Old 04-06-2012, 02:55 PM   #2086
theatriks's Avatar
Hey guys quick question im switching my gears from 64 to 48 and i noticed my xray spurs are offset in the 64p category but my 48pitch xray gears dont have an offset....might i have the wrong xray 48pitch gears for this car?
thanks
theatriks is offline   Reply With Quote
Old 04-06-2012, 05:08 PM   #2087
pchroma24's Avatar
Trader Rating: 73 (100%+)
Originally Posted by donwhit View Post
I agree that the O-ring is not needed.
What you should do is coat the mating faces of the diff cases with a thin smear of thick grease, add the gasket and screw up as normal.
I've built three this way with 700 cst oil, never a leak.
Also be sure not to over tighten the screws.
regards
Don
+1. Done this several times without incident ...
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 04-06-2012, 07:07 PM   #2088
defcone's Avatar
Trader Rating: 15 (100%+)
thanks
the cars come with a non offset spur so you will be fine.
defcone is offline   Reply With Quote
Old 04-06-2012, 11:33 PM   #2089
kinga's Avatar
Originally Posted by MikeR View Post
Hi! The included blocks give you 3 degree rear toe (w/ 0deg hubs) and .5deg front arm sweep. Front and back width is about 170mm measured from hex end to hex end when using 5mm hex hubs.
What surface/grip level is the exotek xr'12 chassis designed for? Is it deisigned to match the original chassis? I know xray recently released a soft weave 2mm chassis, is this between the kit 2.5 and the 2mm soft weave?
How would you acheive the Low roll center suspension arm settings on the chassis?
kinga is offline   Reply With Quote
Old 04-07-2012, 09:46 AM   #2090
theatriks's Avatar
ok thanks
Old 04-07-2012, 06:52 PM   #2091
haywood's Avatar
Trader Rating: 48 (100%+)
Default T3 2012
New Ride! Needs to go on the Hudy System next!
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 04-07-2012, 08:00 PM   #2092
syndr0me's Avatar
Trader Rating: 32 (100%+)
I was some Tamiya ECS in my car to go along with the Tamiya shocks. The design of those things is brilliant.
I'm a fan of the thin chassis/topdeck on carpet so far.
syndr0me is offline   Reply With Quote
Old 04-08-2012, 11:15 AM   #2093
haywood's Avatar
Default Tamiya
Tamiya Ecs part #? Direct fit?
Old 04-08-2012, 11:52 AM   #2094
stro3579's Avatar
Trader Rating: 20 (100%+)
Default T3 12 corner speed issues
I am having problems with my car completing a turn quickly (compare to other cars). My car seems to pause in the middle of a turn versus going in and out. I don't have any issues with the car steering on power or off. Just the mid corner hesitation. Any suggestions?
stro3579 is offline   Reply With Quote
Old 04-08-2012, 12:12 PM   #2095
Trader Rating: 38 (100%+)
Perhaps binding of the CVDs? Or steering throw is too much and you are losing grip?
or8ital is offline   Reply With Quote
Old 04-08-2012, 03:26 PM   #2096
theatriks's Avatar
Hey guys im looking on the team xray setup sheets (team drivers only) and i dont seem to see any pavement setups.....just wondering how long till the drivers hit the pavement.......thanks ......Fred u here?
Old 04-08-2012, 03:47 PM   #2097
UrabusDenis's Avatar
If by pavement you mean outdoor asphalt you have two setups with impressive results- Meen's from TITC (which he won) and Hagbergs from ETS Gran Canaria (where he TQd and finished 2nd). Both setups are low grip and some small changes helped improve my car in those conditions
JQRacing - eu.jqracing.com
Blue Bird - www.blue-bird-model.com
RW mods - www.rw-mods.com
Boca Bearings - www.bocabearings.com
UrabusDenis is offline   Reply With Quote
Old 04-08-2012, 04:13 PM   #2098
theatriks's Avatar
Thanks i thought i went throught them all i guess i need glasses
Old 04-08-2012, 04:44 PM   #2099
Dave Bowser's Avatar
Trader Rating: 51 (100%+)
where is Meen's setup posted?...............can you post it here?
RCAmerica, X-Ray, Hudy, Ko Propo, Protoform, PRS, Jaco, JConcepts, SXT, RC3 Grafix, Kool-Aid, P-Nut, NEXT, www.SuperiorHobbies.com
We're going to skate to one song and one song only!
Dave Bowser is offline   Reply With Quote
Old 04-08-2012, 05:19 PM   #2100
WIITA's Avatar
Trader Rating: 41 (100%+)
Hey there guys, Just picked up a 2012. I have the rear belt on the loosest setting and its still not as loose as I would like it. Is there another belt you guys would recommend or is there a way to stretch the xray one? Any suggestions is much appreciated.
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
