Old 05-06-2012, 02:07 AM   #2401
MrRolla's Avatar
Trader Rating: 29 (100%+)
#302069, they will crack if you overtighten the screw into them
MrRolla is offline   Reply With Quote
Old 05-06-2012, 09:03 AM   #2402
Fred Hubbard's Avatar
Originally Posted by bosfan View Post
Does anyone know how to find out what lbs the springs are?
Originally Posted by Johnny Wishbone View Post
In addition multiply the C value by 5.71 (3.0 x 5.71 = 17.13lbs).
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 05-06-2012, 09:17 AM   #2403
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Thx.
I thought they were aluminum and overtightened
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 05-06-2012, 10:00 AM   #2404
I am headed out with my son for his first day with the t3 12, and yes I will be getting in my fair share of laps also.
Below is a pic of his 3 generations of xrays
Team Waldorf Racing
Old 05-07-2012, 09:32 AM   #2405
Send a message via AIM to Matt W
Default 17.5 Blinky gearing
Hi,
I run the xray t3 12 mainly on mid sized carpet tracks. Ive always run 13.5 boosted and am now switching over to 17.5 blinky. Roughly how many teeth in pinions do i need to go up by in comparison, any ideas?
Matt W is offline   Reply With Quote
Old 05-07-2012, 09:34 AM   #2406
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by Matt W View Post
Hi,
Aim for a 4.0 FDR to start, depending on your track size, you may need to go lower. (I typically have a 92/44)
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-07-2012, 12:11 PM   #2407
Default spacers on the savox
Originally Posted by locked View Post
All set. Now I just need to paint a body before morning. I'll sleep tomorrow night
It's not something I would submit to the best cleanest electronics thread, but it'll do.
hi did you use any shims and if so which size on the servo?
Ken
FiremanKen is offline   Reply With Quote
Old 05-07-2012, 12:31 PM   #2408
locked's Avatar
Ken
No shims. There's some from the servo saver to the steering link, but the servo itself is not shimmed. I do use the rubber grommets on all the ears though, to help prevent tweak. Allows for a little bit of flex.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 05-08-2012, 02:49 AM   #2409
roger999's Avatar
Default rear toe in issue
guys, any ideas what to do to have same toe in on rear left and right wheels? right hand side is 3 but left hand side is about 2.8..? i pushed the alu holders against tightening direction but still is not right.. First was 2.5 but now i could do it until 2.8 but still have no 3... the car is brand new of course....
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 05-08-2012, 03:55 AM   #2410
haywood's Avatar
Trader Rating: 48 (100%+)
Buy the one piece suspension mount for the front of the rear.
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 05-08-2012, 03:58 AM   #2411
roger999's Avatar
Yeah but probably will be less flexible after i mount it...?
Old 05-08-2012, 03:59 AM   #2412
just shim the 2.8 side until you get 3 toe in i have had 2 xray t3 and never had both sides the same from using same shims
rc12r5.1
moggy12 is offline   Reply With Quote
Old 05-08-2012, 04:11 AM   #2413
haywood's Avatar
Yes... You will loose a little rear grip I've been told.
Old 05-08-2012, 04:21 AM   #2414
roger999's Avatar
But after that does the lenght will change? probably will be little different left and right.
Old 05-08-2012, 04:51 AM   #2415
kinga's Avatar
Trader Rating: 15 (100%+)
+1, I have had a t3r, t3 2011 and now t3 2012, and all have had different toe left to right.
I find 1.75mm of shims on the left, and 1.5mm shims on the right gives equal toe in of 3 degrees. Not sure why.
Using the one peice holder at the front of the rear will reduce rear flex and traction
kinga is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
