Old 02-21-2012, 06:50 PM   #1531
Fred Hubbard's Avatar
Originally Posted by theatriks View Post
Would you be able to elaborate on those 50mm shafts and there usefulness?
The shorter length changes the "plunge point" of the entire drive shaft and results in a car that transitions faster, especially noticeable on tracks with chicances.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 02-21-2012, 07:02 PM   #1532
Trader Rating: 19 (100%+)
Originally Posted by Fred Hubbard View Post
You definitely want 50's as they are a valuable tuning option.
Thanks Fred, Im assuming because there are more width options with them then with the 52's. I just wasnt sure if they would go into the outdrive cup on the spool far enough to keep from breaking them really easy. Thanks!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-21-2012, 08:36 PM   #1533
ByteStream's Avatar
50mm ECS ..
If your running 2mm+ shims on the bulkheads and using the plastic outdrives, IMO you'll most likely break them as the pin on the driveshaft does not sit far enough into the cup. I've seen them break with 1.5mm shims on the bulkheads as well but less often.
The cheapest option for you is to shim out the outdrive by putting a washer in between the outdrive and where it connects to the spool. You'll need to grind the washer into a square-ish shape as so that it will fit into the spool part.
Of course you can also get aluminum outdrives that use blades.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 02-22-2012, 12:57 AM   #1534
hanulec's Avatar
Trader Rating: 23 (100%+)
50mm ECS work great w/ Side Piece Racing Nikita Outdrives - http://sidepieceracing.com/products/nikita/
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-22-2012, 03:58 AM   #1535
alecladanga's Avatar
just to contribute: I currently use the 50mm ECS and at one point, broke the pins. Instead of buying flat pins or any other kind, i cut from an old xray stabilizer (hard) and used it as replacement and had no issue since
alecladanga is offline   Reply With Quote
Old 02-22-2012, 05:24 AM   #1536
haywood's Avatar
Trader Rating: 48 (100%+)
+1
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 02-22-2012, 08:54 AM   #1537
spammy's Avatar
+2
____________
Leighton Lederer
{R/C Plus Salem Oregon}
spammy is offline   Reply With Quote
Old 02-22-2012, 10:10 AM   #1538
Ariel Reds's Avatar
hello
can i know what is the T3 turnbuckle wrench size?
Team Max EP Terengganu.
Kuala Terengganu Radio Control Club.
Joy and Passion, its all about.
Ariel Reds is offline   Reply With Quote
Old 02-22-2012, 10:17 AM   #1539
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Ariel Reds View Post
hello
Alumn turnbuckles are 4mm. The smaller spring steel ones are 3mm.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 02-22-2012, 12:41 PM   #1540
Default savox for t3'12 - SC1251MG or SC1257TG
Hello,
what servo you suggest for t3'12 ?
Since it have more space for it.
SC1251MG low profile alu gears
SC1257TG titanium gears standard profile.
farm is offline   Reply With Quote
Old 02-22-2012, 12:51 PM   #1541
I have been running the 52's in front as well as the rear....no wonder why it seems a little lazy on a tighter track...Would you run 50 in the front as well as the rear, or only in the front to make it transition faster?
NPETRO is offline   Reply With Quote
Old 02-22-2012, 04:39 PM   #1542
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www.exotekracing.com/dampener...ollar-for-trf/
Dialed! I wonder if the holes in the caps are large enough to fit XRay mounting hardware without modification?
I've had to replace my bladders due to swelling or tears in the XRay shocks on every rebuild. That's $10-12 to rebuild shocks.
syndr0me is offline   Reply With Quote
Old 02-22-2012, 04:52 PM   #1543
haywood's Avatar
Run 52's in the rear for stability and 50's in the front for a more aggressive feel!
Old 02-22-2012, 04:53 PM   #1544
haywood's Avatar
No doubt... I am sick of buying bladders!
Old 02-22-2012, 04:55 PM   #1545
artwork's Avatar
Trader Rating: 54 (100%+)
Looks like Tamiya plastic on the top of the shock and Xray on the bottom that connects to the arm...
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is online now   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 06:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-17-2011 12:58 AM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 04:11 PM
SEO by vBSEO 3.5.0
