Old 05-26-2012, 09:14 PM   #2581
pchroma24's Avatar
Trader Rating: 73 (100%+)
Originally Posted by RCknight View Post
well I have the newer T3r that is same thing as the T3 12 but with the servo mounted old style. What all do I need to convert it to the newer servo position? A new Xray chassis and upper deck costs to much. Any alternative after market chassis/upper deck that's closer to the stock chassis that's cheaper? I hoped to see a conversion kit for the T3 12.
If I follow your question... 2 relatively simple solutions... You could try to rotate and re-drill the new servo position ( I did this on my 11) use only the inside mount and use some shoe Goo to secure the servo ( or the new center servo mount 306220 ) or .. purchase the cefx chassis #19005 ... its pretty close to a factory 12 and works quite well for around $60 shipped... Hope it helps...
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 05-26-2012, 10:51 PM   #2582
B00t13g's Avatar
Originally Posted by idbdoug View Post
What springs are you referring to???
idbdoug
The new progressive springs. Looked good today Chris!
B00t13g is offline   Reply With Quote
Old 05-27-2012, 12:26 AM   #2583
Chris Adams's Avatar
idbdoug
Doug, find me today during the series race. Ill let you know what springs im talking about. They are new and Im guessing not many people have them. We can get you and whomever else wants them an order.
TEXASEOS.net, SpeedzoneUSA, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2016
Chris Adams is offline   Reply With Quote
Old 05-27-2012, 12:27 AM   #2584
Thanks Mack!
Texas EOS 2016
Old 05-27-2012, 01:08 AM   #2585
syndr0me's Avatar
Trader Rating: 32 (100%+)
Mind sharing the spring info? I'm doing my share of mod practice in challenging traction on the rug. Mid corner grip is particularly problematic.
I ran out of CVD blades, so I put the composite outdrives back in my spool. I had been running the XRay steel pieces. Anyway, I almost immediately bent a CVD (Spec-R) after having no issues for 50+ runs. It's more of a twist than a bend, like I experienced before. I'm wondering if the composite outdrives might be a factor in bending bones.
syndr0me is offline   Reply With Quote
Old 05-27-2012, 07:43 AM   #2586
The spring is a 2.2-2.6. Not sure on the part number. It will help the mid corner grip for sure.
Texas EOS 2016
Old 05-27-2012, 08:01 AM   #2587
Default 10.5T no boost
Anyone running 10.5T at no boost?
I'm running stock class soon and testing the gearing, finally tested with 4.3:1 (1.8:1 rollout), motor temp around 60C with 2 heat sink fans.
Anyone run this gearing and can I faster than this?
GP: Mugen MRX-6, Serpent Cobra GT 3.0
Engine: Tesla 7 port on-road, Tesla 5 port GT, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 05-27-2012, 03:02 PM   #2588
Jerz616's Avatar
Trader Rating: 49 (100%+)
Hey chris. Can you order me some of those springs, and the new center servo mount.
Ryan
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 05-27-2012, 09:59 PM   #2589
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I have had the opposite experience. Weird. I felt that the plastic would give and break before the bone would bend. I have broken several plastic outdrives without bending ecs's. The one day I put the metal out-drives in, I bent an ecs bone.
Old 05-28-2012, 09:08 AM   #2590
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
It's my third week with the t3 12 and I finally hit on a low traction setup for a tight asphalt track. The box setup was like driving on ice. My son finished second with the new setup and more important the car was very driveable. I will now add a little steering. It seems like it takes me 4 weeks of club racing to dial in a new car, so I am a little ahead of schedule.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 05-28-2012, 10:46 AM   #2591
roger999's Avatar
Guys, will 118 t 64 spur fit T3?? Or is too big?
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 05-28-2012, 11:32 AM   #2592
Fred Hubbard's Avatar
It's really too big, the teeth will protrude below the chassis, you could get away with running it on carpet but you will have to drive super smooth and not got over any dots or barriesr and run your ride height around 5.4R and 5.2F so that you don't risk the chance of cutting the rug. As for running it on asphalt, forget about it! If you want to run a big gear a 116 will suffice.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 05-28-2012, 12:15 PM   #2593
roger999's Avatar
Thanks for that. I thought that will be too big... So im a little confused, why Xray selling it????? I never thought will be too big and just got it... now can put it to my bin.
Old 05-28-2012, 01:15 PM   #2594
We used to use them when we ran foam tire TC and 3mm chassis.
Old 05-28-2012, 02:18 PM   #2595
Send a message via AIM to Matt W
Default screws coming out
Hi,
Im having an issue with some of the screws coming out the bottom of the chassis. Can you use soft thread lock to hold some of them in, ie into metal bulkheads?
Matt W is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
