Old 08-20-2014, 02:32 PM   #1081
Originally Posted by Gurneyflap View Post
2S battery ? I'm surprised as mine don't fit, too thick.
I'm running mine with a 2cell battery and 17.5T motor.
The battery is a 2cell in a hardcase of a 1cell battery, so they fit without any problem.
addicted2blue is offline   Reply With Quote
Old 08-20-2014, 03:00 PM   #1082
thanks, didn't think about this before.
Gurneyflap is offline   Reply With Quote
Old 08-21-2014, 01:13 AM   #1083
Clawhammers's Avatar
There are various types of 2S battery with 1S dimension being sold in Japan.
The common dimensions are =
93mm x 46.5mm x 18.5mm
The range of average capacities are between 2800 Mah - 3500 Mah
Clawhammers is offline   Reply With Quote
Old 08-26-2014, 03:25 AM   #1084
Hi,
I have couple of questions, as follows:
1. How to measure the rebound stroke for RM-01X as seen in its Setting Sheet ?
2. As regards Upright Spacer, I am under the assumption that this is the spacer we used inside (before) the front wheel ?
Please correct me if I'm wrong.
Thank you
Old 08-26-2014, 05:17 PM   #1085
ShadowAu's Avatar
Originally Posted by Clawhammers View Post
Hi,
As I read it, rebound stroke is more or less how far down the suspension can move.
Upright spacer is (again as i read it) the spacers put under the ball end to change the angle of the steering arm at the steering block
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 08-27-2014, 12:29 AM   #1086
Thanks for your explanation ShadowAU
Just measure my rebound stroke is around 2.0 mm
And I didn't insert any spacer under the ball end in my front arm.
Old 08-27-2014, 12:30 AM   #1087
Btw
I just created an editable setup sheet for Tamiya RM-01X
It is in PDF format, and the size is 1.80 Mb.
This can be downloaded from =
http://pdfcast.org/pdf/editable-tami...-setting-sheet
Hope this can be useful
Old 08-30-2014, 02:26 PM   #1088
Tamiya RM-01X Outlaw
Finally .... finished it just now
Gonna use it tomorrow first thing in the morning
Old 08-30-2014, 02:27 PM   #1089
Background:
Tech Racing from Japan produces conversion kit for Tamiya RM-01, namely RMGT01 Type R
It's pricing is quite cheap for a conversion kit
Source Link =
http://www.rakuseimodel.co.jp/online...p?jisya=166493
This conversion kit consists of lower deck and lower brace set, including aluminum outer wheel hub for rear wheels, which allows us to apply the wheels and rubber tires of Yokomo GT-500
Front Wheel Setup
1 pair of Tamiya Front Axle 1/8 x 5/16 - #54366
1 pair of Yokomo GT-29 Wheels
1 pair of Yokomo GT-36M Slick Rubber Tires
2 pairs of Flanged Bearing 1/8 x 5/16 x 9/64 for front wheels
Rear Wheel Setup
1 pair of Tech Racing aluminum outer wheel hub
1 pair of Yokomo GT-30 Wheels
1 pair of Yokomo GT-36S Slick Rubber Tires
Note that both Front and Rear wheels require 3mm lock nuts
The diameter for Yokomo GT-36 slick rubber tires = 57 mm
The minimum ground clearance = 5mm (for both Front and Rear)
Front Ground Clearance
5mm (aftermarket) spacers are inserted under the front arms
The standard front arms’ screws are 4x20mm (BB1 @front side) and 4x15mm (BB2 @rear side)
For using the 5mm spacers, I have to replace it with 4x25mm countersunk screw for front side, and use BB1 for the rear side
Rear Ground Clearance
2mm offset rear shaft holder
The standard screw for Tamiya’s outer wheel hub is 2.6x6mm (BB5).
The thickness of Tech Racing’s outer wheel hub at the left side is 4mm, which is thicker than Tamiya’s standard (2mm). Therefore, I replace the standard screw with 2.6x8mm screw
Old 08-30-2014, 02:29 PM   #1090
My initial setup for local outdoor asphalt circuit
Old 08-31-2014, 12:35 AM   #1091
IAmGreatDane's Avatar
Clawhammers, I love your outlaw :-)
And a first for me to see the RM01 with rubber tires. Did you purchase the conversion kit directly from Japan (using the link you've posted)?
A job well done :-)
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 08-31-2014, 12:14 PM   #1092
A job well done :-)
Thank you IAmGreatDane
I purchased my RC parts from Rakusei through Japanese buying agent.
http://www.personalshopperj.com/
They are reliable and very prompt in providing services to overseas customer(s).
Hope this helps
Old 10-06-2014, 07:12 AM   #1093
I am correct in assuming that 2S lipo is no go in the RM01, yes?
My shorty lipo is approx. 96mm x 47mm x 25mm. And yes I did read the previous post about the issue. I just hope somebody has way around this annoying issue :-)
Thanks!
Best Regards,
Old 10-06-2014, 07:48 AM   #1094
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thanks!
There are many 2s lipo available in 1s size
1/12 in general are not built for 2s sized packs
http://www.teamyokomo.com/product/battery/battery.html
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-06-2014, 08:56 AM   #1095
Thanks, RedBullFIXX :-)
I had a look in the manual thinking raising the antenna and pitch damper post (K9?) in order for my shorty to fit below the pitch damper. Will this bold move effect the pitch damping and the handling of the car overall?
Thanks!
Best Regards,
SEO by vBSEO 3.5.0
