Old 02-20-2012, 03:38 PM   #1516
theatriks's Avatar
Originally Posted by artwork View Post
Just in case anyone cares I did update my spring rate comparison document...nice resource to have at the track. Hope you find it useful!
Ive got so many spring charts of all the manufacturers and none of them are every the same lol
theatriks is offline   Reply With Quote
Old 02-20-2012, 04:11 PM   #1517
luigib646's Avatar
Default XRAY t3 2012
I'm selling a X-ray t3 2012 roller used 1 time at the track
$400
Car is brand new
Pm me.
luigib646 is offline   Reply With Quote
Old 02-21-2012, 03:51 AM   #1518
Skiddins's Avatar
Did you measure those yourself?
I made up a similar chart from other people's testing a while back;
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 02-21-2012, 07:36 AM   #1519
Send a message via AIM to Matt W
Default Pins coming out
Hi,
Appart from using the top racing axle pin covers is there a way of stopping the driveshaft pins slowly sliding out? Im using the xray pins with the flat and also using threadlock, Im usually very gd at building driveshafts but i am having a little issue with the front ones, any ideas?
Matt W is offline   Reply With Quote
Old 02-21-2012, 07:56 AM   #1520
spammy's Avatar
Originally Posted by Matt W View Post
Hi,
You can use shrink wrap on them you will never have that problem but they will still break though.
___________
Leighton Lederer
{R/C Plus Salem Oregon}
spammy is offline   Reply With Quote
Old 02-21-2012, 09:26 AM   #1521
Ariel Reds's Avatar
its hard to me to find the shaft with the flat spot, what i do is I use silicone paste and cover the hole with it. It works but need to re-check after few run, and last longer if use high quality one
Team Max EP Terengganu.
Kuala Terengganu Radio Control Club.
Joy and Passion, its all about.
Ariel Reds is offline   Reply With Quote
Old 02-21-2012, 10:02 AM   #1522
Skiddins's Avatar
If you get a chance can you try and measure the newer Tamiya TRF springs, they are all white but have a small piece of colour at one end.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 02-21-2012, 10:12 AM   #1523
theatriks's Avatar
Can u use 52mm ecs shafts with the multi diff when its locked as a spool?
Old 02-21-2012, 01:54 PM   #1524
nerdling's Avatar
Yes.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 02-21-2012, 01:55 PM   #1525
nerdling's Avatar
Looking at ourfitting my T312 with Titanium screws, are there any screws on the T3 that I should not change over?
Old 02-21-2012, 04:22 PM   #1526
Trader Rating: 19 (100%+)
Hey guys, just got my car and am ging to start building it probably tomorrow. I was wandering if the 50mm ecs's will work okay with the stock setup without any problems. I ask because my lhs has the 50's in stock, but not the 52's thanks!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-21-2012, 04:46 PM   #1527
haywood's Avatar
Trader Rating: 48 (100%+)
Yes! They work fine. I believe that they handle a little different then the 52's.
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 02-21-2012, 04:47 PM   #1528
Fred Hubbard's Avatar
If you are running exclusively on carpet then you can change them all, if not then leave only the screws under the chassis steel.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 02-21-2012, 04:48 PM   #1529
You definitely want 50's as they are a valuable tuning option.
Old 02-21-2012, 05:42 PM   #1530
theatriks's Avatar
Would you be able to elaborate on those 50mm shafts and there usefulness?
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
