Old 02-18-2012, 12:05 PM   #1501
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Originally Posted by David G View Post
Love the idea, have a set on the way. With this you can't see joint and maybe more protected for grease leaving and carpet etc getting in. For indoor carpet use, how often do you take apart this setup for either re-grease or cleaning?
I take them apart to inspect, clean and re-grease when I notice carpet fuzz in the joint that can't be easily removed with tweezers, or if I notice binding in the drive train somewhere. So, probably every 3 race weekends or so.
Our carpet fuzzes a lot, so on newer carpet it may not be required as often. I clean them more often when running on asphalt due to the dust and grit on the track.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 02-18-2012, 03:31 PM   #1502
theatriks's Avatar
Hey guys i have aluminum c hubs and aluminum rear uprites and aluminum knuckles for sale if anyone is interested
theatriks is offline   Reply With Quote
Old 02-18-2012, 08:41 PM   #1503
smilekt's Avatar
Originally Posted by Ariel Reds View Post
okay thanks!
first run yesterday, after couple minutes, i broke my rear upright and the CVD just gone i had problem with the pin and the upright seem not very tough as I not accident while i test it
very good English writing... easy to understand ..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 02-19-2012, 04:12 AM   #1504
Ariel Reds's Avatar
sorry noob quetion here! what brand of spur will fit perfectly other than xray one? example like associated, xenon, RW racing and 3racing, which one?
Team Max EP Terengganu.
Kuala Terengganu Radio Control Club.
Joy and Passion, its all about.
Ariel Reds is offline   Reply With Quote
Old 02-19-2012, 06:52 PM   #1505
Zainy's Avatar
Smile
Hi bro,
Go for RW for xray... ( TPracing )
Zainy is offline   Reply With Quote
Old 02-19-2012, 09:04 PM   #1506
Ariel Reds's Avatar
Originally Posted by Zainy View Post
Hi bro,
haha okay thanks bro
Old 02-20-2012, 12:29 AM   #1507
blade072's Avatar
Trader Rating: 98 (100%+)
also arrowmax will fit perfectly......
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 02-20-2012, 04:45 AM   #1508
NR
NR's Avatar
Trader Rating: 52 (100%+)
I can't build anything to save my life
When you do the gear diff up is oil suppose to seep out a little????
I have done everything the instruction says and can't get it right, I HATE that black o ring more than anything in the world
NR is offline   Reply With Quote
Old 02-20-2012, 05:30 AM   #1509
Ariel Reds's Avatar
for me, the CVD drive me crazy
Old 02-20-2012, 07:22 AM   #1510
M-Technic's Avatar
Trader Rating: 15 (100%+)
Maybe a tiny bit, but it really shouldn't leak. You might be filling the diff with too much oil. I try to replace the rubber o-ring AND the paper seal each time I open up the diff. Make sure the 4 center gears are seated in all the way and fill with oil til it's about half way up the center + piece that holds the 4 gears. When in down, underfill rather than overfill. Then make sure the o-ring and seal are in place properly and it shouldn't leak.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-20-2012, 07:30 AM   #1511
Ariel Reds's Avatar
the gear diff assembly is very crucial, once you do it wrong, your life will be in miserable
Old 02-20-2012, 09:40 AM   #1512
Danny-b23's Avatar
That black o-ring really isn't needed. I just used some Green Slime where the ring would normally go. Built up 2 diffs this way with relatively light oil and I haven't experienced any leakage so far.
Also, when you're building your diff, the half that you put oil in should be 7.90 grams totally dry, and 9.20 grams when filled to the correct point with oil. So if you have a pocket scale, that is a pretty accurate way to do it.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 02-20-2012, 01:21 PM   #1513
Skiddins's Avatar
I've found the best way was to actually put the O-ring onto the other half on the diff housing from the one suggested in the manual
I actually put it onto the lip in the other half, then with my finger put some of the oil onto the o-ring.
When you put the two halves together I lower the thinner half very carefully down onto the larger half which contains the oiul and the o-ring
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-20-2012, 01:52 PM   #1514
artwork's Avatar
Trader Rating: 62 (100%+)
Just in case anyone cares I did update my spring rate comparison document...nice resource to have at the track. Hope you find it useful!
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 02-20-2012, 02:06 PM   #1515
Johnny Wishbone's Avatar
The missing Holly Grail of spring charts......thanks Art.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
