Old 06-13-2012, 10:39 AM   #2821
Magnet Top's Avatar
Cool, thanks for the replies !
Magnet Top is offline   Reply With Quote
Old 06-13-2012, 10:40 AM   #2822
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Magnet Top View Post
I should have clarified, I'm using the exotek conversion ....
So Defcone , you are implying you notice a difference of added rear traction without the screw or were you just making a general statement ?
Just a general statement, do you find the car tends to be too "stuck" in the rear end with the exotek conversion? It seems that there are only cutouts in the rear, I myself like the car with kit chassis, cso-made tamiya style blocks in the rear and a mixture of tamiya split block and serpent block up front. Seems to give the best balance of steering and grip.
defcone is offline   Reply With Quote
Old 06-13-2012, 11:16 AM   #2823
Magnet Top's Avatar
Honestly, the question about that motor mount screw has been lingering in my " noggin" for as long as X-ray had that "option". I've owned just about every T3 but tried something else for a bit and just got the '12. I always left that screw out but mostly ran stock classes. When I ran mod my cars tended to be noisy, so I always wondered about the gear mesh and that mount but never tested it back to back. The T3'12 with that screw the mesh is perfect and sounds great...
I only used the stock 2.5mm chassis for one day, then threw the Exotek on it for the Reedy in 17.5 with spec tires , then came home and ran mod with it twice on Sorex, so I'm just getting up to speed with an Xray again and working on a setup but far too many variables to make conclusions. So, in an attempt to answer your question , generally, I'd say my car pushes initially, but is loose middle of the corner on power, and lacks steering on high speed sweepers. So yes, I probably have too much rear grip as you suggest. It could be simply droop and weight bias needs to move forward that will dramatically change the car.... so Basically, I don't have enough time into it to make any assertions as to exotek vs 2.0, vs 2.5mm chassis but generally I'd agree with what you suggest about having more than enough rear grip.
I actually have the CSO blocks already, just hadn't tried them since I went the Exotek route but I may try the stock chassis again with the CSO blocks. If you could pm me more details about your use of serpent blocks.. etc, I'd appreciate it.
Cheers,
Jake D.
Old 06-13-2012, 11:27 AM   #2824
artwork's Avatar
Trader Rating: 56 (100%+)
The removal of top deck screws in the rear is an interesting change in the feel of the car. Although, I think it does tend to allow the car to twist and roll more in the rear I also found that it makes the car a little bit more inconsistent. I think the car is more predictable with the screws in and making other changes in the car to help the car generate from rear grip if needed. A more consistent car tends to help me be more consistent lap after lap and that is what I am trying to achieve in setup. Winning the fast lap game usually ends in tears.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 06-14-2012, 10:48 AM   #2825
Dusttt's Avatar
Trader Rating: 118 (100%+)
so what is the hot setup for the shocks? Are most running the older bladders and the vented top still?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 06-14-2012, 11:01 AM   #2826
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I prefer the RSD bladders, no foam, and the vented caps. The std low bladders work just as well, but I found them to tear more easily.
Old 06-14-2012, 11:36 AM   #2827
NolanP's Avatar
Personally I'm running the 2012 shocks with the fixed 3 hole pistons or the fixed 4 hole pistons. I am not having any issues so far.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 06-14-2012, 12:24 PM   #2828
M-Technic's Avatar
I love the shocks with the adjustable pistons, and the stock low bladder with no foam and a vent hole in the cap.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-14-2012, 02:52 PM   #2829
Dusttt's Avatar
RSD Bladders?
And Thanks guys
Old 06-14-2012, 04:29 PM   #2830
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Tried an XR3'12 at our test facility (street), seemed sharper than T3'12 with similar set up,
will give it a go at the track tonight
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 06-14-2012, 05:02 PM   #2831
elee32's Avatar
Trader Rating: 18 (100%+)
RSD Bladders?
And Thanks guys
RSD bladders are made by reflex suspension dynamics. They work on the x ray shocks and are a bit more durable and a lot cheaper than the x ray ones
elee32 is offline   Reply With Quote
Old 06-15-2012, 04:57 AM   #2832
Trader Rating: 54 (100%+)
RSD012 is this the part # for the bladders you guys are using?
Jamison R is offline   Reply With Quote
Old 06-15-2012, 06:47 AM   #2833
mike ivy's Avatar
Trader Rating: 50 (100%+)
Has anyone tried the Cso blocks and how do they perform over the standard X-ray mounts? Would there be better steering, rotation etc,etc?
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 06-15-2012, 08:13 AM   #2834
Dusttt's Avatar
Thanks!
So anyone that is running the exotek conversion. Are you running shims under the rear blocks?
Old 06-15-2012, 02:35 PM   #2835
UrabusDenis's Avatar
Does the front Yokomo belt fit our car?
Alpha Plus - alpha-rc.com
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
