Old 04-08-2012, 06:27 PM   #2101
locked's Avatar
Originally Posted by WIITA View Post
Hey there guys, Just picked up a 2012. I have the rear belt on the loosest setting and its still not as loose as I would like it. Is there another belt guys would recommend or is there a way to stretch the xray one? Any suggestions is much appreciated.
Rear belt for a T.O.P. Photon. I have one in my Mod car. I recently snapped the kit one and the track was all out of XRAY belts so I put a Photon belt on. It fits just slightly more loose, but definitely fits well. Probably exactly what you are looking for.
The low friction white belts aren't as strong as their standard black belts.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 04-08-2012, 06:40 PM   #2102
stro3579's Avatar
Trader Rating: 20 (100%+)
Originally Posted by or8ital View Post
Perhaps binding of the CVDs? Or steering throw is too much and you are losing grip?
Nothing is binding nor is there to much throw. If there was to much throw, I think the car would just swing the back end around. The car is not loosing grip either, just seems to pause for a sec to complete turn. I don't know any other way to explain it. Other cars at the track seem to carry more corner speed then my car in off power corners.
stro3579 is offline   Reply With Quote
Old 04-08-2012, 06:53 PM   #2103
Trader Rating: 19 (100%+)
how much rear droop do you have?
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 04-08-2012, 06:58 PM   #2104
gawith0413's Avatar
Trader Rating: 73 (100%+)
How are you guys rounding the edges of your chassis?
gawith0413 is offline   Reply With Quote
Old 04-08-2012, 07:11 PM   #2105
stro3579's Avatar
5mm on down stop rear
2mm rear droop
5mm ride height.
My set up is basically Eric Anderson snowbird set up. The car works great, I just want it to roll more in the mid corner, instead of hesitating. I don't know if it's to much roll in the rear or what.
Old 04-08-2012, 07:15 PM   #2106
2mm rear droop
5mm ride height.
I would try increasing rear droop over ride height, People may think its crazy but on a downstop measurement im at 3.0 to 3.5mm which equates to about 4.5mm over ride height. This makes the car have great off power steering and corner speed. I literally cant keep people away from my pit asking questions about why my car rotates so well when they are having issues getting theirs to. Also, you may want to increase front droop as well, this allows the car to roll more overall, resulting in better grip, which ,of coarse, results in better steering and corner speed.
Also, what roll centers are you running as well as your inner camber link positions.
Hope some of this helps! -Randy
★Randy Banks★
Old 04-08-2012, 07:23 PM   #2107
stro3579's Avatar
I will try that. But I for got to mention I removed the rear sway bar due to lack of rear traction to get more roll in the rear. The car now has traction, but pauses in mid corner in the rear. Maybe the car isn't rea ting quick enough in the rear to corners. Dunno? But will try anything
Old 04-08-2012, 07:26 PM   #2108
Put the rear bar back on, and then try what i posted above. If you would like my complete setup, please feel free to shoot me a PM. I am not a team driver for anybody except for my battery company, but with this setup, TQ'd and won over multiple team drivers for TOP/ Xray/ AE and also one from serpent. Let me know. -Randy
★Randy Banks★
Old 04-08-2012, 07:36 PM   #2109
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by haywood View Post
Tamiya Ecs part #? Direct fit?
They won't fit. I was just dreaming.
syndr0me is offline   Reply With Quote
Old 04-08-2012, 07:39 PM   #2110
Trader Rating: 38 (100%+)
Too much throw would plow the front tires. The front tires can break loss rather than steer the car if it's too much. Sounds like you've checked it though.
or8ital is offline   Reply With Quote
Old 04-09-2012, 02:05 AM   #2111
alecladanga's Avatar
Hi guys
I'll be running my t3 12 soon at a local track (asphalt, low - medium grip, 13.5 with boost). Any suggestions on where place the eccentric holder for the rear belt? The standard on the kit (middle position) is just too tight for me and is currently placed 2 notches looser.
Just want to know the other's set up and experience before i run my baby and surely not want to spend on rear belts.
Thanks in advance.
alecladanga is offline   Reply With Quote
Old 04-09-2012, 02:24 AM   #2112
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
Originally Posted by alecladanga View Post
Hi guys
Thanks in advance.
I ran my belt in the middle position but now after a month of running the car they are in the next notch to make it tighter. I think if the belts are too loose you will go through them more often.
mild seven is offline   Reply With Quote
Old 04-09-2012, 02:50 AM   #2113
Many thanks mild seven, much appreciated
Old 04-09-2012, 03:02 AM   #2114
narcotiks's Avatar
In mod drivers usually have tighter belts but in slower classes they are usually loose.
I run 21.5 boosted on outdoor ashphault and my belts are very loose, this is what everyone who runs X-ray and other cars does at our track.
narcotiks is offline   Reply With Quote
Old 04-09-2012, 03:06 AM   #2115
Thanks narcotiks
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
