
What can be the issue?
#3190
So I got around to installing the one piece and still have a 1 degree rear toe discrepancy.
#3191
#3192
#3193
I got 3 more summer races then its back to carpet what chassis should i get for carpet?
#3194
#3195
64p pinion gear to fit T3. Having a hard time finding a 46t and 48t 64p pinion in stock by PRS so i tried a Team epic. The Team epic is a little wider than the PRS's and its extremely close to top deck and belt. Not a big fan robinson racing pinions, does anybody have a suggestion. Haven't tried xray's so i'm not sure if they are worth $15 dollars or so.
thanks for any suggestion
idbdoug
idbdoug
