Old 01-25-2012, 05:12 PM   #301
Kevin CBR's Avatar
Originally Posted by OSherman View Post
is that what the dimples are for on the rear wing? the old 'hanger wire' mount?...
If there are four dimples marks, two on each side of the center line... correct ! The original '80's body used tiewraps to attach the wing to the wire wing mount.
Cuda - is this purple enough for 'ya ?
Tamiya 1/12 R/C RM-01 "Racing Master"-silk-cut-jaguar-xjr-12-2.jpg   Tamiya 1/12 R/C RM-01 "Racing Master"-silk-cut-jaguar-xjr-12.jpg
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Kevin CBR is offline   Reply With Quote
Old 01-25-2012, 06:03 PM   #302
F N CUDA's Avatar
Trader Rating: 30 (100%+)
Yep Panda, that's a bit of purple.
I found a combo of 2 spacers that fit together to allow you to run "normal" spur gears.
If you're familiar with the aftermarket spacer that lets you run the standard spurs on the F103s and 104s, this is one part of the combo.
This spacer has too large of a center i.d. for the RM 01 axle since our spur rides directly on the axle instead of a hub/stud axle like the F1s.
The second spacer needed comes from the left side of the RM 01, the black plastic one that sits between the clamp on hub and the bearing. Or you can use the aluminum spacer from the F1 but will need to slice off what you need since this spacer is much longer than needed.
These 2 spacers together will do the trick.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 01-25-2012, 09:44 PM   #303
CypressMidWest's Avatar
Originally Posted by superspeed View Post
When are these cars from? They look different than the older Mazda gtp cars.
http://www.ultimatecarpage.com/car/4...a-RX-792P.html
Check out this link....good stuff.....
or also
http://www.mulsannescorner.com/RX-792P-b.htm
possibly the coolest site on the net for hardcore GTP junkies
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 01-26-2012, 02:55 AM   #304
I have simply where already times written the ball bearing of the original spur gear, pressed in a gear like you want to run. just extend the center "0.3mm"! to press it in.
cossy4s is offline   Reply With Quote
Old 01-26-2012, 08:11 AM   #305
OSherman's Avatar
pics of this trick?
KO Propo America
EXOTEK
OSherman is offline   Reply With Quote
Old 01-26-2012, 08:54 AM   #306
Originally Posted by RedBullFiXX View Post
How cool is that !
I also hear there are many hop-ups coming soon, carbon, aluminum & goodies
If you check the set-up sheat inside the manual, you see 2 alu dampers mentioned as an option part.
My guess is that they will release also a carbon plate that's attached to the motormount and perhaps an alu stay to mount the carbon plate on it.
And probably an alu motormount too
addicted2blue is offline   Reply With Quote
Old 01-26-2012, 10:03 AM   #307
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
That and more...
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-26-2012, 04:35 PM   #308
found a site that used the dampers off the trailer trucks.
http://caboose3.blogspot.com/2011/12/tamiya-rm.html
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 01-26-2012, 04:57 PM   #309
Thanks for the link.
There is lot of interest in this car
I would wait for the correct RM-01 hop-up dampers.
The Center damper could be improved quite a bit, but the kit side damper works well as is.
They also show a spur gear bored out to 5/16" with a 5/16"x6mm spacer
Old 01-27-2012, 09:59 AM   #310
F N CUDA's Avatar
pics of this trick?
For those of you non F1 guys who may not be familiar with the spur spacer and hub spacer combo I'm referring to here's a couple shots of em.
The top spur is the standard Tamiya spur/bearing combo
The lower spur is the Kimbrough/Robinson type spur/spacer combo
The aluminum tube is the axle spacer used on the left side of the axle on an F1 to space between the hub and bearing, this is what I "sliced" a piece of to insert into the plastic spacer for the Kimbrough spur.
The pic of the single spur shows the 2 spacers combined if you look closely, aluminum spacer inside plastic then inserted into spur.
The RM01 has a smaller plastic spacer for the left side hub and doesn't need to be cut down as it is shorter already but not sure how you'll be able to get an extra one.
Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-download.jpg   Tamiya 1/12 R/C RM-01 &quot;Racing Master&quot;-spacers.jpg
Craig Hammon
Old 01-27-2012, 10:15 AM   #311
Cool
Nice work 12th scale noob
See ya Sun.
Old 01-27-2012, 11:07 AM   #312
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Someone like Avid, Acer or Boca should make a bearing for the spur gear conversion. I'm sure they would get some good sales out of just the F1 guys alone.
YR4Dude is offline   Reply With Quote
Old 01-27-2012, 12:53 PM   #313
F N CUDA's Avatar
It's possible but it would have to have some pretty little balls.
Craig Hammon
Old 01-27-2012, 01:23 PM   #314
F N CUDA's Avatar
NEWSFLASH!
After further review (in my best NFL voice), the bearing of choice is right there in our cars!
For Tamiya fans it's a 1060 and for the rest of you it's a 10mm x 6mm. It's the axle bearing on this car!
It takes only the tiniest bit of love with a body reamer to pop it into the spur (can almost force it in) as the difference is about .010" which is exactly 2 natural blonde pussy hairs.
YR4Dudedude gets credit for inspiring me to go check it out.
Rockstar this one is (Yoda voice).
Craig Hammon
Old 01-28-2012, 12:06 PM   #315
rtypec's Avatar
1s battery, s9650, and booster ordered, chassis glued and drying in garage, and Rolex 24 is about to kick off. Good times
Also found a Wacoal decal sheet so I'll be representing hotness in lingerie
rtypec is offline   Reply With Quote
