Tamiya 1/12 R/C RM-01 "Racing Master"
#601
same here. I used crc pink rear w/ the high grip tamiya fronts, and the other guys were out turning me. I even went 100%F and 0%R for sauce, but still didn't turn sharp enough. The level of grip and wear is much better than the originals though. Going to get those standard bearing axles and test other compounds...
#602
just need to fit a 5x8 MM flanged bearing in the fronts (jaco...shepherd...whatever) on the original tamiya axle.
works well!
#603
yes the turn in is too slow (onroad) i think it will go faster with more grip or even more negativ spur for more steering into. but the high grip tamiya also really good.
works well!
works well!
on another note, I tested the upper brace for the front end, and while it does make the car more responsive, I started to get outside coning. without the brace, it wore pretty evenly.
#604
this weekend is the first time testing another tyre than the tamiya.
will try the shepherd asphalt red (front/rear)
#605
works well!
works well!
Up front you will have much less width than stock
On the back you will gain much more width than stock, as CRC wheels have almost -0- offset
Not saying it won't get around the track, but it will be an odd setup for sure
So far I've found the Jaco wheels have the most offset, aside from Tamiya wheels, to keep things closer to original specs
#606
#607
More Hopup parts for RM01 are available at TQ.
http://www.tqrcracing.com/shop/produ...t.asp?s_sort=3
FYI, Thanks.
FYI, Thanks.
#608
so.
i tested the shepherd red. with a bit more negative spur. much more grip at the front.
on the rear i think the tamiya hop up are better. (could not test it, no tyres)
the track was not so clean like the last time.
#609
well, I got the front axle for the standard bearing, and tried to fit them on.
with the crc wheels, they came out to about 162mm track width. You can probably get up to 166mm with some spacers.
The problem was the ride height. But after some grinding and shaving, I was able to get the max ride height to 6mm. From there, I can add spacers to lower the car, and take them out as the tire wears.
have about 4mm of foam on the wheel. how much can I run them down until I need to replace them?
#611
#612
#615
Nice ride Baka
qty (1) 1/4 X 3/8 Unflanged bearing, 1/8" diff balls
That's the only bearings not supplied in the kit, in order to use a standard spur gear
http://www.tqrcracing.com/shop/produ...earing&pg_no=5
