Old 05-03-2012, 09:26 AM   #2386
Skiddins's Avatar
Originally Posted by MrRolla View Post
Thanks, ill give it a go..
Also while browsing some asphalt setups on the xray site i noticed most of the team drivers are running 450-600 shock oil. Im running 350 atm, but if i was to jump up to 450 all round would it just make the car more responsive? The track is very smooth I race on..
Make sure you are not comparing 'apples and oranges'.
A lot of the team driver setups use alu shocks with 1.1mm hole pistons.
The kit shocks are 1.0mm holes.
My totally un-scientific testing brought me the conclusion that 350Cts with kit shocks is around 450Cts with the alu's and 1.1mm pistons
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-04-2012, 07:47 AM   #2387
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
I am assembling my t3 12 and using a setup I got from Cold aa Ice. I have also looked at other setup sheets and noticed that most everyone is running short camber links for there roll center. I have always thought that longrr links decrease camber gain and settle that end making it more stable or less aggressive. Also how many mm of spacers can I run in front of the rear arms (wishbones) it seems like I can fit 4mm. My purpose is to create a docile car for my 8 year old son to run outdoors on asphalt low traction and tight track
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 05-04-2012, 07:53 AM   #2388
defcone's Avatar
Trader Rating: 15 (100%+)
Docile doesn't really work with tight tracks I found, but the kit setup works well on low-med grip asphalt outdoors and is docile.
defcone is offline   Reply With Quote
Old 05-04-2012, 11:09 AM   #2389
Thx
Team Waldorf Racing
Old 05-04-2012, 04:18 PM   #2390
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Guys Gotta Question,
For people running Tamyia shocks on the T3 2012. What weight old would you recommend for Low to Med bite asphalt w solara hard compound tires. Im running 13.5 Blinky or 17.5 Blinky
The pistons are, I think 3 hole 1.2mm.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 05-04-2012, 09:13 PM   #2391
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Hudy Spring Steel Gear Diff outdrives...
Heavier, Lighter or the same as the stock gear diff outdrives?
http://www.teamxray.com/teamxray/pro...kategoria=4024
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 05-04-2012, 09:21 PM   #2392
hanulec's Avatar
Trader Rating: 23 (100%+)
Yo Ivy.. talk to Haynes. He will be at Jackson Saturday...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-05-2012, 01:30 AM   #2393
syndr0me's Avatar
Trader Rating: 32 (100%+)
Is my Exotek T3'12 TCS legal? Thanks.
syndr0me is offline   Reply With Quote
Old 05-05-2012, 04:15 AM   #2394
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Only if you paint/decorate the chassis blue by rattle can.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is online now   Reply With Quote
Old 05-05-2012, 08:27 AM   #2395
MikeXray's Avatar
Trader Rating: 72 (100%+)
45wt losi, but this really needs to be matched with your spring setup, I have 2 hole piston up front and used 35wt, and used 45 in the rear with 3 hole and 2.6/2.4 springs. I think most are running at least a 2.8/3.0 front spring there, you really want to copy Als car, lol.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-05-2012, 09:41 AM   #2396
Default Servo Recommendation for the 2012
Hi all,
Just recieved my kit and wondering what are the servos are working well with this kit.
Thanks in advance
Ken
FiremanKen is offline   Reply With Quote
Old 05-05-2012, 01:59 PM   #2397
UrabusDenis's Avatar
Anyone using the horizontal rear belt position (not upper or lower) or one tighter?
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
RW mods - www.rw-mods.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 05-05-2012, 04:31 PM   #2398
Does anyone know how to find out what lbs the springs are?
bosfan is offline   Reply With Quote
Old 05-05-2012, 05:00 PM   #2399
Johnny Wishbone's Avatar
http://www.teamxray.com/teamxray/new...gs%20-%20Black
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-05-2012, 10:57 PM   #2400
I noticed today that the plastic bearing retainer on the layshaft is cracked, it is the piece that keeps the layshaft in place between the bearing and top deck.
I don't see a part #
any help ?
Team Waldorf Racing
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
