Old 04-02-2013, 11:30 PM   #871
xsracer's Avatar
Originally Posted by CSeils View Post
Finally finished with decals and paint. Time to hit the track.
Nice work!
xsracer is offline   Reply With Quote
Old 04-08-2013, 08:54 PM   #872
CSeils's Avatar
Trader Rating: 48 (100%+)
Can i use the spur gear adapter #54459, to mount a regular R&R spur or is there a different part?
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 04-14-2013, 07:47 AM   #873
gdiddy's Avatar
http://www.stellamodels.com.hk/84335...is-p-7061.html
Tamiya 1/12 R/C RM-01 "Racing Master"-ta84335.jpg
The desired effect is what you get when you improve your interplanetary funksmanship.
gdiddy is offline   Reply With Quote
Old 04-14-2013, 06:26 PM   #874
Originally Posted by RedBullFiXX View Post
Start with a 78t 64p spur gear
rollout is dependent on track size and motor
90x45 carpet
17.5 - 103mm
13.5 - 90mm
ish
RedBull what will be the best use spur and pinion for 3,5r brushless motor....it will be using on the medium grip asphalt track with 45m straight line..
also which tamiya foam tire will be best used on this type of track...
Cheers
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 04-14-2013, 10:22 PM   #875
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cheers
Wow 3.5
This is a very fast motor, not so easy to drive
96t Spur, 20t (ish) pinion should get you close
I have not tried such short gear on the RM-01 so you may have to experiment to see what fits ?
I would recommend you have very true tires with that much rpm
Jaco Pink Rr, Purple Fr perhaps ?
Tamiya kit tires are very good for stock racing
Tamiya Hop-Up tires have more grip than kit tires
Please post results with this experiment
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-18-2013, 11:39 PM   #876
what non tamiya body fits with no problems
bkdent is offline   Reply With Quote
Old 04-19-2013, 01:54 PM   #877
You should be ok with any 12th scale body
So long as all electronics are mounted low profile
Old 04-19-2013, 03:51 PM   #878
OK thanks for the reply
Old 04-21-2013, 09:54 PM   #879
well i tried to mount a arm12 body but the front of the body rubs on the small post on the front arms, i was trying to mount the body highth even with the bottom of the chassis, is this to low. i noticed that crc bodies are slightly higher in the front, maybe i should try one of the crc bodies
Old 04-22-2013, 06:03 PM   #880
Wow 3.5
i"ll let you know how its goes...
by the way is there any information how to setup 1:12...
i have read some information from this forum but most of them just inform you to use this or that but do not explain clearly what the function really are...
for example: change the oil in pitch damper lighter or heavier... or change the spring infront stiffer or softer... but did not explain if you change the spring stiffer it will make the car react more or less to steering input...
the reason i ask this question is that i do not want to setup my car according to someone else setup which i believe their setup up must be different from my tack...so i want to be able to correct the car quicker by understanding how to fix the problem quicker...
Thanks Guys....
Old 04-22-2013, 07:49 PM   #881
Lots of RM racers use AMR12, perhaps you have the body mounted too far back ?
Thanks Guys....
Tons of build/setup info in my sig...
In my experience, a proper kit build of a 12th scale car + correct tires, will get you most of the way there
Tuning is a fine adjustment for feel as the track grip changes
Tires, and sauce will have more effect, than changing any base settings
Old 04-24-2013, 11:02 AM   #882
Core Creations's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Core Creations
If anyone is interrsted...new in box kit for sale...
Tamiya RM01 Porsche 956 Brand New! Cheap!! TCS
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 04-24-2013, 06:11 PM   #883
Default which bearing
when using option front upright shaft/axel... which bearing is use? flange bearing or normal bearing....
thanks
Old 04-24-2013, 08:22 PM   #884
thanks
With the optional metal front up right, you use the kit bearings
Old 04-27-2013, 09:22 PM   #885
greetings all! seeking advice. After a very long leave of absence, I am trying to get back into 12th scale. now for my question.. is the rm-01x worth the buy or will it benefit me to buy the base kit and pick up only the necessary hops ups? thanks!
one*eighteen is offline   Reply With Quote
SEO by vBSEO 3.5.0
