Old 10-06-2014, 09:52 AM   #1096
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by IAmGreatDane View Post
Thanks, RedBullFIXX :-)
I had a look in the manual thinking raising the antenna and pitch damper post (K9?) in order for my shorty to fit below the pitch damper. Will this bold move effect the pitch damping and the handling of the car overall?
Thanks!
If on high grip surface, yes, if not ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-06-2014, 11:36 AM   #1097
IAmGreatDane's Avatar
Ok, thanks again :-)
I do not if you are asking me a question or it's a typo. Anyway, I get the picture 2S is no go in a RM01 :-)
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 11-07-2014, 11:23 AM   #1098
Clawhammers's Avatar
Tamiya RM-01X with Protoform PFM-12
Clawhammers is offline   Reply With Quote
Old 11-16-2014, 03:19 PM   #1099
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Do low profile servos fit this car? Such as a futaba S9551?
RCBuddha is offline   Reply With Quote
Old 11-16-2014, 07:13 PM   #1100
ShadowAu's Avatar
Yes - I have been using this exact servo myself up till recently
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 11-16-2014, 11:33 PM   #1101
RCBuddha's Avatar
Thanks for the reponse!
Old 01-02-2015, 02:03 PM   #1102
Which tyres/wheels are those? yokomo GT? Direct fit?
prorace is offline   Reply With Quote
Old 01-02-2015, 07:19 PM   #1103
Front & Rear Tires/Wheels Set = Yokomo GT500
Front axle = Tamiya #54366 - Front Axle For 1/8" x 5/16" Bearing
Rear wheel hub = Tech Racing conversion kit RMGT01 Type-R (from Japan)
Old 01-02-2015, 08:14 PM   #1104
ShadowAu's Avatar
Whats the hex size in the Yokomo wheels?
Old 01-04-2015, 12:13 PM   #1105
Sorry for the late response I am still on holiday, and IF I'm not mistaken....
Hex size of Yokomo rear wheel hub = 12mm
Hex size of original RM-01 rear wheel hub = 9mm
Old 01-05-2015, 02:28 PM   #1106
ShadowAu's Avatar
Old 01-20-2015, 08:24 PM   #1107
its been a long time since i ran my rm-01.... 2 years
so to day i was sick at home, missed work...read every page from start to finish
basicly (took a rc day)
so tonight pulled out my rm01 . took it apart and got it running
i have a few questions now.
do you need any bearings for the RM-01 Spur Gear Adapter?
my kit will only run club 13.5 binky
there is a few dif tamiya tires for this kit what are the differences?
would i just use hbr foams? what are new tamiya foam size? to fig out rollout?
some one said to use sunscreen spf 30? to attach the tires... really?
do they still sell rm01x?
thanks for any help
TeamThibault is offline   Reply With Quote
Old 01-20-2015, 08:47 PM   #1108
No, the spur gear adaptor rides directly on the axle
Kit tires are good all around tires for asphalt or carpet, they wear a bit faster than the Option tires
the Option tires are also good for tuning grip levels
Sunscreen is used on asphalt surfaces to soften the tires externally, not to attach them
Yes
thanks for any help
TQRC have nearly everything you could need for the RM-01 kits HERE
For questions about 1/12 scale tuning, rollout etc
Please check the link in my sig
Old 01-21-2015, 02:22 AM   #1109
ShadowAu's Avatar
thanks for any help
What he said
The only thing I will add from my own experience is that option fronts and kit rears offer the best wear/grip balance
Old 05-16-2015, 10:19 AM   #1110
Love this car......but can't convince the touring car guys around me to bite. So I will be running this just for my own pleasure. makes me want to run some rubber tires on it if it is just going to be me. Has anyone managed to fit some M Chassis rims/tires on this? Thank you.
JJ
jujubean is offline   Reply With Quote
