Old 05-01-2012, 04:13 AM   #556
Originally Posted by Taman View Post
Somethings to look forward to:
54364 RM-01 Carbon Lower Deck
2.5mm thick carbon-fiber lower deck replaces kit-standard FRP component to increase overall chassis rigidity and bring out the chassis' maximum potential. It has an additional hole to allow installation of a small steering servo.
54365 RM-01 Carbon Lower Brace
2.5mm thick carbon-fiber lower brace replaces kit-standard FRP component to increase rigidity of the motor mount section for enhanced power transmission efficiency.
A TRF kit couldn't be too far off?
lol that's how they get you. I wouldn't be surprised if a "worlds" edition comes out allowing you to use standard tires by default. by then, our cars will be already a TRF edition
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 05-01-2012, 04:26 AM   #557
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by bakaguyjean View Post
Thanks fr the advise,I will keep searching
On a side note,here in Japan TCS does not allow any other placement of any of the front suspension besides the springs. This includes the servo saver and servo position. Its really an odd way of doing things but I think they do it to keep the car easy to drive and not so twitchy.
There is nothing "Twitchy" about this car
It is so smooth and easy to drive
I think more due to thin flexible chassis, than any servo position
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 05-01-2012, 05:25 AM   #558
bakaguyjean's Avatar
It is easy to drive but have to tried the other servo mounting positions? I have tried it just about every way you can think of. The feeling of the chassis changes alot from the normal steering postion.
You car is not to real TCS specs,its the hacked up US TCS spec. its a completely different animal useing Japan specs,I should have said that earlier.
Its a lot lighter in the rear using Japan specs.
But it is interesting to note the have restricted the servo set up.
bakaguyjean is offline   Reply With Quote
Old 05-02-2012, 06:43 PM   #559
subaru73's Avatar
Trader Rating: 41 (100%+)
Default rm01
what seems to be the best traction compound for the car for out doors?
Tamiya Ta07 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Futaba 4Px radio lrp speed control
Cfx paint works Fantom Racing apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Old 05-07-2012, 07:33 PM   #560
mdutcher's Avatar
More updates.
Hope to have it wired up soon.
Found a simple way to use standard 64p spur gears.
72t will not clear the diff backing plates, 78t fits fine.
Standard 12th rear wheels fit, but maintaining ride height will require larger diameter tires than most 12th scale cars run, Tamiya apparently wanted this car to run 52-45mm tires, try much smaller than that and the chassis will run out of clearance.
Options I see are to use Tamiya RM-01 foams, or F1 foams.
Full size Jaco Rear tires will work, just...
To check max rollout, that's a 78x55 gear for 116+mm roll and stock 52.5mm tires.
Gear selection shouldn't be an issue for 17.5 blinky 1s where 85-110mm roll are the average over a broad range of motors and tracks.
Redbull, where can I pick up a 78t 64p spur gear that you reference here? I want to try your conversion for 64p spurs.
Also, with that spur, what size of diff balls are needed?
Any help or advice would be greatly appreciated. Thanks.
AE RC10B4.2 FT - Reedy 17.5T - Dualsky - XP
AE Vintage RC10's
mdutcher is offline   Reply With Quote
Old 05-07-2012, 07:46 PM   #561
PRS spur, but I'm pretty sure a Kimbrough will work fine too
http://www.tqrcracing.com/shop/produ...ord=78&pg_no=1
I recommend using Ceramic 1/8 diff balls
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
Old 05-07-2012, 08:10 PM   #562
mdutcher's Avatar
Thank you!
AE Vintage RC10's
Old 05-09-2012, 07:23 AM   #563
which RPM do you drive with yours 540 Motors and 1S?
cossy4s is offline   Reply With Quote
Old 05-09-2012, 09:50 PM   #564
We run 17.5 with no esc boost, don't know what rpms they turn
Old 05-10-2012, 02:26 PM   #565
JamesHealey's Avatar
17.5 No Timing is about 9,000 RPM or there about
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 05-10-2012, 10:53 PM   #566
ok,
i use 2s with 380 7t. about 70.000RPM. cant use less/more than 15/104 gearing for 30mm rollout.
Old 05-11-2012, 02:49 PM   #567
A top end 3.5T 540 sized motor should give around 96000 rpm.
Most people using 3.5T gear under 30mm roll out, temperature is the limiting factor.
Old 05-13-2012, 01:38 AM   #568
Taman's Avatar
Trader Rating: 64 (100%+)
I've noticed that the front tyres (kit) seem to wear quicker than the rears. Is this more to do with my driving style (or lack there of ).
Love this car, it's so easy to drive fast. Is there any benefit to buying the Carbonfibre chassis?
thanks
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 05-13-2012, 08:21 AM   #569
I`m doing something a little different with my RM. 380 and 2C Short lipo.
Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-takoblog2.jpg
Old 05-13-2012, 09:02 AM   #570
F N CUDA's Avatar
Trader Rating: 30 (100%+)
thanks
The front tires do wear quickly, even on carpet. The option fronts work as well or better and last much, much longer.
The option rears also work very well and seem to free up the rear a tiny bit but still keep great rear grip. Both kit and option rear tires hold up very well.
Craig Hammon
F N CUDA is offline   Reply With Quote
