Old 05-01-2012, 03:43 PM   #2371
Trader Rating: 19 (100%+)
Originally Posted by Slo_E4 View Post
You will have dirt on the top of those area's. I would cut them out.
Will do, didnt know if it would help keep like small rocks from getting into the pulleys/spur gear.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 05-01-2012, 08:59 PM   #2372
jcrr's Avatar
Thumbs up Thanks
Originally Posted by haywood View Post
You need to switch to 50 mm bones!
Thanks will get them asap !
jcrr is offline   Reply With Quote
Old 05-02-2012, 05:56 AM   #2373
theatriks's Avatar
I thought the same as you and didnt cut the holes out and i got a rock caught under the rear pulley and it tore up my rear belt if i had the holes cut out the rock would have just fell through and saved my belt....soooo +1 on cutting the holes out.
theatriks is offline   Reply With Quote
Old 05-02-2012, 06:07 PM   #2374
I use adjustable piston in the plastic shock, after I checked, the shafts sometimes stuck and can not fully fall down, the shaft must be rotated in order to gain a normal length.
Please help. Thx
b.wihardja is offline   Reply With Quote
Old 05-02-2012, 06:17 PM   #2375
Please help. Thx
The adjustable "clickers" are known and prone to that, The only way to fix that is to run standard pistons, you'll usually only change the front anyway between 2 and 3 hole depending on the track
★Randy Banks★
Old 05-02-2012, 07:07 PM   #2376
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Hi Guys.
this is my first post in this thread and I am looking for a little help. I purhased a t311 with the vbc flex chassis kit which includes the E/W servo mount and I also have the more traditonal rollcenter mounts like the tamiya or serpent.
Anyway I need a begining setup for the car. It will be raced by my 8 year old son, we race outdoor asphalt low traction and very tight.
Don
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 05-02-2012, 11:17 PM   #2377
stro3579's Avatar
Trader Rating: 20 (100%+)
Does anyone know where I can get X-ray part number 306220?
stro3579 is offline   Reply With Quote
Old 05-03-2012, 01:57 AM   #2378
Skiddins's Avatar
Not out yet
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-03-2012, 02:48 AM   #2379
MrRolla's Avatar
Trader Rating: 29 (100%+)
quick question,
2deg vs 3 deg rear toe, if you can keep the car stable with 2deg would the car be faster with 2deg vs 3deg (less drag)? and obviously ill get more steering?
Cheers
MrRolla is offline   Reply With Quote
Old 05-03-2012, 03:44 AM   #2380
adri-13's Avatar
Originally Posted by adri-13 View Post
Ok thanks,
They are much harder than the original arms?
Anyone about the new arms??
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 05-03-2012, 05:49 AM   #2381
Skiddins's Avatar
Originally Posted by Phil C View Post
I have tested the new arms outdoors on asphalt, they appeared to be more responsive and carried more cornerspeed but felt slightly more difficult to drive.
They are lighter and stiffer than the standard arms.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-03-2012, 05:52 AM   #2382
Skiddins's Avatar
Originally Posted by MrRolla View Post
quick question,
Cheers
I believe 2deg will produce less drag in a straight line and will give better turn in, but it may compromise mid corner steering and stability.
It works better on some tracks than others.
Try it and see which you prefer and which produces better lap times for you.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-03-2012, 05:56 AM   #2383
MrRolla's Avatar
Thanks, ill give it a go..
Also while browsing some asphalt setups on the xray site i noticed most of the team drivers are running 450-600 shock oil. Im running 350 atm, but if i was to jump up to 450 all round would it just make the car more responsive? The track is very smooth I race on..
Old 05-03-2012, 06:26 AM   #2384
NolanP's Avatar
We run on a very smooth open track surface and I am running the stock weight the kit comes with up front and 27.5 weight in the rear. Granted this could all change when the temps come up.
I run in 17.5 so its not as violent of a turn in as mod and 13.5 though.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 05-03-2012, 06:55 AM   #2385
adri-13's Avatar
Thank you! I've not seen this reply
PETITrc driver
www.PETITRC.com
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
