Old 05-08-2012, 05:41 PM   #2431
nashrcracer's Avatar
R/C Tech Charter Subscriber
i run a 4.13 on low bite on a 90x48 track smaller I would go higher like 4.20
if the bite comes up go up a tooth or 2.... but that's a good start for full timing on most motors.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow — never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long — you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 05-08-2012, 07:42 PM   #2432
pchroma24's Avatar
Trader Rating: 73 (100%+)
Originally Posted by big paul View Post
Its a good job these cars are suppose to be a luxury car. I'm so pleased I found this thread I thought my set up gear was out.
What is overlooked is the tolerances in the manufacturing process.. in this part especially when 1* toe is achieved with a .5mm shim.. a difference of .05mm anywhere in the mounting (approx half the thickness of a sheet of paper) can yield .1* in rear toe difference side to side .. compound this with 2 separate mounting points (f/r) and it can become a significant issue... Glad we could assist...
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 05-08-2012, 10:45 PM   #2433
Trader Rating: 15 (100%+)
Default Spurs
Anybody know somewhere that has the black rw or xenon 96 tooth in stock in the us
AARON YOUNG is offline   Reply With Quote
Old 05-09-2012, 03:02 AM   #2434
Skiddins's Avatar
What country are you in?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-09-2012, 05:41 AM   #2435
Originally Posted by Skiddins View Post
You need a little bit of slop in the joints to help the steering to center.
If you want to remove some of the slop, try wrapping some plumbers PTFE tape around the ball joint then snap the rod end onto it.
Helped on mine.
Skiddins
Originally Posted by Johnny Wishbone View Post
If you have slight slop and a plastic bag fix is too thick, try saran wrap, its quite a bit thinner mil spec and you can double it if you have to. It also kind of cuts itself so you don't have to trim it after you snap the ball cup back on.
I've tried using the PTFE" and Saran Wrap but it did not last long. Only last around 3 battery.
Originally Posted by bucketboy View Post
Got no slop in any of the ball cups but you can put a soft 3mm o ring over the ball, then the cap will be a snug fit Bb
I'll try o-ring and report back
yea, and don't forget that the sloop can also cause this
b.wihardja is offline   Reply With Quote
Old 05-10-2012, 05:35 AM   #2436
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
I recently rebuilt my XRay after the end of the season and wanted to share a solution I came up with to make the battery fit better.
I use the Orion Carbon Pro 90c 5000mah pack and I didn't like how there was side-to-side play with the stock holder. What I did was measure the amount of space between the inner 30g weight and the battery. I then cut a strip of lead weights to that length and sho-goo'd the lead in place. This now provides a very snug fit for the batteries and puts about 6g of weight additionally in center-line of the chassis.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 05-10-2012, 10:11 AM   #2437
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
I used fuel line tubing and placed it on my L Bracket and it works well.
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 05-10-2012, 10:41 AM   #2438
theatriks's Avatar
wouldnt buying the optinal battery hold down aleviate this battery problem you guys are talking about
theatriks is offline   Reply With Quote
Old 05-10-2012, 12:59 PM   #2439
Trader Rating: 54 (100%+)
whats the part # for those aluminum battery holders?
Jamison R is offline   Reply With Quote
Old 05-10-2012, 01:16 PM   #2440
Default Front Arms Rubbing on Wheels
Hi all,
Just finished putting together my 2012. Just getting the kinks out. One issue I am having is that when I turn the wheel the front arms are rubbing on the inner of the wheels/rims just slightly at speed. FYI the wheels I am using are ones i had on my old 007 which are at least 4 years old as I have not bought any new tires/wheels yet.
Is this an issue specific to older rims/wheels? or do I need to file down a bit on the front arms.
Thanks in advance
Ken
FiremanKen is offline   Reply With Quote
Old 05-10-2012, 01:19 PM   #2441
dannylsy21's Avatar
Hi, it's better for u to file the wheel instead of ur arm...
dannylsy21 is offline   Reply With Quote
Old 05-10-2012, 01:21 PM   #2442
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by FiremanKen View Post
Hi all,
Thanks in advance
Ken
Are they foam? if so, they are wider than the rubber tires we run today, if not, it's possible the brand tire you has is on a wider rim than standard. Adding a shim at the wheel hex is the easiest fix.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-10-2012, 01:55 PM   #2443
They ARE rubber, added a few shims and still does it. Heres a quick video i put up to share. Hoping its the old wheels like i said they are about 4 years old RP brand. ANyone able to measure the inside diameter of your rims i just checked these ones and coming up with about 44.34 mm https://www.youtube.com/watch?v=H8Qm...e_gdata_player
Old 05-10-2012, 02:15 PM   #2444
Skiddins's Avatar
You've made the viseo 'Private' so we can't see it
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-10-2012, 02:27 PM   #2445
opps, ok i unlocked
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
