Old 04-13-2012, 01:38 PM   #2191
locked's Avatar
I twisted one the most while using a 17.5 motor(boosted). The other 2 that I twisted weren't quite as bad even though I was using a 4.5. I might not have noticed the last one that did it, but I've been looking out for it closely now.
Both of my cars get a fair bit of use. Usually 2 race days each week. Including practice, they each get around 400 laps or more every week, I'd guess.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 04-13-2012, 01:45 PM   #2192
UrabusDenis's Avatar
Originally Posted by gawith0413 View Post
How much do you run your T3 12, what motor do you use?
I ran it on a few testing days two weeks before the nationals and on the race itself. I didn't run the car after that, because of lack of free time and the fact the next race is in one month. All together about 20-25 batteries, and in that period I had the problem with the loosened pins (which was easily solved by flattening them- P.S. flat spot pins were included in the kit 8 years ago!), a snapped rear belt, and now the driveshafts (which I discovered today after maintaining the motor and connecting it to see if everything works- then I notices the 52mm shaft is bent) - not something I would expect from a company like Xray. I run 10,5T Super Stock with boosted racing basically as far as it goes- with temperatures around 85-95 degrees Celsius
Alpha Plus - alpha-rc.com
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 04-13-2012, 06:52 PM   #2193
Default Ball Diff for the T3 2012
I would like to try a ball diff in my T3 12. I have a ball diff from my old T2 009 but it has a 34 tooth pulley. I do have a 38 tooth pulley but Im not sure its the right one. Can some one tell me a part number for the correct 38 tooth diff pulley. Thanks
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 04-13-2012, 09:01 PM   #2194
pcar951's Avatar
Trader Rating: 19 (100%+)
I've bent (twisted) all the spring steel shafts on both of my T3 12's. Running 17.5 blinky and 13.5 boosted on carpet with composite outdrives. No major wrecks or anything, just get a little greedy on a corner now and then, tag a board and bend a shaft. Had to use a 50mm set while waiting on parts but they don't sit deep enought in the compsite cup and I broke a couple of the outdrives. We run the CRC track system and it's pretty solid but, I've had many Xrays and never bent a shaft till the 12.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 04-14-2012, 05:37 AM   #2195
Anyone else had problems while using 50 mm driveshafts in front with composite outdrives? I would like an explanation for these driveshaft problems in general since I never had these problems with my other Xrays
Old 04-14-2012, 05:43 AM   #2196
I have bent one front & one rear 52mm 2012 drive shafts I run twice a week on high grip carpet about 6-8 packs a session, and I also noticed that the 50mm front shafts do break the plastic out drives much more often. The explanation I was told was how far they sit in the cup, & I am hitting with the wheels turned.
However the quality of this kit is the best I have ever owned, the plastic is strong & I am confident I can finish a race with this car.
I can only compare to the tc6 I started with, and I prefer the strength of the X-ray
Shortbusallstar is offline   Reply With Quote
Old 04-14-2012, 07:12 AM   #2197
alecladanga's Avatar
Originally Posted by syndr0me View Post
Dear Exotek,
Please make something like the Tamiya ECS that will fit the XRay. Thanks!
Arrowmax and atomic make ecs for Xray as well
alecladanga is offline   Reply With Quote
Old 04-14-2012, 07:51 AM   #2198
defcone's Avatar
Trader Rating: 15 (100%+)
Spec-r make the exact thing, the material they use will bend in a hard hit though.
defcone is offline   Reply With Quote
Old 04-14-2012, 10:28 AM   #2199
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
What are the differences between the t3r and t3 12? I am looking at a t3r and then buying the Exotek xr3 upgrade. would that give me the same thing as a t3 12 running the Exotek xr3 upgrade (besides the cf towers).
Serpent, KO Propo, Viper, Savox, ProTek
Team Waldorf Racing
Your not lapping me, you just caught up to me again!!!
rdlkgliders is offline   Reply With Quote
Old 04-14-2012, 12:32 PM   #2200
Is it true that 50mm wear the composite outdrives faster than 52mm's?
Old 04-14-2012, 12:34 PM   #2201
Super Moderator
Slo_E4's Avatar
Trader Rating: 58 (100%+)
Pretty much. The 50's don't sit deep enough in the cup. Outdrives will break easier with 50's. Wear should be about the same.
Slo_E4 is offline   Reply With Quote
Old 04-14-2012, 01:18 PM   #2202
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
R1WURKS will have some out soon
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 04-14-2012, 07:07 PM   #2203
pcar951's Avatar
T3R won't give you the east/west servo setup, you'll get steel turn buckles and I think just fiberglass towers and the old inner camber link mount setup. You'd have to buy a lot of parts besides the XR3 chassis to build up a 12.
Jim Chapman
Old 04-14-2012, 08:40 PM   #2204
Thanks Pcar,
I can't Talk my son into the serpent so we can share parts. He wants an xray.
Team Waldorf Racing
Old 04-15-2012, 12:04 AM   #2205
oops, wrong reply.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
