Like Tree1Likes
Old 09-03-2012, 07:15 AM   #661
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Alfonso_R View Post
BTW we will be running 13.5 non boosted !
The car above is built with these hop-ups for 13.5SS (BlinkY) on high-grip carpet
For low to med grip asphalt the kit lower deck and lower brace are sufficient
Tamiya offer a side spring set, but imo the AE springs are superior, Silver, Green or black would be good to have for fine tuning
RC Carbon Rear Bulkhead Plate - RM01
RC RM01 Alum Pitch Damper Set
RC RM01 Front Axle - For 1/8" x 5/16" Bearing
RC RM01 Carbon Lower Brace
RC RM01 Carbon Lower Deck
RC Aluminum Motor Mount - RM01
RC Titanium Coated King Pin - RM01 3x31mm (2pcs)
RC Carbon Rr Body Mount Plate - RM01
RC RM01 Pitch Spring Set
Jaco/Parma wheels have the correct offset for the RM
Black front, Yellow rear are a good baseline
To add about 1mm of ride height up front remove the ring of plastic on the lower side of each upright
Also, if you do this mod, make sure to add 1mm of shim under the top e-clip, and don't use the lower e-clip
This keeps the lower clip groove on the kingpin from catching on the lower arm
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-03-2012, 03:55 PM   #662
I)arkness's Avatar
Ahh, excellent
I wondered where you removed the plastic for the extra ride height
B.Portelli
Hyper RC - Metro Hobbies - RAB Hobbies - Wild Turbo Fans
Off road - Schumacher - R1Wurks Australia (Coupon Code - R1BP5%)
On road - Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 09-03-2012, 05:00 PM   #663
Radio Active's Avatar
Also, if you do this mod, make sure to add 1mm under the top e-clip, and don't use the lower e-clip
So, if I understand correctly, you have spaced the upright down far enough that the upright sits over the lower groove in the king-pin? Does this put any additional pre-load on the front springs?
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 09-03-2012, 05:30 PM   #664
Yes, it does
And there is still some droop, and room for adjustment using silver springs
Old 09-03-2012, 05:39 PM   #665
Alfonso_R's Avatar
Send a message via Yahoo to Alfonso_R
For low to med grip asphalt the kit lower deck and lower brace are suffucient
Alright Thanks ! How is the kit holding up? how are the arms and other parts?
Alfonso_R is offline   Reply With Quote
Old 09-03-2012, 06:18 PM   #666
I'm pretty easy on parts, no issues so far
Old 09-03-2012, 06:28 PM   #667
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Hey dave
I was told that you had the jaco tires instead of tamiya tires during the TCS Nat's?...
OVA is offline   Reply With Quote
Old 09-03-2012, 06:51 PM   #668
Originally Posted by OVA View Post
Hey dave
There were a few guys that did run Jaco's, just not me
I used Tamiya Option Front, Tamiya Kit Rear
Mounted up a fresh set for the weekend, and just rotated every run
Still plenty of life left in them
Old 09-03-2012, 07:00 PM   #669
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
If they had a TRF version of this with an updated front end, i'd have this in a heartbeat!
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 09-03-2012, 07:56 PM   #670
subaru73's Avatar
Trader Rating: 41 (100%+)
Default Rm01
I also ran the same tire set up for the weekend.
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 09-03-2012, 08:26 PM   #671
I would think a graphite rear axle would have to be next on the list of option parts before a front end upgrade.
twitter: @dvcotton
Old 09-03-2012, 10:08 PM   #672
hey guys I just join RM-01 club
I know the 58509 is a basic kit but it will get me racing 1/12th
what are some starter hop ups i should be looking at as a newbie?
im running trackstar 1cell esc & nano 3.7 battery
and not sure on motor....maybe a thunder power 17.5 for stock boost
from what i read the op front tires will be on order right away
any advice would be great
hotrod306 is offline   Reply With Quote
Old 09-04-2012, 03:42 AM   #673
My RM-01 [#58509] arrived this morning.
Does anyone know what sort of run time I should expect using the Tamiya LiFE 1100 battery and the kit 380 motor ?
Cheers.
TB-03, M-03, M-04,M-05, TT-01, DF-03ra, TRF201, SCX10, Stampede
tdunster is offline   Reply With Quote
Old 09-04-2012, 07:01 AM   #674
I have 1 RM in kit form that is used for asphalt, and one indoor car with all the hop-ups
Build the car and run it, then see what if any hop-ups are necessary
Cheers.
In the states the standard is 1s lipo
Perhaps someone will chime in on how the Life battery setup works
Gratz on your new RM's
I've updated the first post on PG #1 with build tips & setup info
Old 09-04-2012, 07:37 AM   #675
Does anyone know what sort of run time I should expect using the Tamiya LiFE 1100 battery and the kit 380 motor?
I have used the life battery with the 380 motor and you can easily run op to 15 and more minutes, depending on track size and gearing.
Just make sure you don't run the battery below 6V, i usually run between 5 and 10 minutes with an ESC for brushed motors.
Just to make sure i never get the battery voltage to low, cause the ESC doens't have a cut-off build in.
For longer run times i'm using a 1/18 2 cell 7.4V lipo, this works perfect and it also gives you a higher/better speed.
With this type of battery it's even better to use the 380 sport tuned motor from tamiya.
addicted2blue is offline   Reply With Quote
