Old 05-10-2012, 03:38 PM   #2446
Fred Hubbard's Avatar
Originally Posted by FiremanKen View Post
They ARE rubber, added a few shims and still does it. Heres a quick video i put up to share. Hoping its the old wheels like i said they are about 4 years old RP brand. ANyone able to measure the inside diameter of your rims i just checked these ones and coming up with about 44.34 mm https://www.youtube.com/watch?v=H8Qm...e_gdata_player
You are using the kit front driveshafts right and running a spool? If so then what you are hearing is chatter which is normal when using none ECS type driveshafts.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 05-10-2012, 03:48 PM   #2447
Thanks Fred....SO the "chatter" is that from hitting the inner rim from the vibration?Is this much of a concern while running it on the track?
FiremanKen is offline   Reply With Quote
Old 05-10-2012, 03:53 PM   #2448
Super Moderator
Slo_E4's Avatar
Trader Rating: 57 (100%+)
Nothing should be hitting the rim. The driveshafts are making the chatter. This is normal in pretty much any car that "does not" have ecs type shafts. (double jointed shafts) You won't have problems on the track, but if you do get ecs's you will feel the difference.
Slo_E4 is offline   Reply With Quote
Old 05-10-2012, 03:59 PM   #2449
As you start to approach and at full steering lock is what causes chatter and from that you will get vibration which can cause the rim to rub as well.
Old 05-10-2012, 05:18 PM   #2450
Skiddins's Avatar
I made a video of the same thing a while back for someone;
http://s107.photobucket.com/albums/m283/Skiddins/RC%20Stuff/?action=view&current=SpoolChatter.mp4
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-11-2012, 03:56 AM   #2451
Originally Posted by Skiddins View Post
So will gear diff in front help reduce chatter much?
zzztech is offline   Reply With Quote
Old 05-11-2012, 05:53 AM   #2452
Trader Rating: 54 (100%+)
It depends on how heavy the oil in the front. If I switch to a gear diff in front with 60,000 its barely noticable. Ive tried 500,000 and putty and they both chatter. The ecs shafts are the way to go. Arrowmax makes a set that are better than the spec-r but not quite as nice as the xray ecs shafts.
Jamison R is offline   Reply With Quote
Old 05-11-2012, 06:50 AM   #2453
Skiddins's Avatar
Don't bother with a gear diff if your only reason is to get rid of servo chatter, as a spool will be faster.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 05-11-2012, 07:09 AM   #2454
dr_hfuhuhurr's Avatar
Trader Rating: 69 (100%+)
Your Battery is going to fall
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 05-11-2012, 10:36 AM   #2455
Skiddins's Avatar
TOO LATE!
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 05-11-2012, 04:08 PM   #2456
steveonamission's Avatar
Anyone else discovered CSO's engineering not to be up to much?
The driveshaft axles have been drilled in the wrong place, which leaves about .5 of play.... Didn't expect them to be as strong as the XRAY items, but I only wanted them for the rear where they arn't strained, but atleast expected them to have been drilled correctly.
Just a little warning for anyone looking to purchase.
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Old 05-11-2012, 04:13 PM   #2457
Caveat Emptor...imitation may be the highest form of flattery but it doesn't mean the quality will be the same as the original designer!!!!
Old 05-11-2012, 05:09 PM   #2458
pcar951's Avatar
Trader Rating: 19 (100%+)
Yup, I bought some CSO axle assemblies to get me by in a pinch. Can't use them, the axle shafts are machined under size and sloppy in the bearings, creates erratic handling.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 05-11-2012, 07:30 PM   #2459
Magnet Top's Avatar
I just picked up a set of CSO "tamiya style" hinge blocks for the T3'12. I didn't realize they don't offer 1.5degree and 2.0 degree toe blocks for the rear. ( only 2.5, 2.75, and 3.0 ) So if you want to use outboard toe, you are limited to no less than 3.5 degrees of rear toe (unless you use the CSO toe block in the rear and the standard X-ray roll center hinge blocks ( with shims ) in the front of the rear )
Also, apparently the optional T3'12 2.0 and 2.2mm chassis that CSO offers has a flaw, they drilled the holes the for the steering rack in the wrong spots....
So, basically... yeah, I'd be wary of CSO products at this point !
Jake D.
Magnet Top is offline   Reply With Quote
Old 05-12-2012, 07:57 AM   #2460
Jake D.
When I was testing our protoype back in January one of my suggestions was that we create additional blocks so that we can run outboard toe and still have all the overall toe options we needed. Whew it feels great to know that Exotek customers don't have to experience these types of isssues
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
