Old 03-20-2012, 12:42 PM   #1891
pchroma24's Avatar
Trader Rating: 79 (100%+)
Originally Posted by Manson View Post
I would like to fit tamiya shock on my t3.
What is the best way to put it on.
Tamiya caps with tamiya gold balls ? Or xray caps with xray balls ?
If you don't mind a bit of machining/drilling... You can open the Tamiya threaded top rings to 9.1mm... They will then accept the xray original top caps... Makes for a nice factory look and the Tamiya shocks of course work awesome... I've done this several times with out issue... Hope it helps ....
If you can't explain it simply, you don't understand it well enough... Einstein
pchroma24 is offline   Reply With Quote
Old 03-20-2012, 03:14 PM   #1892
Bigz84's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Matt W View Post
Hey,
Could someone please explain the different handling characteristics between adding a 1mm spacer between the front shock and tower and also adding a 1mm spacer between the front shock and tower but also running a 1mm spacer at the bottom on the wishbone?
I know both of these changes calm the front end down but im assuming in different ways?
I think I've read by Fred H on here by adding the shim on the arm along w/ a shim on top does nothing but move the shock out, which does nothing. Only add a shim on top, which calms the initial steering. If i'm wrong, someone please chime in. I've read only add to the top of the shock. Hope this helps.
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Motiv : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 03-20-2012, 04:48 PM   #1893
jag88's Avatar
The way I think of it is as if I'm holding a pipe in my hand. Put a blob of weight on each end of the pipe. Slide the weights out to the ends of the pipe and try to quickly rotate the the pipe back and forth. It's difficult to make the pipe change direction quickly because you have to over come the inertia of the weights. Now move the weights in toward your hand and it becomes easier the closer the weights get to your hand.
I think of the shocks as those weights. Put spacers behind the shocks and it becomes a little harder for the chassis to change direction quickly. It mellows out the chassis especially in high speed chicanes.
jag88 is offline   Reply With Quote
Old 03-21-2012, 11:17 AM   #1894
4skinz80's Avatar
Trader Rating: 15 (100%+)
does the kit come with a spur gear... if so what size? on xray's website I could only find what the 11 came with?
also whats a good FDR to shoot for with 17.5 boosted? 5.5?
Losi 22 & B44.2
Banning hours raceway
I want to be fast... My car just won't do what my mind tells it too;)
If you Aint First Your Last!!!
4skinz80 is offline   Reply With Quote
Old 03-21-2012, 11:30 AM   #1895
Trader Rating: 19 (100%+)
You'll want to replace the spur straight off the start. It comes with an 84t 48 pitch spur gear. With 17.5 boost I would shoot for about a 6.0 fdr. Just remember that boost in these is like boost in a real car, the more you put through the engine, the faster it will be, plus motor temps will be lower with a 6.0 to a 6.4 fdr
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 03-21-2012, 11:40 AM   #1896
4skinz80's Avatar
thanks... What do you recommend? 64 pitch? or just a different tooth 48p?
Losi 22 & B44.2
Old 03-21-2012, 12:53 PM   #1897
Questions?? t3`12 plastic vs alu shocks - rebound
Hi guys,
I got me a t3`12 for this year outdoor racing, though I'm really having a hard time getting the rebound on the plastic kit shocks even on all 4, without air in it.
I might be doing something wrong here, but I doubt it cause I tried every possible way described on the internet, and the manual.
Now I remember reading somewhere that the Alu shocks (308306-O) are much easier to set the rebound on.
My question is, is this really the case? I have seen the manual, and it definitely looks easier, but is this really true? Cause to be honest, the instructions to set the rebound for the plastic shocks seems easy too.
I hope you guys can help me out.
Patrick
Patrick_S is offline   Reply With Quote
Old 03-21-2012, 01:18 PM   #1898
locked's Avatar
Originally Posted by Patrick_S View Post
Hi guys,
Patrick
Call me crazy, but I don't mind a little rebound. I minimize the amount by pushing the center of the bladder in with the shaft of a paint brush (or something similarly blunt like the eraser on a pencil) while making sure the piston is just a few mm from the top of the shock. Then when you put the cap on, don't tighten it too much. You can adjust the rebound a bit by how tight the cap is on, to get them all even.
If you want 0 rebound, drill a small hole in the plastic top piece so air can escape when you tighten the cap. A hot pin will also work for making a little hole.
Just to be clear, don't do this on an assembled shock. You just want a hole in the very top, not through the bladder.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 03-21-2012, 01:32 PM   #1899
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Hi guys,
Patrick
I feel like getting absolutely zero rebound can be hard. Too little oil and you get air; too much and you have rebound. Typically, I try to get the rebound equal left and right (maybe 2mm max) on each end of the car. To me, it's more important they have the same relative internal pressure versus getting all the rebound out of it and possibly introduce some air.
I don't think the aluminum shocks are warranted unless you are like some who can't stand plastic shocks on their $500 racing kit.
Just my 2cents.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 03-21-2012, 02:04 PM   #1900
Bigz84's Avatar
Hi guys,
Patrick
go to page 105 on this thread. Perfect way to do it. Alum shocks are not needed to do it. I know the alum shocks have the bigger pistons, 1.0 to 1.1, if you want a little more traction. My plastic shocks are set w/ 0 rebound, but it was a pain to do it before i read this.
i hope this helps
Old 03-21-2012, 08:27 PM   #1901
Meradin's Avatar
Do you have a post count, page count changes as each person changes the page preferences.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 03-21-2012, 08:33 PM   #1902
Shock build tips are post #1565
Xray T3 2012
Simon
Team_Krusty is offline   Reply With Quote
Old 03-22-2012, 02:14 AM   #1903
RC MARKET's Avatar
A+ New Option Parts for T3
Adjust Alu. Lower Suspension Holder -0.5mm
RC MARKET is offline   Reply With Quote
Old 03-22-2012, 03:38 AM   #1904
Locked: I have yet to figure out what kind of % rebound I like. I started with the basic setup for the t3, that would be 25% of rebound. I tried the way you described, only thing I did different is I put the bladder in the cap of the shock, and then screw it on. But after the shock cap was screwed on the shock shaft would push it self out (100% rebound). lol I even used some spare plastic shims from the kit to make sure all shocks were pressed in the same amount of mm before I screw the top cap on.
I have my shocks on 25% right now (after like 7/8 tries), only problem now is that when I pull the shock shaft out it sucks it self back 1/1.5mm in? I guess this is a problem?
Dane: I'm not trying to get 0% rebound. And no I'm not one of the guys who think the plastics look ugly, IMO they look kinda nice with the orange bits, just a pain to build again IMO.
All others: Thanks for your answers, going to try a couple more things.
Patrick
Old 03-22-2012, 04:57 AM   #1905
locked's Avatar
try pushing the bladder into the shock body gently and let excess oil seep out over the rim before putting the cap on.
Dave Locke
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
