Old 06-12-2012, 08:58 AM   #2806
bukil's Avatar
Trader Rating: 39 (100%+)
Can anyone tell me the difference between these servo savers:
372500
372502
372503
Which one would you recommend for TC?
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 06-12-2012, 09:00 AM   #2807
artwork's Avatar
Trader Rating: 60 (100%+)
372500
372502
372503
372503 is what you are looking for...it is a really good servo saver for TC.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 06-12-2012, 09:46 PM   #2808
stro3579's Avatar
Trader Rating: 20 (100%+)
I am looking for out drives for the front of my t3 12 car. I am using the stock composite ones without the plastic piece at this time. I haven't broke a composite yet, but I know it's coming. I also have a t3 11 that I bought used and it came with some gold ones that I can run without the plastic piece. I would like to find the gold ones for the 12
stro3579 is offline   Reply With Quote
Old 06-12-2012, 10:44 PM   #2809
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by mrjeremyaaron View Post
hi all,
i'm looking to upgrade my '11 to the 2012 spec, and have read through the commentary regarding the thinner flex chassis upgrades from xray, smokem', VBC etc.
typically i run on low-medium grip asphalt here in sydney.
before i go out and spend the coin,would the advice be to go straight to the 1.6 / 2mm flex option from xray or stick with the kit chassis? aside from a lack of turn-in (which apparently the 12 spec is an improvement on), the 11 spec goes ok so i would rather not spend the extra coin if i'm not going to be happy with the upgrade.
looking forward to your thoughts.
I run a T3 here in Sydney also.
I swear by the 2.0m chassis with the standard top deck, I have persevered with the thick and tried to get it going as well as I like the thin, but couldn't I am back to the thin and extremely happy.
In saying that it appears to be personal preference, as some of the guys have done just as well with the standard chassis.
Might be also worth Noting Lemieux ran the thin chassis and thick top deck at last weekends pre worlds. He is also a big fan of the thin thick combo.
Best of luck
Nathan
NR is offline   Reply With Quote
Old 06-12-2012, 11:07 PM   #2810
mrjeremyaaron's Avatar
Best of luck
Nathan
Cheers mate, parts on order..
mrjeremyaaron is offline   Reply With Quote
Old 06-13-2012, 01:03 AM   #2811
hana166's Avatar
They're made by RNR racing. Speedtech used to do them, and ebay, but quite hard to find now
hana166 is offline   Reply With Quote
Old 06-13-2012, 01:09 AM   #2812
kinga's Avatar
Trader Rating: 15 (100%+)
Best of luck
Nathan
When using the 2mm chassis, Do you shim the bulkheads up with 0.5 mm spacers as suggested by xray?
kinga is offline   Reply With Quote
Old 06-13-2012, 03:31 AM   #2813
elee32's Avatar
Trader Rating: 18 (100%+)
http://www.sidepieceracing.com/products/nikita/
They're not gold, but very strong
elee32 is offline   Reply With Quote
Old 06-13-2012, 04:10 AM   #2814
NR
NR's Avatar
I did first time around, however on Hagbergs recommendation, I left them out this time round, apparently leaving them out makes it a little easier to drive.
To be honest I can't tell the difference between the shimmed and unshimmed.
Nathan
Old 06-13-2012, 10:02 AM   #2815
Magnet Top's Avatar
Default Motor mount screw
What is the general consensus on using the "center motor mount screw" ?
With previous T3's I used to leave it off in 17.5 etc to allow more rear flex but running mod I feel the gear mesh at mod rpm requires more rigidity to maintain good gear mesh. Thoughts on this ? Does anyone notice a handling difference on the '12 if the screw is left out ? Any gear mesh issues ?
To clarify this is the screw from the bottom of the chassis , its centered in the chassis , holds the black L shaped "bracket" between the motor mount and the carbon fiber chassis .
Thanks,
Jake D.
Magnet Top is offline   Reply With Quote
Old 06-13-2012, 10:17 AM   #2816
NolanP's Avatar
Thanks,
Jake D.
Yeah mod has a tendencie to be a lot more violent on chassis flex. I switched to a 1.6mm top deck and had better results but that was running 17.5 blinky. I am going to try 2.0mm chassis and 1.6 mm top plate on monday running 17.5 blinky. then try 2.5mm chassis and 1.6mm top plate in 13.5.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 06-13-2012, 10:18 AM   #2817
M-Technic's Avatar
Thanks,
Jake D.
I only remove screws when I run mod, and I only remove them from the top deck. Either just 2 from the back, or 2 from the back plus two from the front.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-13-2012, 10:22 AM   #2818
defcone's Avatar
Thanks,
Jake D.
I don't think this car needs anymore rear grip.
defcone is offline   Reply With Quote
Old 06-13-2012, 10:29 AM   #2819
Magnet Top's Avatar
I should have clarified, I'm using the exotek conversion ....
So Defcone , you are implying you notice a difference of added rear traction without the screw or were you just making a general statement ?
Old 06-13-2012, 10:36 AM   #2820
M-Technic's Avatar
I should have clarified, I'm using the exotek conversion , but the question I should have asked is, do people notice a significant handling difference , and is it trouble to not use the screw in mod due to gear mesh issues ?
I think he's saying in general that the car has plenty of rear traction without removing screws.
I stripped a lot of spurs in mod even without removing a screw from the motor bulk head, so I would definitely advise against it. You don't want any flex right there.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
