Old 01-05-2012, 07:13 AM   #211
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
How do you use a regular spur gear in the diff?
There is .350mm difference between the 6mm Tamiya axle, and a standard 1/4" axle
I used a thin piece of Tamiya yellow tape, 2 turns around the axle to fit a 1/4" flanged, or non-flanged spur gear bearing
Works a champ
Remember to use 1/8" diff balls when using 64p spur gear
78T 64p is a good size to start with
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 01-05-2012, 07:24 AM   #212
Is it possible to use/mount another 1/12Th body on this chassis?
Cause as the body isn't available as a spare part yet i'm thinking to use another body on this chassis.
addicted2blue is offline   Reply With Quote
Old 01-05-2012, 08:44 AM   #213
Yes, the RM-01 at 165mm width is a tad bit narrow compared to the 172mm max of the high-end modern 12th racers.
Wheelbase is more or less the same.
So any of the lightweight race bodies will fit no problem.
This is something i plan to do as well, until more parts & bodies are released from Tamiya.
Old 01-05-2012, 08:46 AM   #214
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by mailboxck View Post
Does anyone have a step by step build pics yet? Also, do you think Tamiya will turn the RM-01 into a mini and go up against the M05 and M06?
If you're talking about something equivalent to the Yokomo GT500 or the Kawada M300GT, it is possible. The parts are already available from the F103GT. All Tamiya needs to do is make something better looking than those comical Mini bodies. Should be easier and more fun than Minis because there are no shocks or sway bars to mess with.
YR4Dude is offline   Reply With Quote
Old 01-06-2012, 03:08 PM   #215
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
So RedBull, Are you running this car for fun or are you actually racing it in a class? Im thinking it would be cool left alone and ran as is with other racers doing the same. Maybe a body change and tires thats it.
Josh-n-ya is offline   Reply With Quote
Old 01-06-2012, 04:36 PM   #216
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Yeah, require Dave to run it box stock when racing against us, ... and carrying a brick!
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 01-06-2012, 04:40 PM   #217
Old 01-06-2012, 05:11 PM   #218
Trader Rating: 19 (100%+)
RedBull- have you been running this car as it comes in the kit? even with the tamiya tires? I wander if it would make the car slightly wider if you a set of aftermarket (jaco, parma, bsr, ect.) on it.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 01-06-2012, 05:29 PM   #219
Been running it as is. The base car is dialed, even with a heavy, low downforce body on it, curious to try an Audi R10 body to see how much quicker it can be.
Tamiya kit tires are very much like Black, Yellow.
Jaco wheels will make the car more narrow, although you can shim them out to keep it the same.
Old 01-06-2012, 06:22 PM   #220
Josh-n-ya's Avatar
The car looks to have some old and new mixed! I am going to see if Norcal Hobbies will get some of them. It would be interesting to see everyones driving skill with the same car here.
Old 01-06-2012, 11:34 PM   #221
bakaguyjean's Avatar
Well it didnt take long for third party manufactures to get involved.
Tech Racing has a nice line up of parts they released this month.
(but dont get confused the axle are for the wild willy2)
http://www.tech-racing.co.jp/sinseihin2012-01-17.html
Expect to see everybody else offering stuff along he same lines soon.
And on more thing the RM-01 F1 based link car
http://www.tech-racing.co.jp/sinseihin2012-1-20.html
bakaguyjean is offline   Reply With Quote
Old 01-07-2012, 03:49 AM   #222
Cool info thanks !
Mini servo mount holes are a good choice, would be better if they were slotted.
Interesting to see Tech are going with 2mm carbon chassis, and more cutouts than the standard chassis.
Most new chassis are 2.5mm, with less cutouts.
Tech Carbon RM-01 Chassis upgrade.
Tamiya Standard Chassis
Old 01-07-2012, 04:04 AM   #223
Trader Rating: 45 (100%+)
So cool, a 1:12 F1 chassis...
Do you think Tamiya will ever release a competition version RM-01?
Apex is offline   Reply With Quote
Old 01-07-2012, 06:59 AM   #224
I think you will see a F1 link chassis before a RM-01 pro from Tamiya, The Tech chassis is for a 1/10th link useing RM-01 parts
Old 01-07-2012, 06:41 PM   #225
The RM01 is awesome. First time out today against Associateds, CRCs, TOPs, etc, came in third with kit tires. RAD
OutsideLine is offline   Reply With Quote
