Old 04-28-2014, 07:31 AM   #1036
CSeils's Avatar
Trader Rating: 48 (100%+)
Anyone have a suggestion for a good/small receiver for this car?
I am using a Futaba 3PM with a Speed Passion esc. I don't want to try and get the 603FF that comes with the radio to fit in such a small area. Also looking to save some weight.
Any suggestions will be helpful.
Thanks.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 04-30-2014, 02:16 PM   #1037
Wyvern95's Avatar
Thanks.
I don't know of a smaller receiver but I can tell you a 603FS (same size as 603FF) will fit, as well as a 1S voltage booster, Novak Club ESC (roughly same footprint as a Speed Passion Reventon) and a full size servo (Futaba S3050).
Tamiya 1/12 R/C RM-01 "Racing Master"-image.jpg
Wyvern95 is offline   Reply With Quote
Old 05-01-2014, 10:23 PM   #1038
Clawhammers's Avatar
Hi, I am looking for some suggestions for tires.
The available tires at nearby LHS are quite limited, as follows :
Front Tires
Tamiya Standard (#51483) / High-Grip (#54334)
Shepherd Hard (SH12AFH)/Medium (SH12AFM)/Soft (SH12AFS)
JACO Double Pink/Magenta/Black
Rear Tires
Tamiya Standard (#51484) / High-Grip (#54335)
Shepherd Hard (SH12ARH)/Medium (SH12ARM)
JACO Yellow/Magenta/White/Gray
We run at medium grip asphalt (outdoor), which of the above combination would be better ?
Clawhammers is offline   Reply With Quote
Old 05-02-2014, 02:50 AM   #1039
ShadowAu's Avatar
Front Tires
Rear Tires
I am not the most experienced with my RM, but so far the best all round tyre combo has been the Tamiya tyres. Last time I raced I used the option fronts and standard rears, mostly because the option fronts actually last longer (the grip isn't THAT much different in my experience). Using Tamiya tyres also negates the limited ride height adjustment.
With the Jacos, Yellow and Black are supposed to very similar to the Tamiya tyres.
Wouldn't bother with the Shepherds unless you can get soft rears (notoriously hard to get in my experience). They don't seem to match up with anything else. I've tried Med and Hard fronts with a variety of Jaco Rears (Pink, White, Yellow) and Tamiya Rears and they just don't balance. Maybe if you need a LOT of steering somewhere.
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 05-02-2014, 09:01 AM   #1040
@ShadowAU
Thanks for sharing mate. I haven't thought the ride height adjustment to my consideration.
I guess the Tamiya's option front and standard rear would be the better combination.
1 last query, if I use HW 13T motor with FDR of 2.500 and 1s 3.7v 2000mah battery, then (theoretically) how long would this foam tires last on asphalt ?
Would it last for (at least) 3 (or 4) full battery charges ?
Old 05-02-2014, 09:19 AM   #1041
masterhit's Avatar
Trader Rating: 14 (100%+)
There are a couple options that deal with the ride height issue.
Tuning Haus makes aluminum ride height adapters that will get you -2.5mm which is about max without grinding.
Alpha Giken lets you use a standard 1/4" axle and gives a lot of ride height range. Around -3.5mm offset.
TRG Again up to -3.5mm offset with the stock axle.
You will need to grind the screw hole for flipping the plastic piece though to get the max ride height with the Alpha and TRG adapters. But I can't imagine ever using the high position with 12th?!?!?
Mike Slaughter
masterhit is offline   Reply With Quote
Old 05-02-2014, 05:01 PM   #1042
ShadowAu's Avatar
@ShadowAU
That's a hard one to answer because it will depend on how abrasive the asphalt is. To give a personal example - I recently raced on a medium grip track and I manged to make one set of Tamiya tyres last 5, 8 minute races - mind you I was 4 laps slower than the fastest guys but in comparison they used 3 sets of fronts to my 1 set for the meeting.
To be honest I find front ride height far more of an issue than rear. I have the Tuning Haus inserts and haven't used the 2.5 yet as I simply haven't worn tyres small enough or been on a track smooth enough to need it. Even on outdoor asphalt I am running around 4.5mm to 5.0mm ride height.
Old 05-04-2014, 12:26 AM   #1043
@ShadowAU
Duly noted. Thank you very much for your explanation and sharing mates.
Old 05-17-2014, 11:14 PM   #1044
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
TCS Race at TQRC tomorrow
Mazda is fun to drive
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-17-2014, 11:41 PM   #1045
Nice specs
Good luck tomorrow and look forward for your result
Old 05-20-2014, 12:45 AM   #1046
nitrojamie's Avatar
Hi redbull im all the way over here in new zealand and ive just got the rm01 with mazda 787bbody. Can you tell me how you found the body handling wise compared to the higher down force bodys on the market . I ask this because we run 12th with mod motors here of around 5.5turn with lipo batts and were not aloud tyre aditives of any kind.
Cheers jamie
Tamiya f104v2/rm01
nitrojamie is offline   Reply With Quote
Old 05-20-2014, 06:22 AM   #1047
niznai's Avatar
Hi guys, just a quick question and I'm out of here. Can anyone let me know what is the diameter of the pivot balls used on this car? Tamiya item # 51485.
Thank you.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-06-2014, 08:37 AM   #1048
Hi Guys
Never drove any of these 1:12 cars but I'm a bit curious.
Wondering about the Tamiya since I kind of like Tamiya.
With the EFRA using modified or 10.5T motor I'm wondering about some "few" things.
What spurs and pinions is usable with a 540-motor?
What batteries are good for 1:12?
With the standard set from Tamiya, what MUST be swapped out to make the car work on a track?
Artificial intelligence is no match for natural stupidity
NoBrainer is offline   Reply With Quote
Old 07-06-2014, 05:37 PM   #1049
ShadowAu's Avatar
Originally Posted by NoBrainer View Post
Hi Guys
Still a lot of grey in those questions -
What class are you intending to run? 1S 540 would be so slow you could outrun it on foot
Most 1/12 classes run 1s batteries but I have read about some 2s 21.5T classes existing. As for what brand that's for you to decide but I will say a lot of us here in Australia haven't had any complaints with the Turnigy 1S packs (ROAR approved of course).
Are you thinking of an RM-01 or 01X? The 01X has most of the options out of the box but even the 01 works pretty well in standard form. The 01 also comes more complete package out of the box with body and tyres. As typical with anything Tamiya there is a full range of options available but the only things I've swapped on mine are optional oil pitch damper, the alloy motor mount and the harder option front suspension.
Overall the RM is a good car but its not really at the same level as the top brand cars. That being said I love mine and since I am never going to win anything these days anyway I don't mind it being a bit slower, given how easy it is to drive.
Old 07-07-2014, 08:52 AM   #1050
Cool
Hi Guys
Use the Tamiya spur gear adapter and 1/8" diffballs, with a 76-78t 64p gear, and 64p pinion, which are standard on all 1/12th cars
Any 1s lipo
The Kit form RMX is an out of box racer, some have bolted on an AE or Xenon front end for more tuning options
Check in with the local racers at your track for tips on motor, battery, electronics, tires, and setup help
The RM-01(X) can use springs from other cars, as settings are often similar across many different makes in 1/12th scale
Tamiya Option front, kit rear foams, are as good as any tire available, only drawback, is you have to mount them yourself
To use standard pre-mount 1/12 wheels I recommend
RC RM01 Front Axle - For 1/8" x 5/16" Bearing
And rear wheels will need a decent off-set to keep front/rear wheel-track similar
Spur Gear adpater
SEO by vBSEO 3.5.0
