Old 06-23-2012, 07:09 AM   #2881
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by or8ital View Post
Why not just use a narrower hex? Would it not be the same net result?
A lot is different when you narrow the block when compared to a narrower hex, even if not by much(dependant on how much you grind off).
defcone is offline   Reply With Quote
Old 06-23-2012, 07:31 AM   #2882
Skiddins's Avatar
Not quite, when you remove material from the blocks you are changing the suspension geometry as well as the width.
The wishbone position, upper link length & roll centre etc will all change.
Changing the hexes only changes the roll centre.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-23-2012, 08:20 AM   #2883
pchroma24's Avatar
Trader Rating: 73 (100%+)
Not exactly, when the upper camber link is run in position 1 (outters most, closest to wheel) , as most of Hagbergs setups indicate, it will make the upper link abit shorter, which then makes camber rise abit quicker... It's a geometry change not so much a track width adjustment... Hope it helps...
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 06-23-2012, 08:57 AM   #2884
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
won't running the camber link in it's outermost position (closest to wheel) make it longer ?
Do you mean after the mod it will become shorter than before the mod creating the quick camber gain.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 06-23-2012, 09:14 AM   #2885
pchroma24's Avatar
Apologies for the confusion... I was meaning the inner mounting on the bulkhead closest to the wheel, should be position 1? (Not in front of a setup sheet, LOL) ,... You'd maintain the inner mounting on the hub as well... Making the link as short as possible
Old 06-24-2012, 06:59 AM   #2886
NolanP's Avatar
How wide or narrow are you running your front end?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 06-24-2012, 06:22 PM   #2887
elee32's Avatar
Trader Rating: 18 (100%+)
May have been brought up already but, are there any advantages to running 50mm driveshafts in the rear?
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 06-24-2012, 07:57 PM   #2888
NolanP's Avatar
Yes you can narrow the rear end which will help the car come around the corner. It will make it less stable though.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 06-25-2012, 12:30 AM   #2889
kinga's Avatar
Originally Posted by silvalis View Post
This mod makes the rear of the car quite a lot narrower which results in more turn-in and mid corner rotation. The car will be more aggressive and difficult to drive but faster for some conditions.
http://hagberg.blogs.se/2012/01/18/r...tion-12479898/
Rather than hacking up your susp blocks, you can use these holders
http://rcmarket.com.hk/product_info....ducts_id=13037
That way you can use low, mid or high susp blocks without hacking them up.
I tested these today and they work a treat, it is only a .5mm thinner though, but the benefit is it is reversible side to side, so you can run in the -0.5 configuration (1mm total trackwidth reduction) or in the normal configuration.
The other benefit is you can use the separate rear-front suspention holders that you remove from the rear, in the front-rear position instead of the one peice holder, and increase steering at the same time and make front belt changes much easier
kinga is offline   Reply With Quote
Old 06-25-2012, 07:45 AM   #2890
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'd sure like to see an option like that from XRay. It gets us that much closer to toe blocks though, I guess.
syndr0me is offline   Reply With Quote
Old 06-25-2012, 07:50 AM   #2891
Chrissy C's Avatar
Syndr0me, if those adjustments float your boat then the Exotek chassis conversion set allows you to use different toe blocks so that you can alter the track width.
There is another thread on here specifically for it where the widths of blocks etc are listed.
Chrissy C is offline   Reply With Quote
Old 06-25-2012, 08:11 AM   #2892
M-Technic's Avatar
If they could make those out of the same molded plastic, it would be a lot cheaper than stocking a bunch of different toe block widths like I had to when I ran Tamiya.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-25-2012, 09:37 AM   #2893
what is the preferred low traction asphalt chassis combo? I have been running on low traction tight tracks with the VBC flex and it did not take the basic asphalt setup with positive results. I have it pretty dialed now. what is preferred the 2.0 xray, the exotek, vbc or other
Team Waldorf Racing
Old 06-25-2012, 10:21 AM   #2894
If you put the seperate suspension holders in in the front -rear position you better order some replacement chassis....
nevergiveup is offline   Reply With Quote
Old 06-25-2012, 04:53 PM   #2895
NolanP's Avatar
I personally would rather just mill them down myself and know they are correct and be able to run any of the adjustable blocks vs just the one set.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
