Tamiya 1/12 R/C RM-01 "Racing Master"
#843
If you look at the included parts list on the box or so there is mentioned that the chassis is a "special part" aswell as the rear axle spacer.
It's an alumlinium one and also marked as a "special part"
The chassis plate is a must have item for being able to use the full height of the tires.
I'll keep my eyes open to get that chassis plate
#844
I believe this is the new spur gear adaptor to run non Tamiya gears
#845
The one between the bearing and the wheel stopper.
#848
Registered User
Tamiya spur gear adaptor for rm-01 has been available for about 2-3 weeks now. Item number 54459. I imagine that it is identical to the one that is for the F104 too that has been around for quite a while.
#850
Registered User
Plenty of the rm-01 ones on eBay. Gt mine last week just need the spur gears for it.
#851
Registered User
#852
And the RM-01 wheels don't fit the plastic diff outdrives.
#853
#854
You can run the same gears on both cars
Only bushing/bearing size which the spur gear rides on is different
RM-01
Spur gear with bearing/bushing, mounts directly on the 6mm axle
All current & nearly every Tamiya F1 ever
Spur gear with bearing/bushing, mounts on diff-hub which slides over 6mm axle
RM-01
