Old 04-02-2012, 04:15 PM   #526
Josh-n-ya's Avatar
Trader Rating: 71 (100%+)
Originally Posted by WarpdSpazm View Post
I haven't run Formula since the F201, so thanks for that Red... I'll make sure to smack my buddy upside the head. LOL
On another note... Does anyone have a recommendation on a 1S lipo? $60 for a one cell is hard to swallow when I'm paying $34.99 for GOOD 2S packs...
Turnigy from Hobby King makes a great cheap battery 1s. 24.00 Not Roar approved though!
Josh-n-ya is offline   Reply With Quote
Old 04-11-2012, 06:44 PM   #527
spring71's Avatar
Smile
RM-01 Hopups are available at TQ.
http://www.tqrcracing.com/shop/produ...t.asp?s_sort=3
Visit RM01 Parts store.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 04-11-2012, 11:08 PM   #528
Any idea when the alloy steering knuckles will be available?
racer robert is offline   Reply With Quote
Old 04-11-2012, 11:12 PM   #529
hotdognobun's Avatar
Trader Rating: 31 (100%+)
stellamodels and ebay has them. i just recieved mine today.
hotdognobun is offline   Reply With Quote
Old 04-15-2012, 08:04 PM   #530
Originally Posted by RedBullFiXX View Post
Alloy diff and hubs are included in the kit.
any special modification to use 64pitch spur?
Old 04-15-2012, 10:07 PM   #531
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
http://www.rctech.net/forum/10126876-post211.html
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-19-2012, 03:07 PM   #532
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
joined the crowd... finally!
madjack is offline   Reply With Quote
Old 04-19-2012, 06:03 PM   #533
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Nice, another excuse to run mine some more.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 04-22-2012, 01:51 AM   #534
Taman's Avatar
Trader Rating: 64 (100%+)
my rm-01 is running painfully slow, has the following
SP GT2.0 EX
SP 17.5 motor
Thunderpower 5000mah li-po
Stock Spur gear
21 tooth pinion.
My f104 has a 17.5t motor and it flys compared to my rm-01. the rm-01 even seems slow when you just run it while holding it off the ground. Any suggestions?
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 04-22-2012, 02:07 AM   #535
JamesHealey's Avatar
What is your roll out? If you are using 3.7v Lipo, most 12th guys running 17.5t run big pinions and small spur gears.
Think 80mm roll out
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 04-22-2012, 02:15 AM   #536
Taman's Avatar
to be honest I'm a bit lost when it comes to that. The tyres are 53mm in diameter if that hepls and the spur is 66 teeth. Yep 3.7V li-po. Are these cars as quick on a 1-cell battery as a car with the same motor on a 2-cell battery?
Old 04-22-2012, 10:11 AM   #537
Thats a 53mm roll out, it wants to be about 75-110mm range for 17.5 depending on track layout..
That's about a 30 to 40 tooth pinion for those size tires.
Jim.
Tire diameter x 3.14 x pinion / spur = roll out.
Old 04-22-2012, 10:16 AM   #538
14mph is your top speed at the moment
27mph is your top speed with 40 tooth pinion and 17.5t blinky.
If you were to switch to 2S which isn't race legal by the way with a 40t pinion you'd be looking at 54mph.
Btw these are theoretical top speeds, not to be taken as gospel.
Old 04-22-2012, 10:55 PM   #539
The stock spur is meant for 6.6v, not 3.7v
Voltage has a major effect on RPM
You need a 78t 64p Spur
And pinions in the mid 40s for indoor tracks, and low to mid 50s for larger outdoor tracks
You are WAY under geared
Gearchart.com is your friend for easy roll-out charts
Old 04-23-2012, 03:31 AM   #540
Taman's Avatar
Thanks Jim and RedBullFIXX, appreciate the help
SEO by vBSEO 3.5.0
