Old 05-08-2012, 05:51 AM   #2416
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Are you noticing a difference in handling with the toe discrepency or uneven tire wear or heat? Maybe you can leave it even though it seems off, .2 is not that bad. I might try a shock o ring or other oring in the equasion and tighten until it is even, not sure about how well it will hold up in time though.
I would not want to give up the rear grip but there are adjustments you can do to compensate if you do add the 1 piece mount in the rear of the front.
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 05-08-2012, 05:53 AM   #2417
pchroma24's Avatar
Trader Rating: 73 (100%+)
Originally Posted by roger999 View Post
guys, any ideas what to do to have same toe in on rear left and right wheels? right hand side is 3 but left hand side is about 2.8..? i pushed the alu holders against tightening direction but still is not right.. First was 2.5 but now i could do it until 2.8 but still have no 3... the car is brand new of course....
This is more likley to do with the combination and inconsistency in the thicknesses of the shims and the plastic suspension holders being used. Differences of up to .05 mm is pretty common when checked with calipers and is responsible for the small variances in toe from side to side. With some effort and an assortment of shims, you can get it perfect.. I ve also touched up the suspension holders with abit of sand paper to ensure consistent thickness as these can vary slightly too... Hope it helps...
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 05-08-2012, 05:54 AM   #2418
roger999's Avatar
Originally Posted by kinga View Post
+1, I have had a t3r, t3 2011 and now t3 2012, and all have had different toe left to right.
I find 1.75mm of shims on the left, and 1.5mm shims on the right gives equal toe in of 3 degrees. Not sure why.
Using the one peice holder at the front of the rear will reduce rear flex and traction
Cool. will try it later. thanks.
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 05-08-2012, 06:53 AM   #2419
Send a message via AIM to Matt W
Default 17.5 blinky gearing
Originally Posted by MikeXray View Post
Aim for a 4.0 FDR to start, depending on your track size, you may need to go lower. (I typically have a 92/44)
I currently run on a small/mid sized carpet track running 8.70fdr using a 13.5 boosted LRP x12! Do u still think 4.0fdr is a gd starting point or is that more for larger tracks?
Matt W is offline   Reply With Quote
Old 05-08-2012, 07:48 AM   #2420
roger999's Avatar
yes i did sand suspension holders a bit, and decreased toe fron 2.5 to 2.8. But still need more will shim it a bit later and we will see the effect. thanks.
Updated:
used silver shim from kit, ~0.3mm and that problem is solved! Thanks to all.
Old 05-08-2012, 12:43 PM   #2421
whityboy's Avatar
Will spurs from serpent fit on the T3?
I need smaller spurs and the smallest xray is 78.
Serpent goes to 72.
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 05-08-2012, 12:47 PM   #2422
MikeXray's Avatar
Trader Rating: 72 (100%+)
Yes 4.0 is a good starting point, on larger tracks we can run as low as 3.2, but generally 3.6-4.1 covers most medium sized tracks, and it depends on what motor, how much timing, and how hot that motor is getting. I run thunderpower motors with around 32dg of timing.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-08-2012, 01:56 PM   #2423
M-Technic's Avatar
Trader Rating: 15 (100%+)
Serpent goes to 72.
You won't be able to get to the second motor screw.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 05-08-2012, 02:16 PM   #2424
locked's Avatar
If you ever need to use a spur that blocks access to the rearmost motor screw, just set the mesh using the front motor screw, then remove the spur/layshaft, tighten the rear motor screw, then put the spur back in.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-08-2012, 02:24 PM   #2425
Super Moderator
Slo_E4's Avatar
Trader Rating: 57 (100%+)
+1 or you can drill a hole in the spur.
Slo_E4 is offline   Reply With Quote
Old 05-08-2012, 02:54 PM   #2426
FK05 lover's Avatar
Trader Rating: 147 (99%+)
Serpent goes to 72.
RW do 48p spurs for Xray, I run a 66t in my T3'12 & can get to motor screw,
though I do remove the top deck to make life easier when I change the pinion
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 05-08-2012, 03:22 PM   #2427
Talking
Updated:
Its a good job these cars are suppose to be a luxury car. I'm so pleased I found this thread I thought my set up gear was out.
big paul is offline   Reply With Quote
Old 05-08-2012, 04:33 PM   #2428
Skiddins's Avatar
Serpent goes to 72.
+1 for RW spur gears, they are OEM for Schumacher cars and do Xray spurs that you want
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-08-2012, 05:01 PM   #2429
theatriks's Avatar
anybody else notice that the instructions for the assembly of the ball diff are wrong
theatriks is offline   Reply With Quote
Old 05-08-2012, 06:31 PM   #2430
silvalis's Avatar
Trader Rating: 29 (100%+)
silvalis is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
