Old 03-14-2012, 06:34 AM   #1831
Skiddins's Avatar
Originally Posted by Matt W View Post
Are you looking for more initial steering or more middle to exit?
Ideally both, but perhaps mainly mid, I'm having to slow too much for corners.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-14-2012, 07:25 AM   #1832
sagejyoung's Avatar
how much smoother would the car be with the ceramic ball bearing set from xray? any one bought this and tried it? im looking at making the change if need be. some help appreciated.
sagejyoung is offline   Reply With Quote
Old 03-14-2012, 07:45 AM   #1833
Xpress's Avatar
I think you'd be better off just buying the cheap $1 bearing and just tossing them when they get a little gritty.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-14-2012, 08:05 AM   #1834
theatriks's Avatar
Can somebody explain arm sweep to me please?
theatriks is offline   Reply With Quote
Old 03-14-2012, 09:53 AM   #1835
jag88's Avatar
...not needed. take the money and buy extra tires.
jag88 is offline   Reply With Quote
Old 03-14-2012, 01:34 PM   #1836
Send a message via AIM to Matt W
Default Setup ideas for west london
Skiddins
Ive had a look at your setup and here's a few ideas-
+ First thing try a 1.3 front roll bar (loads of steering)
+ Raise front ride height to 5.5, same as rear to give front end more roll
+ Lay down rear shock (better rotation middle to exit)
+ 1 degree front toe out instead of 0.5 ( better steering around sweeper and initial turn in, also better stability)
+ lower ackerman to 1mm or 0mm to get more mid to exit steering
+ Lengthening front turnbuckle link will give you more mid to exit steering as well.
Hope some of those ideas help!!
Matt W is offline   Reply With Quote
Old 03-14-2012, 01:50 PM   #1837
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Is the Center Mount servo thingy released yet? In stock anywhere, I can't seem to find it anywhere.
http://www.teamxray.com/teamxray/pro...ount%20-%20Set
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 03-14-2012, 03:38 PM   #1838
Skiddins's Avatar
Cheers. Although I started with the longer front link (middle)
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 03-14-2012, 03:47 PM   #1839
Skiddins's Avatar
Originally Posted by Mb3195 View Post
The front of the top deck has had a slot put in it, the slot in the middle was increased on the front end.
With the chassis, 0.75mm has been taken in on both sides front and rear in each of the corners. If you compare it to yours you will see the down stop parts on chassis seems to stick out further on the photos.
You can also see the servo has been moved fully inboard!
I noticed the Exotek T3'11 chassis (which I just removed) is narrower along each side than the kit '12 chassis.
Despite the extra cutouts the current '12 chassis feels almost identical when flexing it in my hands to the Exotek 11 chassis.
Skiddins
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 03-14-2012, 03:59 PM   #1840
theatriks's Avatar
Skiddins
Skiddins
hey skiddins with all this set up talk can u explain to me what arm sweep is?
Old 03-14-2012, 05:00 PM   #1841
Skiddins's Avatar
Is or does?
It's when you put thicker shims at the front of the front wishbone pivot block and use thinner shims at the back of the front wishbone.
Effectively giving the front arms a 'swept back' look.
I believe it's supposed to help with turn in at corner entry.
Although when I've tried it outdoors it's been of limited use, I think it requires good grip to begin with and on tight carpet tracks it can make the car hook on sweeping corners
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 03-14-2012, 05:24 PM   #1842
Bigz84's Avatar
Trader Rating: 15 (100%+)
Default sweep
Is or does?
both actually. i think i know what it is but not sure.
On your setup for more steering, have you tried to lower or remove the 2mm spacer on the top of your shock. i found that having that spacer, made the steering lazy, to me. I have recently gone to the short link in the front and i like it for steering, and if i went longer, middle link, that also made the steering slower.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 03-14-2012, 05:41 PM   #1843
Skiddins's Avatar
The 2mm is for arm sweep, not on the shock.
I also started with middle hole front links and went to shorter, which helped.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 03-14-2012, 08:09 PM   #1844
haywood's Avatar
Trader Rating: 48 (100%+)
I'm looking too?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 03-14-2012, 11:09 PM   #1845
sagejyoung's Avatar
yea thanks guys, should i change the bearings for a smoother drive train? do the xray ones work? and should i go the ceramic route?
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
