Old 02-27-2012, 04:29 PM   #481
superspeed's Avatar
Originally Posted by rtypec View Post
First time driving the RM-01 or a 1/12 scale of my own of any kind This is box stock without any adjustments since I was focusing on my GT1 car most of the day.
+ YouTube Video
Thanks to my brother, George, for filming the video.
box stock = 380 motor?
superspeed is offline   Reply With Quote
Old 02-27-2012, 08:12 PM   #482
Originally Posted by RedBullFiXX View Post
As in standard non Tamiya fronts, correct, they will not work.
The Front Track on the RM-01 is 160mm, with standard 12th wheels it would be 156mm +/- i.e. too narrow.
The option front tires are a very good compound.
Pic of 703gr Race Ready RM-01 !
TQ and track record holder at our local Carpet Asylum
Option Fronts 47mm
Jaco Rear White 47mm
CRC Shorty 1s
Revtech 17.5 w/lightweight end cap
how did you get the jaco rears to fit? I tried on an old set and the center hole is too small for the tamiya hubs. Screw holes line up though.
edit: nvm, I torqued it down and forced itself in.
bored out the center hole about 0.2-0.3mm, and it fits perfectly now.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 02-28-2012, 12:39 AM   #483
cementsurfer86's Avatar
Finally getting into my RM-01 build. Stoked to get this thing on the track.
Tamiya 1/12 R/C RM-01 "Racing Master"-imag0271.jpg
Jesse Anderson / JROY386 / R_
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 02-28-2012, 12:42 AM   #484
That's what I was thinking, but the big difference is in the rear offset.
There is very little difference in front off-set to all the wheels.
we're talking a few 10ths of a mm here or there, not 2mm per wheel.
Down the road Tamiya will have a front end/Axle that will accommodate std 12th wheels.
As it is now, the car is what it is.
I think the CRCs are a bit wider than that...typically on my Speed 8 bodies the Jaco rims sit a few mm inside the body at the front where the CRC rims are pretty much just about touching...at least from what I can remember from the last time I used Jacos...my memory could be fuzzy though.
Old 02-28-2012, 05:10 AM   #485
Taman's Avatar
Trader Rating: 64 (100%+)
Just fitted the option pitch and roll dampers - that was an interesting experience getting those tiny c-clips on took me about 10 minutes with the c-clip doing it's best to be anywhere but where it should be.
How easy should it be to activate the roll damper as it doesn't seem to have alot of dampening force compared to the placstic part?
Also with the pitch damper what do you set the spring tension too, using the collar? Is it meant to be very stiff or soft?
thanks
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 02-28-2012, 05:28 AM   #486
Tim K's Avatar
I installed the new alloy pitch damper and ran it in practice. The rear end was super taily, so I switched back to the stock friction damper and it was planted again.
I'm sure the alloy damper will work, just need to spend some more time dialling it in.
Tim K is offline   Reply With Quote
Old 02-28-2012, 10:04 AM   #487
rtypec's Avatar
Box stock chassis. The electronics and motor were anything but stock
rtypec is offline   Reply With Quote
Old 02-28-2012, 10:14 PM   #488
bakaguyjean's Avatar
thanks
You have to adjust it for your running conditions. so really there isnt one way to set it up. even the stock rolling damper can be adjusted with the thickness of grease and how much you use.
Pitching is also for you and what I would tell you would not be a very good set up for you.
For example using the normal plastic rolling damper and AW grease mine feels good,but my buddy used the same AW grease and he could not even move the damper because he used a little to much.
I like to use the plastic rolling damper to find out what works good,then switch to the oil damper when I can feel how the chassis rolls in my hands with the plastic damper.
SO I have a point to tune the oil shock to. I like this way as its easier to change grease than rebuilding a shock every five minutes.
if you give some information about what rear tires you are using any gripper and what surface you are running on helps,but it is still a shot in the dark.
bakaguyjean is offline   Reply With Quote
Old 03-08-2012, 03:24 PM   #489
hotdognobun's Avatar
Trader Rating: 31 (100%+)
anyone know the release dates of all the hop up parts?
hotdognobun is offline   Reply With Quote
Old 03-08-2012, 10:11 PM   #490
I picked up most of the hop up parts like the pitch damper, roll damper, option side springs, option pitch damper springs, 2 carbon plates (forgot what they call exactly) from my LHS today except still waiting for the front titanium king pin and alum motor mount. Heading to Canadian onroad nationals with my RM-01 and see how well this beast can do!
They might not have them listed but I know the fact that they pick up 2 of each option part cause I saw it.
www.muchhobby.com
Good luck!
seasons29 is offline   Reply With Quote
Old 03-08-2012, 10:22 PM   #491
awesome! thx
Old 03-09-2012, 11:47 AM   #492
stitchy's Avatar
Tamiya RM-01/F104X1 Aluminum Roll Damper Set
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 03-11-2012, 04:52 PM   #493
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
Just won the kit in a raffle at the TCS race today at "The Track" at Harbor Hobbies. Can't wait to put the car together and run some laps. Been wanting to get this car since it came out. Need to get the Porsche body when it is available.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M06|F104 Pro|F103RM|RM-01
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 03-11-2012, 11:47 PM   #494
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Gratz
It's a fun car to race.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-12-2012, 12:17 AM   #495
Gratz
+1
