Old 02-16-2012, 08:07 PM   #1486
smith9turbo's Avatar
Originally Posted by Ariel Reds View Post
okay thanks!
first run yesterday, after couple minutes, i broke my rear upright and the CVD just gone i had problem with the pin and the upright seem not very tough as I not accident while i test it
sorry for you, but it often to happen for original XRAY CVD.
you should read this page, we talk about XRAY CVD
page 97 => Xray T3 2012
on that page, we talk about this option too...
this TIP... it so good for me, and it can solve my XRAY CVD PIN problem.
if you don't do something about XRAY CVD,
you may be lost all 4 CVD and both upright and both steering box. with PIN loose problem.
smith9turbo is offline   Reply With Quote
Old 02-16-2012, 10:36 PM   #1487
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by 303slowdown View Post
I recently got the vbc t32f chassis and clamps through crc and am very happy with the quality and performance of the kit. I would recomend it if your in the market for something a little different.
I was thinking of getting one of these. I noticed that crc says the T32S is the stiff version and the T32F is the flex version, while VBC claim the other way around. I was inclined to believe VBC as the S version only has a 2mm chassis...
How does it feel on whatever surface you are running on, compared to the stock '12 chassis?
silvalis is offline   Reply With Quote
Old 02-16-2012, 11:04 PM   #1488
I would imagine the f stands for flex and s stands for stiff?
Mb3195 is offline   Reply With Quote
Old 02-17-2012, 01:46 AM   #1489
silvalis's Avatar
Thats what would make sense.
But the F version has a 2,5mm chassis and the S a 2,0mm
Old 02-17-2012, 04:29 AM   #1490
gonzo416's Avatar
Trader Rating: 39 (98%+)
Maybe the F=Firm and S=Soft.
gonzo416 is offline   Reply With Quote
Old 02-17-2012, 04:35 AM   #1491
blade072's Avatar
Trader Rating: 98 (100%+)
the f version may be thicker but it has less carbon due to all the cutouts.....hence it has flex..if it was a full chassis like the s then i would say it is firm but that just isnt the case....would hate to think how flexy it would be in 2mm carbon....
full deck = stiff
swiss cheese = flex
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 02-17-2012, 05:16 AM   #1492
Ariel Reds's Avatar
ohh i see thanks!
i will change it, but i noticed that the kit come with Medium rear upright and knuckle right?
Team Max EP Terengganu.
Kuala Terengganu Radio Control Club.
Joy and Passion, its all about.
Ariel Reds is offline   Reply With Quote
Old 02-17-2012, 05:28 AM   #1493
ohh i see thanks!
my XRAY T3 2012 KIT come with
Knuckle(Steering box) H
C-HUB H (4L, 4R)
rear upright 0-degree M
(H=Hard, M=Medium)
Old 02-17-2012, 05:38 AM   #1494
Ariel Reds's Avatar
C-HUB H (4L, 4R)
upright M 0-degree
(H=Hard, M=Medium)
oh sorry, maybe i'm made the mistake
so far, i managed to get rid of the rear belt problem
Old 02-17-2012, 06:24 PM   #1495
Trader Rating: 19 (100%+)
new t3 2012 on the way
I was wandering if anybody knows if the spec-R BD-5 ecs shaft will work in the front of this car, I ask because i am switching from a photon and have like 4 sets of these things and dont really want to have to restock on new ones. Thanks!
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 02-18-2012, 06:13 AM   #1496
narcotiks's Avatar
Hey guys
Had a head on Collision with a barrier today , my antenna wire came in contact with power wires and I lost control
The front toe is now en even and on neutral throttle th car is banking to the right.
the front steering links are of equal length but the toe is out of allignment.
I just checked it on the setup system and I'm pretty sure one side is 2 degrees more than the other ...
What parts should I check out that could be bent or semi broken?
And to fix the toe back to normal , should I change the steering link length or should I add spacers to the rear arm mount thing?
Thanks in advanced
narcotiks is offline   Reply With Quote
Old 02-18-2012, 06:34 AM   #1497
locked's Avatar
Originally Posted by narcotiks View Post
Hey guys
Thanks in advanced
Check the suspension mount screws. They can bend in a hard impact and throw off the alignment. Check these after any run with a impact. If the screw wobbles around when you loosen it, replace the screw.
Make sure the aluminum suspension mounts aren't bent.
Check that the servo horn/saver didn't move and that the turnbuckle didn't bend or get yanked out of the ball cups a bit.
Always a good idea to check the bearings after a good hit. The outer wheel bearing are the ones that tend to have an issue first. If one side is binding more than the other, it will usually pull toward the side with the bind.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 02-18-2012, 06:37 AM   #1498
Regional Moderator
CarbonJoe's Avatar
Most common: hinge pins, hinge pin screws, front bulkheads, hinge pin holder aluminum T shaped part, steering links.
Less likely: broken A arm, broken steering knuckle, bent axle.
I would find out what's bent. Changing only the steering rod length will give you unequal steering left and right.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-18-2012, 06:41 AM   #1499
defcone's Avatar
Trader Rating: 15 (100%+)
The ball size of the cvd is different. You could try covering the ball with some heatshrink and see if it will fit like that.
defcone is offline   Reply With Quote
Old 02-18-2012, 11:15 AM   #1500
Originally Posted by HarryLeach View Post
It's hard to see in pictures of the TOP retainer, but they have a decent lip on one side that keeps them from sliding over the whole joint. Once installed in the bearings and hubs, there's no wobble, some slight inboard/outboard play, and when installed the cross pin is never uncovered.
Is it perfect? No, but it does work very well.
Love the idea, have a set on the way. With this you can't see joint and maybe more protected for grease leaving and carpet etc getting in. For indoor carpet use, how often do you take apart this setup for either re-grease or cleaning?
- David Gillis
RACE TECH HOBBIES (Where the racers shop)
XRAY T3 2012
David G is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
