Old 03-30-2012, 04:53 PM   #511
Originally Posted by subaru73 View Post
looks like more goodies coming out.
1 RC RM01 Front Axle - For 1/8" x 5/16" Bearing
54365
I don't see the point in this when you can't raise the front of the car high enough to accommodate the low pro tires.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 03-30-2012, 06:57 PM   #512
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Josh-n-ya View Post
Who was that battling with Dave, and are all of those RM01s? Always fun to watch racing on a lunch break!
That's my bud Matt Bell leading at the start with a Pink/Green R5-inline.
I'm rocking the RM with a Casper Body in 2nd, till the draft n'pass down the back straight
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-31-2012, 08:11 AM   #513
MrUnlimited's Avatar
Would love to see the Rothmans Porsche 962c body for this chassis
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 04-02-2012, 07:14 AM   #514
DaveG28's Avatar
Trader Rating: 56 (100%+)
Is there a chance that either the tread plate spacer or the upright option are meant to sort this...though as far as I can see you'd need different arms?
What is the upright?
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
DaveG28 is offline   Reply With Quote
Old 04-02-2012, 08:17 AM   #515
DaveG28's Avatar
Ran mine for the first time yesterday, liked it but 17.5 blinky is a bit slow! So are these legal for general 12th racing? Not fussed about competitiveness, just whether you could enter general 12th races with them?
Also, anyone got a setup? I put the hopup dampers on during the day (just used supplied oil to start) and got more and more push!?
I was thinking of stiffening up the pitch springs to get the rear to break more, and loosening the diff...do you need to run the diff loose on these to stop push from a more solid rear axle?
Old 04-02-2012, 08:23 AM   #516
What surface are you running on, & size
Of course it's legal for 12th racing
What is your rollout
The kit springs are heavy, both side & center, no reason to go up on spring rate
Diff should ALWAYS be locked, and smooth with 12th scale
If the car is pushing, try the option front tires
Old 04-02-2012, 08:51 AM   #517
DaveG28's Avatar
My question on legality was just around dimensions, I haven't been in the US long and have never run 12th!! (I'm offroad normally)
Not sure on rollout, haven't measured yet, but was on option tyres all round and std spur, tried 19 and 23 on pinion, felt like 21/22 would be best. It is a short carpet track, with generally long (double apex) fast corners leading into tight corners, so no brake use, just using the corner to scrub off speed.
I probably had my diff to loose actually then, and should lock it up more.
What's the best way of clamping the rear axle, I find it binds if there's no play, but also moves a bit during the run as it has more play after...is it best to
Clamp with a tiny amount of play and just clamp it down really really hard? Feels like it may strip the thread!
Old 04-02-2012, 09:00 AM   #518
You will need a smaller spur gear, the one incl in the kit is for somewhat of a 2s application
Look back in this thread for suggestions on how to use a standard 78t 64p spur, using tape on the axle, it works awesome
95 to 100mm roll is what we run on a 90x45 track here
Clean the axle end and hub, remove all oil, and yes the screw has to be very tight, use a quality 2mm driver
There should be end play on the axle
Gearchart.com is your friend for rollout
The option rear tires may have the rear locked in too much, try kit rear, w/ option fronts
You can also adjust how you sauce the tires, what sauce are you using
Brakes are unnecessary in 17.5 blinky, the car never goes fast enough to need them, unless something is wrong on the setup, or tires
Old 04-02-2012, 01:21 PM   #519
Rothmans Porsche
Old 04-02-2012, 01:47 PM   #520
WarpdSpazm's Avatar
Should make note, this link might not be a good idea from your work computer!!! Great idea for person computer wallpaper though! Glad my boss is on vacation this week.. SHE'D not be happy to see that!
I'll be painting my Tom's this week... Little depature from the all white base...
In regards to the spur. I've heard from some F1 guys that they also have a part for this.. Just waiting to hear what they've done specifically.
Ray
Brownies Hobbies | BlackMaven MotorSports
TA-05 V.1|TT-01E|RM-01|M-05 S-Spec
Long live the Silver Can!
www.facebook.com/blackmavenmotorsports
WarpdSpazm is offline   Reply With Quote
Old 04-02-2012, 01:47 PM   #521
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
nice!
Josh-n-ya is offline   Reply With Quote
Old 04-02-2012, 02:07 PM   #522
I doubt that
The F1 diff, and axle are different
Old 04-02-2012, 02:10 PM   #523
WarpdSpazm's Avatar
I haven't run Formula since the F201, so thanks for that Red... I'll make sure to smack my buddy upside the head. LOL
On another note... Does anyone have a recommendation on a 1S lipo? $60 for a one cell is hard to swallow when I'm paying $34.99 for GOOD 2S packs...
Ray
Old 04-02-2012, 02:36 PM   #524
aussierevo's Avatar
oh the suffering that car would have had to go through for that shot
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 04-02-2012, 03:27 PM   #525
hotdognobun's Avatar
Trader Rating: 31 (100%+)
nice track layout! Do you have a shot of it going in the tunnel?
hotdognobun is offline   Reply With Quote
