Like Tree2Likes
Old 02-07-2012, 12:06 PM   #361
dag32's Avatar
Trader Rating: 109 (100%+)
Originally Posted by RedBullFiXX View Post
Enetti rear wheels bolt right up, and have the perfect offset.
Stormer has them in stock.
Last week, I used Enetti 35 on the rear, with Tamiya Option fronts, to take TQ, track record, and the win in 12th blinky at TQ.
Dave, would that be ENN12MR35G or ENN12AR35T?
★ David Garcia ★
dag32 is offline   Reply With Quote
Old 02-07-2012, 12:24 PM   #362
OSherman's Avatar
On the Up side
It was good close racing, the RM is very easy to drive, it really just needs to go on a diet, and have an aluminum motor mount (coming in March) to be on-point.
pic please!!
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-07-2012, 01:27 PM   #363
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
G
Originally Posted by OSherman View Post
pic please!!
I believe the Enetti (48.5mm) are a touch larger in Dia (more foam) than the CRC.
Either wheel is bolt on out of the box, no mounting, or truing.
There is a trade-off though. Lite weight vs: durable
The Kit Tamiya tires have the same grip as standard 30-35 tires, but they have very little wear.
For instance, the kit tires on my RM have just over 1mm of wear since new.
The Enetti lost 1mm in 3 runs Sun.
Enetti
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-07-2012, 02:58 PM   #364
So...how are you bolting the 3 bolt pattern onto the hex adapter axle?
Old 02-07-2012, 03:40 PM   #365
rtypec's Avatar
Default Pretty in Pink...
The chassis is done and electronics are installed. I did a quick "body-off" installation run to center everything and this car has a lot of potentional. Can't wait to run it in full-on-angry mode
Thanks to all of you *cough* RBF for the informative thread. Here's a picture of how the chassis turned out:
And here is a preview of the body in progress...Pink Panther
Straight from the paint booth, aka my back yard, and I still haven't taken the protective film off. For Kevin, I used about 5 coats of Pactra metalic burgandy backed with silver (I tested backing with red, black, pink, white, etc) and this is the closest match to the Wacoal livery. I also painted all of the trim so that they won't get scratched off WHEN I roll the car
Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-rm01a.jpg   Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-wacoal1.jpg
rtypec is offline   Reply With Quote
Old 02-07-2012, 04:19 PM   #366
Just remove the 3 screws and hex adapter, then use the same 3 screws to bolt on standard 12th wheels.
Beautiful build as always HotRod
Old 02-07-2012, 09:56 PM   #367
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
heres a lil preview...just waiting on decals and a track to run on!
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 02-07-2012, 11:13 PM   #368
cementsurfer86's Avatar
I can't wait to get the Porsche when it's available! Stoked!!!
Dave, I'm sure you may have covered this, but what brand spur are you running? I definately want to run 64p when I get the car. Any special tricks to get it to fit? Thanks!!!!!
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC / Schumacher
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 02-07-2012, 11:42 PM   #369
Back a page, R-type layed it out
Tamiya 1/12 R/C RM-01 "Racing Master"
I recommend PRS, or Kimbrough gears, very high quality.
Old 02-07-2012, 11:52 PM   #370
Thanks Dave!
BTW, The car looked great at TCS! I was gonna try to make my way over to take a look at it, but I had problems with my equipment all day. (Since fired my crew chief....)
Old 02-07-2012, 11:59 PM   #371
CypressMidWest's Avatar
Upon further review, standard 12th scale front wheels are not a viable option for the RM at this time.
With 8X5 flanged bearings, they will fit, however the off-set is 2mm more than the Tamiya wheels.
This results in a reduced front track width of 4mm. which is of no use.
How much room is there to shim on the front axles? Can you run a flanged inner, and flange-less outer bearing thus allowing for more shimming on the axle side?
Just some questions from an Old-Skool 12th'er.................
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 02-08-2012, 12:05 AM   #372
Thanks Dave!
Thanks dude.
No room, that's the problem.
There may be a Hop-up option from Tamiya down the road to sort this out.
I suspect if someone really wanted to run standard front wheels, they could find a way to use a standard axle block...
Old 02-08-2012, 12:13 AM   #373
Thanks dude.
AE Old-Skool front steering blocks, with Lunsford ti axles? Might be worth looking into.......
Old 02-08-2012, 04:38 AM   #374
Taman's Avatar
Trader Rating: 64 (100%+)
Nice paint job rtypec. Where did you get the decals? I used those decals on my original toms when I was 18
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 02-08-2012, 08:00 AM   #375
rtypec's Avatar
Thanks for the kind words. The Wacoal decal sheet is from the original kit. I received a couple of sheet from the gracious people in customer service at Tamiya America several years ago.
