Old 05-29-2012, 07:56 PM   #2626
NolanP's Avatar
Originally Posted by hanulec View Post
never owned a 2012. last XRay was a T3 (2010). i'm just filling a product gap -- good outdrives!
Gotcha.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 05-29-2012, 08:17 PM   #2627
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by defcone View Post
Any plans for a similar product for the gear diff? It seems like everytime I'm replacing that plastic bit, only half of it is used.
+1
syndr0me is offline   Reply With Quote
Old 05-29-2012, 10:10 PM   #2628
RCknight's Avatar
Originally Posted by J.Filipow View Post
I saw some of the development parts and a preproduction T3-2013 being run by Martin Hudy at the Reedy Race last weekend. Lots of subtle tweaks to the T3-2012 platform, some of which may or may not make it into next years production kit.
Can you mention what tweaks you saw? Just curious. Thanks. I won't hold my breath on a Tamiya designed teflon coated shock. lol
RCknight is offline   Reply With Quote
Old 05-30-2012, 04:19 AM   #2629
hanulec's Avatar
Trader Rating: 27 (100%+)
I'm not familiar with the gear diff problem(s). Tell me more, take some pictures. Personally I don't know why people run them up front. I think spools are still the way to go.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-30-2012, 04:34 AM   #2630
blade072's Avatar
Trader Rating: 98 (100%+)
on our track it makes our cars more stable....ill never go back to a spool.....
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 05-30-2012, 04:56 AM   #2631
defcone's Avatar
Trader Rating: 15 (100%+)
Just that the outdrive is made too thin and the blade wears out really quickly.
defcone is offline   Reply With Quote
Old 05-30-2012, 04:59 AM   #2632
Trader Rating: 38 (100%+)
This.
or8ital is offline   Reply With Quote
Old 05-30-2012, 05:16 AM   #2633
blade072's Avatar
thats why i got the hudy spring steel versions.....but i have 2 pair of the standard ones new in pack if anyone wants them
http://www.teamxray.com/teamxray/pro...0Steel%99%20(2)
David Randall
Old 05-30-2012, 05:32 AM   #2634
defcone's Avatar
Does the outdrive cover the entire blade?
Old 05-30-2012, 06:02 AM   #2635
M-Technic's Avatar
Originally Posted by olhipster1 View Post
adjustable pistons only pro is the ease of being able to change make a quick change to the shock oil flow. Thats it.
no other advantage...
they tend to get loose and change setting after crash/etc.
more parts inside the shock...etc.
always go with fixed pistons...no disadvantage...build it and leave it.
Xray shock are very good...when they are built correctly.
I love the adjustable pistons, and in 3 years of driving an Xray I've never had one change it's setting in any situation. I use that adjustment a lot and it's one of the nicest features of an Xray in my opinion. Just my 2 cents.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-30-2012, 06:11 AM   #2636
locked's Avatar
No, but the blades fit really snugly in the steel outdrives. They'll wear a groove in the blades, but it's not really an issue.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-30-2012, 06:35 AM   #2637
Xpress's Avatar
The outdrives are the same OD as the bearing ID. If you want the outdrive larger in dia you'll have to install the bearing on the diff case and then build the diff trapping the bearing. I'd rather just change the blade when it wears out...
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 05-30-2012, 07:02 AM   #2638
Trader Rating: 20 (100%+)
the picture i've included includes the SPEC-R -- which are like 50mm, not 52mm.
I measured a set of the ver2 spec R shafts and they were about 1.2mm shorter from pin to post than the Hudy 52mm shafts. I wasn't extremely precise when I measured because it was more of a curiosity to know rather than a need for a specific length but I was pretty close.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 05-30-2012, 09:37 AM   #2639
Originally Posted by b.wihardja View Post
Can I use "308361 hardened shock shafts" on t3 2012 standard shock?
I need a longer shock to raise ride height
AFAIK 308361 is a shaft for T2 007
No body use 308361 on t3 12? Thinking another way to extend the shock.
b.wihardja is offline   Reply With Quote
Old 05-30-2012, 10:31 AM   #2640
Skiddins's Avatar
New Nikita V3 outdrives now available at www.sidepieceracing.com/products/nikita/. They feature a 90 degree offset to further reduce wear and tear on the drive line. The outdrives are designed for 50mm drive shafts, but might fit 52mm shafts depending upon arm spacing. The depth of the U cut is similar to the original manufacturing run.
Originally Posted by MikeXray View Post
I don't have them, I never understood why anyone needed them other than that hagberg runs them so they must be better The SPR outdrives work well with 50's even up to 2.25mm spacing.
I never understood why Hanulec doesn't make them fit the 52mm driveshafts, then it doesn't matter what we use
Skiddins
P.S. I have some of the version that fitted 52mm driveshafts and still use them.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
