Old 03-05-2012, 03:36 PM   #1726
dragont's Avatar
Originally Posted by UrabusDenis View Post
Anyone tried putting shrink tube over the joint to prevent the pin from moving? My pins are now with flat spots but I'd like to be absolutely sure they won't move again
Yes, I have and still currently in use. So far so good...the pin no longer move. It works very well.
HOY BAKLA!!!! U DA BU LA'IA!!!!!!
dragont is offline   Reply With Quote
Old 03-05-2012, 03:38 PM   #1727
Trader Rating: 30 (97%+)
for high grip carpet, should i use the standard top deck or go with the 1.6mm I have both, but since my wires are attached to the standard top deck, its really a lot of work to switch and did not want to do it if its worse thanks
zaraz is offline   Reply With Quote
Old 03-05-2012, 04:21 PM   #1728
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Matt W View Post
Hi,
Im having trouble getting even toe in at the rear of the car, ive got 3 degrees one side and 2.5 the other.
I read somewhere that if you use the solid rear suspension holder (302048-O) instead of the two piece it will solve this, is this correct and will i notice any difference in handling?
You can try flipping the arms left to right and the hubs too if running zero degrees... sometimes the arms have variances in toe due to nylon shrinkage factors... what Bigz84 said also +1.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-05-2012, 04:44 PM   #1729
Skiddins's Avatar
Looks like you're going to test it for us
Why do you have wires attached to your top deck?
You really don't want anything attached as it may reduce flex in one direction etc.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-05-2012, 04:54 PM   #1730
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Originally Posted by Bigz84 View Post
I have also read on this thread that you can loosen the lower susp holder screws once the car is assembled and re tighten. (302046). This should solve the rear tow issue. I was a .5 degree off too until i tried this, and now they are both equal. Give it a try.
Tried the loosening/tightening thing, but didn't work... so I just added the shim, like you did, to get it closer to where I needed. It's fine now, I guess. I'd still like a better answer as to WHY this occurs. Is this an oops by Xray?
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 03-05-2012, 05:16 PM   #1731
Bigz84's Avatar
Trader Rating: 15 (100%+)
that sucks, sorry bout that. i have equal shims left to right, and both sides are dead on. i have heard that there is a manufacture error, but i don't know how much truth there is to that. I have read too that you really don't feel the difference in rear toe. i ran the 1/2 degree off in rear toe for a couple months and when i did the fix above, i really didn't feel a difference.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 03-05-2012, 06:26 PM   #1732
I was wondering if anyone has used this chassis yet
http://www.teamcrc.com/crc/modules.p...prodID=7719218
VORRA; www.RVAHobbies.com; www.ashfordhobby.com; www.tqwire.com
bgrick is offline   Reply With Quote
Old 03-06-2012, 04:47 AM   #1733
Send a message via AIM to Matt W
Default Rear toe
Still having trouble with rear toe being un even so decided to switch the lower suspension bulheads left to right and then ended up with 2.5 degrees left and right so have added a 0.4mm shim and now it seems even, very odd!!
Matt W is offline   Reply With Quote
Old 03-06-2012, 04:58 AM   #1734
sagejyoung's Avatar
the car has arrived - will literally start the build in less than 5 hours time and trawled through this thread for build tips... what a machine... very impressed.
sagejyoung is offline   Reply With Quote
Old 03-06-2012, 08:13 AM   #1735
theatriks's Avatar
anybody use the exotek chassis yet ....just wondering because if it improves handling the 50 dollar price tag might make it worth it
theatriks is offline   Reply With Quote
Old 03-06-2012, 08:18 AM   #1736
Trader Rating: 38 (100%+)
Which size ECS would you use with a front gear diff with steel outdrives?
or8ital is offline   Reply With Quote
Old 03-06-2012, 08:35 AM   #1737
Skiddins's Avatar
If you mean the one that was designed for the T3'11 originally, I'm running it.
Problem is I haven't yet run the proper T3'12 chassis (on order)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-06-2012, 08:35 AM   #1738
Regional Moderator
CarbonJoe's Avatar
Why run ECS with a front gear diff? It's not a spool, so it will have some diff action no matter what weight fluid or putty you put in there. Just run the stock CVD driveshafts. Besides, I thought you were running a TC6.1?
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-06-2012, 08:38 AM   #1739
theatriks's Avatar
the one on the exotek site it says its for the t3 and not the t3 11
Old 03-06-2012, 09:19 AM   #1740
I was curious and I still do wonder which it would be. CVD or ECS I am curious the length.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
