Old 03-12-2012, 11:22 AM   #1801
Originally Posted by DOTMAN View Post
No...put them in the oven
of course tire warmers!!
btw - don't get them too hot. I used about 50 degreesC on my warmers
DOTMAN is offline   Reply With Quote
Old 03-12-2012, 05:01 PM   #1802
gonzo416's Avatar
Trader Rating: 39 (98%+)
Oh! I just happen to have a Much More oven.
gonzo416 is offline   Reply With Quote
Old 03-12-2012, 05:03 PM   #1803
Trader Rating: 23 (100%+)
I did that once...
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 03-13-2012, 10:04 AM   #1804
Send a message via AIM to Matt W
Default Rear flex
Hi,
Can you take the middle screws out of the rear of the top deck to give that end a bit more flex and grip?
Matt W is offline   Reply With Quote
Old 03-13-2012, 10:43 AM   #1805
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Matt W View Post
Hi,
Yes. I remove top deck screws frequently, it makes a noticeable difference on the track.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 03-13-2012, 11:31 AM   #1806
Default Rear flex
Its just that ive bought the solid rear suspension block to sort the toe issue out which also reduces rear chassis flex. I thought I might be able to put some rear flex back by taking out two of the rear topdeck screws!
Old 03-13-2012, 12:00 PM   #1807
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Hi,
Yes some guys do that but they take the front 2 screws out....Not the middle ones. If you look the rear screws attach to the bulkheads. The front screws attach to the motor mount/layshaft mounts. If you take those it allows the chassis to flex there. If you take the middle ones out it is still tied to both sets of bulkheads and doesnt allow flex.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 03-13-2012, 12:29 PM   #1808
Skiddins's Avatar
EA
Will that gain steering or rear grip?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-13-2012, 12:30 PM   #1809
Team EAM
Rear grip. It will flex between the layshaft mounts and rear bulkhead mounts.
EA
Contact Us
Old 03-13-2012, 12:42 PM   #1810
I've taken the Dremel to mine, taken the chassis 1.5mm narrower and trimmed the front of the top deck. Car now flexes equally front and rear, car goes miles better!
Mb3195 is offline   Reply With Quote
Old 03-13-2012, 01:35 PM   #1811
Can you post some pics of your mods, Im sure every one would find this use full
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 03-13-2012, 04:12 PM   #1812
theatriks's Avatar
Ok so i bought these xray weights hoping for a clean install but maybe im not understanding but i cant see how u can screw these in with the battery stops in place and only the 10g ones screw in the 5 g i guess u gotta double side tape down???? IDK maybe anybody whos using these can explain to me or did i just buy overpriced weights
theatriks is offline   Reply With Quote
Old 03-13-2012, 04:24 PM   #1813
Skiddins's Avatar
Questions??
First meeting back at West London for a couple of months and found I was struggling a bit for steering.
It may partly be down to me trying to carry too much corner speed and actually acheiving the opposite.
This was the setup I ended on;
http://piez0r.com/Skiddins/Xray%20Se...%2011-3-12.pdf
I also tried 1.5mm shims at the front wishbones (no arm sweep), 2.8F & 2.6R springs.
0 & 1mm ackerman shims, shocks more upright, 1mm at the steering link knuckle and HPI Pink(F) and silver(R) springs.
Also 1mm at he front upper clamp
The biggest change was making the front upper link shorter which helped.
Didn't have time to try making the rear link longer, or reducing rear toe in.
Rear grip wasn't an issue unless I really tried to provoke it.
Would changing to the 2.0mm chassis give me a lot more steering?
Any idea's?
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 03-13-2012, 04:39 PM   #1814
Sorry but those weights weren't made for the 2012 kit. I just double side tape them in. The parma tape holds them nicely and comes off without any mess
Old 03-13-2012, 04:57 PM   #1815
Default Need a little help!
I just put my car together last week and raced Sat.night. I am using the jointed front 50mm cvd's.I am getting some binding and broke a composite outdrive....should I be using the 52mm? or should I just use the stock units?
TWILL is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
