Old 02-27-2012, 08:03 AM   #1621
theatriks's Avatar
Originally Posted by Daddycool View Post
Hi guys
I have a noob question which I am sure has been answered in the past but I am hoping since the brushless motors have been around for longer now I can draw on some of your experiences.
Basically I am looking for a 17.5 sensored motor for my xray T3 thats fast and reliable and doesnt get too hot as I am in Adelaide and the weather here can sit above 30C for long periods of time.
I have tried to find a Corally 17.5 pro red but they dont make them anymore.
Any suggestions or opinions would be welcome and dont hesitate to point out any motors that are crap
Marius
Apparently the schuur speed motors are the new kick asses to get
theatriks is offline   Reply With Quote
Old 02-27-2012, 07:12 PM   #1622
bozzplayer's Avatar
Trader Rating: 16 (100%+)
lol, how many do u own Rob
bozzplayer is offline   Reply With Quote
Old 02-27-2012, 07:48 PM   #1623
Default 2012 spur gear... Offset?
I'm looking at the kit spurgear and I don't see any offset to this gear. What part of the gear is offset on the 2012? I'm getting ready to order gears but not sure if I really need an offset gear since the gear looks centered on both sides
Brian Marz is offline   Reply With Quote
Old 02-27-2012, 08:18 PM   #1624
bozzplayer's Avatar
if you look close enough you will see one side is flat while the other side has some depth to it
Old 02-28-2012, 03:05 AM   #1625
Skiddins's Avatar
It's to do with the width of the spur in the centre, where it mounts against the layshaft.
You do need the offset spurs.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-28-2012, 04:02 AM   #1626
sagejyoung's Avatar
just ordered my kit! should be here in time for nationals.
sagejyoung is offline   Reply With Quote
Old 02-28-2012, 02:02 PM   #1627
Xpress's Avatar
I've noticed that on several of Hagberg's setup sheets he has been running a little bit of arm sweep in the front. He lists 2mm shims between the front roll center block and the arm mount....
Anybody know where to get 1mm or 2mm shims the same dia as the normal Xray ones?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 02-28-2012, 06:10 PM   #1628
Trader Rating: 19 (100%+)
Use all the kit shims and oils in all the specified places, make sure everything is nice and free and smooth, and the car is dialed out of the box! I ran mine for the first time last week on 2 different race days and TQ'd and won both days!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-29-2012, 12:22 AM   #1629
ByteStream's Avatar
The Xray lower suspension shims are 3mm x 7.5mm x thickness.
Xray sells them in 0.4, 0.75, 1.15 and 1.5mm sizes
0.4 x 5 = 2mm
If you are willing to go to a little smaller shim, 3x7x1 or 3x7x2 you can find them all over with a quick search.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 02-29-2012, 12:29 AM   #1630
sagejyoung's Avatar
hey thanks! i saw the car was dialled out the box with a mate of mine at a club raceday. Going to change the gear diff oil to 1000 from the 700 supplied - apart from that will run it from kit setup - i have a friday off to test the car the day before we start qualifiers - i also have a photon which i will use to test against the car and make a decsion on which to use that weekend. seems i'll be more than likely going with the Xray for that weekend.
Old 02-29-2012, 12:51 AM   #1631
Ariel Reds's Avatar
Team Max EP Terengganu.
Kuala Terengganu Radio Control Club.
Joy and Passion, its all about.
Ariel Reds is offline   Reply With Quote
Old 02-29-2012, 01:09 AM   #1632
sagejyoung's Avatar
Originally Posted by Ariel Reds View Post
how neccessary would it be to have both sets of ECS's the 50mm and the 52mm - has any one tried this? does it make a 'massive'/noticable difference in the cars handling using the 50mm's over the 52mm's? for around $160 for both sets seems a little excessive.
Old 02-29-2012, 01:38 AM   #1633
defcone's Avatar
Trader Rating: 15 (100%+)
I went from kit 52mm spring steel ones to 50mm spec r ones and only noticed a little less tendency for the car to kick around mid corner. If you want, you could just buy the different length dog bone for the ecs and change them that way.
defcone is offline   Reply With Quote
Old 02-29-2012, 01:50 AM   #1634
sagejyoung's Avatar
was thinking that. if i cant get consistent without playing with everything else i would consider it. thanks
Old 02-29-2012, 05:54 AM   #1635
theatriks's Avatar
Its on its way .....but if u knew how to read u would see i said "apparently" which would mean i dont own one myself ....but we can go over the english language next race day if u like
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
