Old 07-11-2012, 02:00 PM   #3136
Send a message via AIM to Matt W
Originally Posted by COLD AS ICE View Post
Personally I found that certain tires like rotation, some dont. Between the ones that do, they can go different ways. I found for tires such as Solaris Hards you criss-cross them, so move front left to the right rear and right rear to the left front, do the same with the front right and left rear. This seems to make them last a good bit longer, but be careful on the first 2 or 3 laps, they can be wierd. For sweeps, such as 32's or 36's they like side to side. Not sure on Jaco's as our LHS doesnt stock them. These are my personal findings so if others want to say something as well it may be best to get more opinions and findings
Im running sorex 28's jb and sweep 30's exp!
Matt W is offline   Reply With Quote
Old 07-11-2012, 02:18 PM   #3137
Trader Rating: 19 (100%+)
For the sweeps i would say change them side to side. Not to sure on Sorex as i 've never ran them.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 07-11-2012, 03:55 PM   #3138
theatriks's Avatar
Hey guys quick question at my track last week the fastest guy was running an xray and i noticed inbetween heats his mechanic was dremeling out some of the excess plastic from the suspension arms.....does this allow the car to turn in with more speed because the arms flex a bit more?
theatriks is offline   Reply With Quote
Old 07-11-2012, 07:55 PM   #3139
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I've noticed in on my T3 in Mod that the front wheels can rub ever so slightly on the front of the arms where they flex in high speed corners. My guess is he was dremeling to provide clearance?
Old 07-11-2012, 07:58 PM   #3140
Originally Posted by rcgerber View Post
Are the Spec Rs 52mm or 50mm?
I know the original ones were 50 mm, and I had lots of success with them. Does anyone know if the V2 Spec-R's are 52 mm? If not I think RSD is considering/going to make 52 mm Xray ecs drives.
Old 07-11-2012, 08:31 PM   #3141
Trader Rating: 20 (100%+)
I casually measured the Spec-R shafts when I was replacing the stock 52mm shafts and I think they were actually about 51.2mm. Seriously. I measured from drive pin to wheel pin and subtracted the difference and although I don't think I was 100% accurate because I was just curious I did use a nice caliper.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 07-11-2012, 08:39 PM   #3142
I was told or read somewhere that they are about 51mm long, same with the Aeromax shafts, but everyone says that Spec-r V2's are the way to go
★Randy Banks★
Old 07-12-2012, 12:36 AM   #3143
narcotiks's Avatar
any body used this chassis?http://rcmarket.com.hk/product_info....ducts_id=13424
narcotiks is offline   Reply With Quote
Old 07-12-2012, 06:04 AM   #3144
theatriks's Avatar
No he was dremeling out the in side part of the arm where the plastic is recessed a bit he drilled it rite out ...im surprised nobody knows why they do this ?...i guess thats why the fast guys are the fast guys.
Old 07-12-2012, 06:48 AM   #3145
Thanks everyone. I might just have to pick up a set.
rcgerber is offline   Reply With Quote
Old 07-12-2012, 06:57 AM   #3146
M-Technic's Avatar
Trader Rating: 15 (100%+)
It sounds like they were doing it to get more arm flex, but I don't think that's very common to do on modern touring cars. What kind of surface do you race on? It could help with mechanical grip on low traction surfaces, but I know it would hurt your corner speed on all of the tracks we race on in Florida that have at least moderate traction.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-12-2012, 07:12 AM   #3147
Espo's Avatar
Custom adjustable top plate
R/CAmerica, Hudy, X-Ray, Trinity, Protoform, Speed Passion, Matrix Tires, Laser Products Industries, Leisure Hours Hobbies.........
Espo is offline   Reply With Quote
Old 07-12-2012, 07:15 AM   #3148
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Espo View Post
Attachment 946016
Didn't you just remove all torsional flex from the top deck with that?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-12-2012, 07:24 AM   #3149
defcone's Avatar
Attachment 946016
That looks intense, does it generate too much grip?
defcone is offline   Reply With Quote
Old 07-12-2012, 07:26 AM   #3150
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Attachment 946016
That Dieter's car hes been running or your car Espo?
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
