Old 10-04-2011, 02:21 AM   #61
IAmGreatDane's Avatar
Default Has the rear bodymount been moved?
I like it and thanks for sharring, Kentech
The images of the Toyota is a bit blurred, but the rear bodymount seems to have been moved in front of the rearwheels. Or am I way of here?
On the original, the rear bodymount and the rear wingmount shared the same mounting on the rear pod - a lot of mounting in one sentence
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 10-04-2011, 08:59 PM   #62
DaveG28's Avatar
Trader Rating: 58 (100%+)
Are you guys sure it'll take a 540? It looks ok but might it not have the clearance underneath?
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 10-05-2011, 12:28 AM   #63
bakaguyjean's Avatar
100% sure it does.
bakaguyjean is offline   Reply With Quote
Old 10-05-2011, 12:33 AM   #64
THe wing mount is one the back of the gearbox like the F1 chassis cars.
The old method isnt bad but it limits the gearbox movement. And the wings allways fall off. The sad part it is doesnt make a difference if it has the wing or not for handling.
Old 10-05-2011, 12:51 AM   #65
Thanks!
Best Regards,
Old 10-07-2011, 01:44 AM   #66
kentech's Avatar
Electric R/C Car Series
Toyota Tom's 84C
Item No:58509
In 1985, Tamiya released a 1/12 scale R/C model of the Toyota Tom's 84C Group C race car and it enjoyed a great reputation. In recent years, the 1/12 scale class has become a very popular R/C race class once again. To re-enter this exciting class, Tamiya's Toyota Tom's 84C will be making a return on the brand-new RM-01 chassis. This new chassis features a Direct Drive 2WD setup and a Pivot-Ball Link Rear (PBLR) suspension to offer linear throttle and steering response and realistic racing action.
【 All-New RM-01 Chassis 】
This chassis features a 2.5mm thick black-colored FRP lower deck and a height-adjustable resin gear case with type 380 motor. Pivot-Ball Link Rear (PBLR) suspension system features a center pivot ball, a pitch damper to temper chassis pitch movement, and a roll damper and side links to control chassis roll. Aluminum diff housing allows ball differential adjustment without detaching rear wheel. Attachment of both hex-hub-secured and 3-screw-secured wheels are possible. Front independent suspension features optimized kingpin trail. The standard type 380 motor is installed by using an adapter, which may be removed to allow installation of type 540 motors.
Front section is designed to provide superb durability. Independent front suspension has optimized kingpin trail, offering smooth steering operation and straight-line stability.
Rear section features a Pivot-Ball Link Rear (PBLR) suspension system. Roll springs can be additionally installed for more advanced suspension settings.
Direct Drive setup features an aluminum diff housing, steel rear shaft, and height adjustable gear case. New wheel hubs allow attachment of both hex-hub-secured and 3-screw-secured wheels.
The straightforward design and optimized layout result in superb weight distribution which contributes to linear throttle response and steering characteristics.
【 Separately Required Items 】
●2-channel R/C unit with ESC.
●R6/AA/UM3 batteries for transmitter
●Item 55105 Tamiya LF Battery LF1100-6.6V Racing Pack (M-Size) & compatible charger.
Specifications are subject to change without notice.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 10-07-2011, 10:39 AM   #67
DaveG28's Avatar
Cool, definitely getting one to dabble with as my first 12th, hopefully they'll follow with a trf at some point!?
Had the original 956, it was awesome!!
Old 10-07-2011, 06:07 PM   #68
DaveG28's Avatar
That post is kind of contradictory, I should have said first 12th in a long time!
Old 10-07-2011, 06:31 PM   #69
Taman's Avatar
Trader Rating: 64 (100%+)
Had one of these when I was a kid so really looking fwd to getting one again. I'm guessing they will re release the 956 or the body set, which would be great
Taman is offline   Reply With Quote
Old 10-12-2011, 09:10 AM   #70
kentech's Avatar
You might find this interesting...
More and bigger scans @ http://kentech.blogs.se/
Old 10-12-2011, 09:25 AM   #71
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Sweet !
Thanks kentech.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-12-2011, 09:29 AM   #72
superspeed's Avatar
another collector item
superspeed is offline   Reply With Quote
Old 10-12-2011, 10:00 AM   #73
Colect if you want.
I plan on running it
Old 10-12-2011, 10:08 AM   #74
Infinite 12th's Avatar
Originally Posted by RedBullFiXX View Post
Colect if you want.
It looks like the top and side shock might be like the Agitators by Lucas G.
Also note the swept back front arms
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 10-12-2011, 11:05 AM   #75
Looks like a damper tube to me. The top shock is the same plastic one the F1 cars use.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
