Like Tree1Likes
Old 11-16-2011, 07:36 AM   #121
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
New TCS Class for 12th scale...
1/12 GT
Recommended Minimum Skill Level: Advanced; Experienced racer with proficient driving abilities.
1/12th scale pan car racing has been around for decades. Tamiya is once again part of the action with its new, modern designed RM-01 chassis (RM=Racing Master). The 1/12 GT class is a new class to TCS and is perfect for advanced to expert racers that enjoy direct drive pan car handling with realistic body choices offered by Tamiya.
About the RM-01
The Tamiya RM-01 chassis is a direct drive pan car with a pivot ball rear link suspension and front independent suspension using a king pin design.
1/12 GT Basic features:
Pan car chassis design
Solid rear axle/2WD direct drive train
Uses foam tires
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-16-2011, 07:45 AM   #122
YR4Dude's Avatar
Trader Rating: 44 (100%+)
1/12th scale with Tamiya foams. That should be interesting.
YR4Dude is offline   Reply With Quote
Old 11-16-2011, 08:03 AM   #123
Tamiya 12th scale Foams were the bomb back in the day.
Old 11-16-2011, 08:41 AM   #124
ghoppa's Avatar
Trader Rating: 50 (98%+)
now this car looks fun!!!!
RCAmerica - Xray - R1 Wurks - ActivRC - Hudy - ApexRC - Jgo Paintz - P1 Brands - 702 RCRaceway
ghoppa is offline   Reply With Quote
Old 12-06-2011, 11:42 PM   #125
This thread needs some updates
Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-rm-01_b.jpg   Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-rm-01_956.jpg   Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-rm-01-vs-rm.jpg
Old 12-07-2011, 01:54 AM   #126
That's the 956 body but the body post holes and wheel wells are not cut out...is that the Frewer copy or is that how Tamiya is doing the car now? Is is out?
Old 12-07-2011, 09:12 AM   #127
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
anyone have an idea of the release date for then US?
madjack is offline   Reply With Quote
Old 12-07-2011, 10:19 AM   #128
FMW
FMW's Avatar
The RM-01 is as we say in the business..."On the water".
The expected date they arrive at our warehouse in So Cal is December 16 or there about. From there they will be shrunk wrap and sent to Hobby Distributors that have them on order from TA.
Thanks to RedbullFIX for taking our sample kit and helping us figure out the options we have in mind for TCS rules and what motor/battery combo would best suit the Tamiya car.
FMW is offline   Reply With Quote
Old 12-07-2011, 10:33 AM   #129
YR4Dude's Avatar
Team Blue Groove
http://www.ebay.com/itm/TBG-ROTHMANS...item2311f499cd
Old 12-07-2011, 10:38 AM   #130
YR4Dude's Avatar
Who has this on order so that we may know where to look to place a pre-order?
EDIT: Nevermind, just found it at Tower for 189.99
http://www3.towerhobbies.com/cgi-bin...?&I=LXBUUJ&P=7
and this from Google
http://www.rcplanet.com/ProductDetai...4_a_7cTAM58509
Old 12-07-2011, 11:16 AM   #131
madjack's Avatar
Thanks for the clairification FMW.
"here come santa clause, here comes santa clause..."
Old 12-09-2011, 04:32 PM   #132
FMW
FMW's Avatar
Tower Hobbies has them on order.
http://www3.towerhobbies.com/cgi-bin...8509&search=Go
Old 12-09-2011, 07:47 PM   #133
YR4Dude's Avatar
I wonder why Stormer Hobbies don't have it listed on their site. They usually have all the latest for 1/12 pan.
Old 12-11-2011, 05:27 PM   #134
More updates.
Hope to have it wired up soon.
Found a simple way to use standard 64p spur gears.
72t will not clear the diff backing plates, 78t fits fine.
Standard 12th rear wheels fit, but maintaining ride height will require larger diameter tires than most 12th scale cars run, Tamiya apparently wanted this car to run 52-45mm tires, try much smaller than that and the chassis will run out of clearance.
Options I see are to use Tamiya RM-01 foams, or F1 foams.
Full size Jaco Rear tires will work, just...
To check max rollout, that's a 78x55 gear for 116+mm roll and stock 52.5mm tires.
Gear selection shouldn't be an issue for 17.5 blinky 1s where 85-110mm roll are the average over a broad range of motors and tracks.
Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-34s.jpg   Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-41s.jpg   Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-42s.jpg
Old 12-11-2011, 05:52 PM   #135
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Thanks Dave, keep the updates coming.
What do you think:
1) how does the plastic look? Is it stiff enough vs. durable enough?
2) how does the body length appear? Looks like it's long in both the front and rear, will it affect running on a tight track?
3) does the front ride height look easily adjustable? Standard shims or something else? Standard rear ride height adj or Tamiya unique?
4) would you run the 380 motor when you run against us so we have a chance?
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
