Old 05-30-2012, 12:07 PM   #2641
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by Skiddins View Post
I never understood why Hanulec doesn't make them fit the 52mm driveshafts, then it doesn't matter what we use
Skiddins
P.S. I have some of the version that fitted 52mm driveshafts and still use them.
For the best durability.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-30-2012, 01:39 PM   #2642
hanulec's Avatar
Trader Rating: 23 (100%+)
The v2 did fit 52mm ... and they had issues for some people. The v3 model is cut lower than the v1 but much higher than the v2 models. I suspect they will work with 52mm shafts, just not in all conditions/ configurations.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-30-2012, 01:58 PM   #2643
Send a message via AIM to Matt W
Default Battery positioning!!
Has anyone experimented with moving the weight of the lipo forward or back. The weight of a lipo is usually around 20g difference front to back so by positioning the plugs at the front should give a different weight bias to if they were positioned at the back.
Does anyone know how this will affect the car, should you always aim to get an equal weight bias front to back?
Matt W is offline   Reply With Quote
Old 05-31-2012, 08:52 AM   #2644
RobS's Avatar
Weight bias front to rear is a tuning option. The more weight you have further back in the car, more weight will transfer to the front when entering a corner therefore giving you more grip. The further forward the weight is in the car the less it will transfer when going into a corner therefore giving you less grip.
You don't need to aim for 50/50 weight bias front to rear, most of my setups have slightly more weight in the rear then the front.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 05-31-2012, 11:16 AM   #2645
M-Technic's Avatar
Trader Rating: 15 (100%+)
I installed and ran the new offset servo mount last night. It seems nice, but not as solid as I was hoping it would be. I did about 5 runs with it and no problems, but time will tell how it holds up.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-31-2012, 11:21 AM   #2646
Trader Rating: 38 (100%+)
What about it didn't seem solid? I have it in the car I'm building up now and it seemed like it was going to hold pretty well but I don't even have a servo connected to it right now.
or8ital is offline   Reply With Quote
Old 05-31-2012, 01:28 PM   #2647
yokemad's Avatar
My one looks and holds rock solid....
You can also apply some servo tape if you want but I couldnt get why do you think it may fail?
Cheers
yokemad is offline   Reply With Quote
Old 05-31-2012, 01:45 PM   #2648
M-Technic's Avatar
It just flexes more than I would want it to.
Old 05-31-2012, 08:44 PM   #2649
haywood's Avatar
Trader Rating: 48 (100%+)
Default T3 2012
Really pleased with the performance and reliability of my 2012! Car is dialed on carpet with our club spec Sweep True Blue tires. I am Running the car virtually stock with the exception being the 50mm ecs shafts and the Side Piece Racing spool outdrives! My only real complaint is the $12.00 shock bladders that tear occasionally.
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 05-31-2012, 09:44 PM   #2650
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I've been using the Reflex bladders in my Xrays for about a month and they seem to be more durable. I haven't torn one yet and they build great with no hassle in the Xray plastic shocks.
Old 06-01-2012, 06:00 AM   #2651
yokemad's Avatar
Using Tamiya Bladders& Xray Alloy shocks last couple of years without any problem ,Should We Change them time to time With New ones Despite They Still looks Brand new?
Cheers
Old 06-01-2012, 08:27 AM   #2652
dr_hfuhuhurr's Avatar
Trader Rating: 69 (100%+)
Originally Posted by RCknight View Post
What do you think Xray will change for the T3 13?
I would love to see a purpose-built body tuck solution for the 13.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 06-01-2012, 09:05 AM   #2653
I would like to see alloy shocks ,ECS shafts and a 2mm chassis as standard equipment.
Fastfreddy74 is offline   Reply With Quote
Old 06-01-2012, 09:52 AM   #2654
yokemad's Avatar
I guess 2mm chassis, centre servo holder and alloy steering arms = t3 2013
Old 06-01-2012, 09:58 AM   #2655
syndr0me's Avatar
Trader Rating: 32 (100%+)
You guys are crazy if you think XRay is going to throw in $350 worth of hopups in the new kit.
The topdeck and chassis shapes will see slight changes. Maybe the servo mount will get thrown in. Perhaps the camber link plates will be lower with a wider range of adjustment. That's about it.
syndr0me is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
